Question about Acer Aspire 3690-2196 Notebook
Turn on hi! i just changed my hardisk twice. its samsung 120 gb ide.. when i turn on the laptop, the acer page appears then its black instead of windows xp appearing.. what i do is i turn on the switch again, then maybe after 3 -4 times opening the laptop starts to open. what seems to be the problem? i believe if i turn on the laptop the windows xp should appear right after the acer page..is my mother board having a problem?
  • Roberta Smith
    Roberta Smith May 11, 2010
    ummm you did actually reinstall a replacement operating system when you changed the drive right ?
    Robert
  • Glenn Rogers
    Glenn Rogers May 11, 2010
    How and what did you use to install windows on this new hard drive? Or did you clone it and if so, what program did you use?
    Worldvet
  • 95 Answers
I would do another clean install...Start the machine with the OS disk in tray/follow on screen instruction...if it does not works that way when you start the machine up go to setup and make cdrom your 1st boot/save and exit/then restart machine and follwo instructions
Posted on Aug 31, 2008
ACER REINSTALL STUCK ON INSTALLING CLEANUP 28/29
Sounds like the recovery disk when BURNT contains errors, you need the factory discs for your system
Jan 26, 2013 | Acer Upper Case Palmrest for Aspire 5336,...
I have installed Windows 7 to my Acer Aspire One AOD255 but i want to revert it back to Windows XP and I no longer have the Windows.old folder. How can i downgrade it back?
If it originally came with Windows XP and it has the recovery partition still untouched (assuming the disk hadn't been formated to only one partition), you might recover the system from the hidden recovery partition.
To initiate this process, switch on the laptop and press F10 when the ACER logo appears (some computers need you to press ALT and F10 together, instead of the F10 only. If the Acer Recovery Management starts, you just have to follow the instructions to recover your system.
If nothing happens after pressing F10 or ALT and F10, you will need to get a Windows XP installation CD and a external CD drive to reinstall the whole system.
In this case, first you have to enter setup by pressing F2 at boot time, as soon as the ACER logo appears in the screen. Then, you will need to switch the SATA Mode to IDE from AHCI.
Select: Main -> SATA Mode -> IDE
This is done to allow Window XP to see your SATA.as an IDE disk and install the system.
When you get the external USB CD/DVD driver to use with a Windows XP installer CD, connect it to you laptop, switch it on and press F2 again to enter Setup.
This time, scroll over to the BOOT menu and press Enter. Scroll down to the last option USB CD- Rom and then use the F5 key to move it to the top of the boot list order. Then press Escape and then F10 and finally Enter. The computer will restart and load the CD and you can start the installation of Windows XP.
Hope this info may help you!
Mar 13, 2011 | Acer Aspire One D255-1549 Atom N550...
I want to upgrade the hard drive. What type do I need ide, ata, sata
the upgrading can be done only if the motherboard support if your laptop had sata provision you can use them if you dont have you cant use sata check the motherboard
Dec 15, 2010 | Acer Aspire 5100-5480 Notebook
My Dell Desktop cannot start in Safe Mode
hi there,
you mention you have change your hardisk,you have to check if your hardisk was configure in cmos and bios set up, first whaen you start your computer press F2 then bios set up appear,check your device if
was connected on your system.on main menu check your ram if it was connectd,then press arrow right to advanced menu check your hardisk from IDE configuration if both hardisk and memory was installed or cofigured by your system.go to boot menu to set your device, on boot menu,scroll it from boot device priority
if you assure there is windows installed already on your hardisk,priority your hardisk,second your cd room,third floopy etc.press F10 to save and restart your computer,If no sytem was appears you must reinstalled your windows but you should change again
the boot set by priority the cd room instead of hardisk in order to put windows on your computer.press F10 again to save and restart your computer
to install your windows
insert windows cd on cd room
wait to configure your computer by the cd windows
then ff the windows installation procedure
until windows installation was finish.have a nice day don't forget to rate me please.thank you
Feb 21, 2010 | Dell Dimension 3100 PC Desktop
I have a samsung sp1203N 120gig capacity, running with a new WDC WD5000AAKS-00A7B2 500GB HD ,as the primary drive on windows 7. My problem is that my samsung drive is only reading at a 31.4 GB capacity...
On XP, it was Control Panel, Administrative Tools, Computer Management, Disk Management.
Upgrade the 120gb to a Dynamic disk and then extend the partition, or if there's no data on it yet, delete the 32gb and create a 120gb one.
Should not be that different under Win7. Hasn't changed much since NT4.0
Jun 30, 2009 | Samsung (SP1203N) 120 GB Hard Drive
Hard drive not working
hi im josh in cebu phils.Friend if that happens whrein your 2nd hdd dont detect. Try to use these solutions. Check first the jumper of the hardisk whether it is stated as slave or master. if 2nd disk is master the jumper should be in the master and if it is slave the jumper must be slave. or try to use another IDE cable. put them as both master the first hdd in first ide slot and your 8 GB 2nd hardisk in 2nd slot as master also. or try to enter bios setup utility then try to check or detect the both device.thats all good luck
Feb 26, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
RHEL %
change HDD mode in bios setup and try.
it seems that RHEL is not supporting your SATA hardisk.
Aug 01, 2008 | Acer Aspire 5610-4648 Notebook
Error to Detect, hardisk must be formatted
The problem might not be with the HHD instead it could be your bios setup. you will have to download drivers for the bios of you laptop and install them in your operating system then try to access the hard-disk.
Mar 12, 2008 | Computers & Internet
Acer Aspire 3690-2196 Notebook Logo
106 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
