Question about Sony KP-46WT510 46" Rear Projection HDTV
Having a problem with my Sony KP-46WT510 46 in tv
It shut off out of know where. It is giving 7 blinks after it shuts down? Is this a major or minor repair?
Thanks,
JoAnn
  • 1 more comment
  • joandrsn Jul 04, 2008
    I checked again on the number of blinks and had someone else check it and it is 6 blinks. Hope it is still a minor repair.
    how much would the repair cost me?
    Thanks,
    Joann
    So what you are telling me it will either be 300 or 200 to fix?
    Thanks,
    Joann
  • Sony Master
  • 8,617 Answers
Very minor. Horizontal deflection is stopped Q8035 or Q8038 on the D board is defective. Change both just to be sure. If you need more assistance let me know.
Posted on Jul 04, 2008
  • Sonny Berry
    Sonny Berry Jul 04, 2008
    Thats alittle more involved as the +5 line is shorted or over loaded on either the A or B pc boards.
  • Sonny Berry
    A repair shop will most likely want to replace the A board first at about 300 if that doesnt do it then the b board at about 200. Most shops wont do component level troubleshooting on the A board. the b Board has no serviceable parts so that has to be replaced if the trouble is on that board
Tv well turn on then turn off
The power indicator should blink a series of blinks pause slightly the keep repeating the blink sequence. let me know the blink sequence and I can let you know why the set is shutting down.
Aug 04, 2012 | Sony KP-46WT500 46" Rear Projection...
Sony tv powers off
does the power indicator blink when it shuts down? If so let me know the number of blinks as thats a error code indicating which circuit has the issue.
Oct 19, 2011 | Sony KP-57WS500 57" Rear Projection...
I have a Sony kp-51ws500 I had the tubes fixed 3 years ago!! Now the blue screen flashes & shuts down the tv!! Also the red timer lite is blinking at the same time!!! I dont have the timer set!! Please...
The Blue CRT has shorted and shutting the set down. You can verify this by simply sliding the Blue CRT drive board off the neck without unplugging any of its wires, Just let it hang suspended and then try powering up the set. If the set stays on you will know the Blue CRT needs replacement.
Sep 19, 2010 | Sony KP-51WS500 51" Rear Projection...
Have sony kp51ws500 won't turn on, it clicks then shuts down and i get 7 blinks on front--had green, blue, and red line issues before
Hi wright
To answer your question;
The 7 blinks code(sony error codes) means that the horizontal deflection has stopped.
The common cause for this are transistors Q8035,Q8038 and the horizontal output Q8024 all located on "D" board.
Hope this help and let me know if you need further assistance.
Feb 18, 2010 | Sony KP-51WS500 51" Rear Projection...
I get curved red lines and then screen goes completely red and no sound
This is symptom of defective red picture tube in TV that needs to be replaced.
Let me know if you want to replace it by yourself to provide you part number info or call tv tech to do the job.
Thanks.
Nov 30, 2009 | Sony KP-65WV700 65" Rear Projection HDTV
KP-51HW40 - Auto shut down problem
I had the same problem. i was told by one of these so-called experts @ fixya that my flyback transformer needed to be replaced (the 8 blinks on the standby was the indicator). but i recently replaced it and im having the same problem. sorry. no advice. good luck.
Jun 18, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony Tv 7 Blinks
its the horizontal deflection has stopped the q5006 on the D board is broken or else ic 452 is faulty on the A board if you need to know where you can order these parts let me know and I will post a link also they offer free tec advice
Apr 10, 2008 | Televison & Video
KP-46S4U lose picture after a few second blink of brightness
does the from led blink if so how mant times pause then blink again?
Feb 12, 2008 | Sony KP-48S65 48" Rear Projection...
Kv40xbr800 standby flashes 7 times, sony 40" Hello. I hope some 1 can help. I've a 41" rear project Sony TV ModelKP-41T65. One day it just decides not to turn on. When you turn on thepower you hear the...
7 blinks on a sony indicate that high voltage has exceeded 33K and the set is going into safety shut down. Check your Horizontal and rgulator circuits. Something in those circuits are causing the increased voltage.Hope this helps let me know if I can help you further.
Dec 02, 2007 | Sony KP-41T65 41" Rear Projection...
Cant fix my sony KP-53S65
If the TV will not turn on and the red light blinks on the front of the set, it means that the microprocessor has detected a problem in the set and shut the set down. It then blinks the red light a certain number of times, and the number of blinks is the code for why the set has shut off. How many times does the red light blink before repeating?
Aug 07, 2007 | Sony KP-53S65 53" Rear Projection...
Sony KP-46WT510 46" Rear Projection HDTV Logo
105 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
