Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Ice Maker My icemaker doesn't seem to want to work...I think I banged the wire that controls when to shut off the ice maker (on/off ) over hanging wire...so what to I do.
    Sergeant:
    Champion:
  • 330 Answers
Maybe the wire loss from inside, be careful, don't get electric shut.
Posted on Jul 10, 2008
Ice maker not working on model ED2LFXHW02
ice maker not working YouTube
Check the wire feeler that normally sits on top of the ice. If it is lifted above the ice it shuts the icemaker off.
Oct 09, 2014 | Refrigerators
Ice maker won't stop filling
The ice maker it self is what powers up the water valve after every ice harvest. You have a bad ice maker or the wires shorted somewhere in the harness.
Dec 30, 2013 | Maytag Refrigerators
Ice maker doesn't work
Testing the ice maker:
As far as the smaller line (1/4") you have to manually advance the ice maker and wait for it to call for water with the 1/4" line disconnected from the valve. For whirlpool and its subsidaries,you can do this by getting a jumper wire, removing the cover of icemaker, which you jsut grab and pull off, and using the jumper wire insert one end of the wire into the cirle marked m and the other in the cicle marked n. Leave there until you hear a click and sometimes see a little spark behind the modular head wheel. For GE, you turtn the ice maker off, wait about a minute then turn back on, water should automatically shoot water in the icemaker. That will tell you the water valve is good and icemaker is bad, or the ice maker is good and the valve is bad if no water. Also if you see ice in the maker that hasn't dumper and the teeth of the icemaker are facing any direction other than two o clock position, the icemaker is bad. Also check the fill tube to be sure the no ice is blocking water from coming in.
Jun 17, 2012 | Kenmore Refrigerators
Whirlpool ice maker locks out after every cycle. I removed the ice maker to clear a ice jam and after I reinstalled it, it only runs one cycle and the control locks in the up position shutting the ice...
The internal part that is supposed to relases the control arm when the icemaker is harvestiing a cycle is hanging up and the icemaker itself or motor board would need to be replaced...all that is really needed would be the motor module and its less expensive the part numbers are
ENTIRE ICEMAKER 4317943
MODULE W10190935
depending on which one ya decide to replace (the entire icemaker or just the module) it can be purchased at your local appliance parts store or online at
searspartsdirect.com
repairclinic.com
apdepot.com
apwagner.com
partselect.com
GENE
Sep 26, 2011 | Refrigerators
Ice maker is not working.
Ice maker has built in thermostat that turns cycle on at around 10 degrees F. If freezer temp does not reach that point the ice maker will not cycle. So either the freezer is not cold enough or the thermostat is faulty.
Make sure that the ice maker motor that turns the cams and controls the various stages is also working.
Apr 08, 2017 | Frigidaire 20.6 cu. ft. Top Freezer...
Sears model KSRA25FKBL00 How do I remove the icemaker to replace it
Well you can please follow the below steps -
1. Ensure that the water going into the ice maker is shut off. If there is not a valve on the water line going to the refrigerator, check under the house, because there is usually a shutoff valve there.
If there is no shutoff valve for the water line, which is rare, it is possible to cap off the water line with a screw on end cap. If this is the case, you would have to shut the water off completely in the house, cap off the water line, and turn the water back on.
2. Remove the container that holds the ice, as well as any plastic shelves.
3. Remove the screws holding the ice maker in place. There are usually only two and they connect the icemaker to the inside of the freezer.
4. Disconnect the wiring harness that is hooked up to the ice maker.
5. Disconnect the water line from the ice maker.
6. Remove the ice maker.
Please post comments for more help or information........
Good Luck!!
Thanks
Jan 24, 2010 | KitchenAid KSCS25FKSS Side by Side...
Water overfills icemaker. Won't shut off properly
Good day,
There is a micro switch in the ice maker that turns on the water valve for approx. 7 seconds, and then closes it.
If the valve is hanging open, even though receiving no input from the ice maker then the water valve needs replaced.
Nov 30, 2009 | Kenmore Refrigerators
Icemaker does not make ice. Appears no water is getting to maker.
If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
May 20, 2009 | Refrigerators
Ice maker
your plastic water tube coming in to the icemaker is probably frozen needs to be taken out and remove ice not letting water come in to icemaker I have run on this alot in the field.This seems to happen [alot] when you turn off the water to the icemaker
Sep 14, 2008 | Kenmore 53642 / 53644 Side by Side...
Icemaker
Check the power conection to the ice maker. If that's ok, then I would think the solenoid that controls the water flow has gone bad. Unfortunately, you will likely have to replace the whole ice maker, I don't think they are reparable.
Feb 11, 2007 | Kenmore 53632 / 53634 Side by Side...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
43 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
