Need to get the gas out of my tank in my 1998 chevy venture van can you tell me the easiest way the head is cracked in my motor so i am junking it but i have a full tank of gas
My 01 Chevy venture just got a new fuel pump put in gas gauge still isn't working proper so had another fuel pump put in same problem. My relay fuse is good fuel pump fuse is good. I have to have my wires checked, make sure my sensor on top of pump connector wires are good. What else can I be looking for?
First if it is over heating check coolant level,if okay make sure there is no air in the system. Because of age of the car check for wiring issues like exposed wires at connectors that maybe grounding.
No way to drain it other than sticking a small hose down the fuel tank inlet, and syphoning it out. The tank is plastic, so it is light, even with a couple gallons left in it. Only three straps hold it to the underbody, so you remove 3 bolts, and the electrical connections, and the two fuel line connectors, and it comes off of the van.
No it's not, if your van is running fine, fuel pump is good, just the fuel gauge sending unit is bad, to repair, the gas tank will have to come off, the sending unit sit on the same hanger the fuel pump is on.
most any sensor going bad can cause the check engine light to come on,try disconnecting the posative battery cable for 15 seconds ,then put it back on,will reset the codes, or take it to auto zone,they will test your computer for codes at no charge to you.i had a venture van my was ox. sensor. thanks robert b.
