TV Turns off automatically
Just can not turn it on anymore. never had theis issue before my tv will be on for a while....and then poof! turns off and wont turn back on unless I unplug it and plug it back in. Sometimes that doesn't even work until I wait like ten minutes or so. Sometime hitting it works too. (I got frustrated) If you know how I can fix it myself I'm all ears.
  • 2 more comments
  • Bryan_Kiefer Jul 04, 2008
    my tv will be on for a while....and then poof! turns off and wont turn back on unless I unplug it and plug it back in. Sometimes that doesn't even work until I wait like ten minutes or so. Sometime hitting it works too. (I got frustrated) If you know how I can fix it myself I'm all ears. I have a 32" Sharp standard tube tv. Not sure of the exact model. It's about 7 years old.
    Can I replace the tube so it holds the power?
    So, if it's a case of cold solder issues, please help me understand why it stays on for awhile, (most times 20min. somethimes days.) Also, if I hit it, it seemes to be the most effective although I would rather not keep doing that but that tells me something might be loose. (????) I'm not an electronic guy, so I don't quite understand.
  • Bryan_Kiefer Jul 05, 2008
    Thanks. I think I will take it in to a repair shop.
  • 2,071 Answers
That is the oscillation sound comes from the relay,cannot continue because of protection mode,by the system.. Your tv parts is ok.only the solder joint is crack or cold thats why function abnormally,goes off and goes on, due to the voltage trap, when voltage is there the solder is hot and connect the parts joint, when voltage extremely hot, due to prolong use it will disconnect the solder joint parts thats why you cannot see picture..its need to reheat the solder joint of all parts affected....power supply section ,,horizontal section,vertical section ..and to microprocessor ic section including jungle ic..
find a tv technician to do the works .in order to avoid high voltage shock this not cost too much because only reheating works....
Posted on Jul 04, 2008
  • 983 Answers
I think some component is getting over heated inside so you are facing this type of problem ....
the component may be transformer,capacitor on some circuit board ...
due to this temperature variation you tv will turn off ...
or may be some IC(intergrated circuit ) is gone ...
there will be one Video IC if it is gone means also you will this problem ...
if it is gone it will get heated very shortly so the tv will turn off due this variation in temperature ...
just have a check with these components.......
    Brigadier General:
  • 6,966 Answers
Based on your description, it would appear to be a case of cold solder issue (most likely) or heat related (just a possibility) or both interrelated.
Repairs wold require the application of a low wattage soldering iron at the determine cold solder joints. They can be determined by checking for those that are dull grayish in color as compared to the regular/good bright silvery. Should you not be able to determine the exact cold solder joint, a shotgun approach would also do. This is re-soldering most of the major joints with particular attention to the power devices such as the bridge diode, regulator IC, chopper transformer, capacitors in the power supply; the vertical IC; the flyback transformer pins and the Horizontal out. Often, the major joints would be bigger than the regular solder joints.
The above of course requires familiarity with electronic circuitry and components, use of a soldering iron and perhaps even a DVM. Should you be uncomfortable, then perhaps your best bet wold be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back on the model number how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
  • Louie  Role
    Louie Role Jul 04, 2008
    Hi again,
    Appreciate the postback....
    cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected (hanging by a thread). When the TV turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. Jarring the unit creates movement inside enough to re establish the contact, sometime good enough sometimes not enough.
    Again, since the unit still operates (sometimes) then it is highly probable that there are no defective components. As you have surmised, it is possibly a loose connection, solder joints are "connections" except that molten soldering lead is used to attach/connect the component to the board, "loose connection" in this sense is equal to "cold solder".
    Again on the assumption of no defective parts, then seeking a more experienced buddy for the soldering might be to your advantage. This is of course in addition to the possible electrical hazards when repairing the inside of a TV unit for any lay/unexperienced repair person.
  • Louie  Role
    This might be of help to you.
  • 1,879 Answers
Greetings,
Your tube is experiencing power supply failure. Can't sustain electrical power for the whole system.
If you do electronic troubleshooting, check the power supply section. Else, get a qualified repairman.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
    Master:
  • 848 Answers
Your tv is having powersupply problem
smps might not be working properly check it
the power supply is not reaching the main board properly
give details about your tv - make and model number
Why does my Onkyo turn on automatically with the TV?
Codes are the same for both units. You can experiment with finding different codes that allow independent selection.
Jan 23, 2017 | Televison & Video
I have a 58 inch Sanyo flat screen TV, I turn it on everything works fine, shuts down in about 10 minutes! Sound stays on though. If I shut it off and turn it back on it does the same thing!
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I demonstrate in this video how to repair a Sanyo by swap out the... the Sanyo DP47460 that I'm having an issue with. after ~ 40minutes of watching, if I attempt to change the channel or adjust the volume, the picture/screen freezes. ... After ~ 20 seconds, theTV will automatically shut off, then turn back on.
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ... Hi, I've got a Samsung LED TV that switches off after20 seconds and remains off. .... after about couple of minutes, is this the same problem with the tv in the video? .... 10:32. How to repair a Samsung LCD TV with a flashing standby ...
TV Turns On, Backlight Inverter Immediately Turns Off TV ..
Dec 17, 2015 | Televison & Video
TV automatically turns off. unpluged the tv and
Hey i am having the same exact problem with my same exact tv. If you have already solved your problem I would love to know how u did it. I know you posted this a long time ago but if you havent gotten it fixed yet, if I fix mine i will let you know. Thanks.
Aug 03, 2010 | Toshiba 65H84 65" Rear Projection HDTV
Screen turns bright green and stays that way until I turn the TV off and then back on. Ususally happens during channel surfing.
I had the exact same problem with my Toshiba 26" LCD; it ended out being my cable box. The cable guy switched it out for a better model, and poof! No more problem. P.S., you don't have to turn the unit off and on; simply press a menu or information button and it will come right back. Using the TV power button that often can be hard on your set.
Mar 11, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Set is 7 years old - it turns off intermintently
Ours used to do that - and then we moved it to another state with us. Since the move it doesn't shut itself off anymore. I suspect that the problem was dirt and dust inside which got knocked loose in the move and the shutdown was due to thermal limits being exceeded. You may want to try vacuuming or blowing out the dust inside if you feel comfortable opening up the unit.
Feb 15, 2010 | RCA D52W135D 52 in. TV/DVD Combo
Our LA32R81B Samsung shut off during thunderstorm&it wont turn on
you probably need a new motherboard or hopefully something that cost less. i had the same thing happen to me with a tv, took it to repair shop and they said needed a new motherboard. good luck
Apr 22, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Turn on and stay on
It seems that Your TV set may have a problem with its power supply circuit, the problem is intermitent bring it to the repair shop.
Nov 06, 2008 | Televison & Video
Could be a problem with the flyback /auto transformer / powerboard. I'd get those checked first..
May 10, 2008 | Pioneer SD-P50A3-K TV
DLP TV turning on and off automatically - Mitsubishi WD-52327
1. Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if low or missing check C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB part # 930B929001
Sep 18, 2007 | Mitsubishi WD-52327 52" Rear Projection...
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
Electro Med Services...
