Question about E-Machines e15t 15" Flat Panel LCD Monitor
Panel display one-half is OK, another half is whitish blur.
  • Anonymous Dec 05, 2008
    only half of the page is showing even when I shut it down and start it again. Side arrows do not move it to the right either.
  • 983 Answers
The discoloration problem is due to the near by magnetic field (magnetic interference or due to magnets) appliances like speakers which are very near to monitors ...
so what you have to do is just keep some distance to the monitor from the speakers and other magnetic appliances and then press menu button & just give degauss.
Posted on Sep 05, 2008
  • Dileep Keshavanarayana
    Dileep Keshavanarayana Sep 05, 2008
    if you still persist the same problem then there may be some problem in CRT inside take it to technician ...
    once you try rubbing the screen against the magnets
My Vizio GV42L is fading to a dull whitish color after 2-3 minutes. I can still see the TV program I am on but the screen just goes to a dull whitish color. No boxes or anything popping up. Basical
Either its back light inverter board, or, the LVDS cable has the fault. First try by re-seat the LVDS cable, and check. Thus you can make sure about the fault. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic /Timeslide, can be selected by the drop-down list, by the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window.
Nov 06, 2013 | Vizio GV42L 42 in. LCD Television
Half screen is blurred
if as it appears a LCD and problem is half screen is "blurred" the set uses two (or one large) boards and each drives the picture on half the screen---could be one bad, poor connection or worst case defect in screen unit (display panel) which would be fatal.
Aug 27, 2012 | Toshiba Regza 52XF550U 52 in. LCD HDTV
Focus on Ricoh R6
Could be that the electrical connector on the autofocus has come off. This is a job for a repairer.
Mar 21, 2012 | Ricoh Caplio R6 Digital Camera
I have a display problem for nokia 5233 my display screen bets blur
hi friend
your LCD display leakage
cause of blur
OK
change your display
Apr 08, 2011 | Computers & Internet
My 5 years old Plasma TV found half of the screen picture view not very clear.. The half colour seen blur..
Your Buffer boards or the YSUS main are bad. THe YBU-Y Buffer upper controls the top half of display, the YBL-Y Buffer lower controls the bottom half and the YSUS Main controls both those boards. They are located to the Far Left on and opened Set.
Jun 21, 2010 | Philips 42PF9966 42 in. HD-Ready Plasma...
Wont turn on
The problem usually is from low quality or defective "capacitors" on the main circuit board. There are two capacitors in particular on the main board that causes problems with these tv's. You can check for swelled up capacitors or burn marks on the circuit board. You can also purchase an analog tester or ohmmeter and test the capacitors.
If for some reason these caps test to be ok, then test the power inverter.
May 13, 2010 | Philips 37MF231D 37 in. LCD Television
Blurred side of projector
This is caused by misaligned lens and/or display panel (LCD or DLP). Recommend a trained tech to perform alignment.
Mar 08, 2009 | HP Digital Projector Vp6110 Multimedia...
Resolution
You could check your DPI setting in the display, being a large monitor your DPI setting shoul be up around the 75 - 85 Hertz.
To access this
Control Panel --> Display --> Settings --> Advanced --> Monitor and then click the drop down box and see what the DPI is set to and keep trying the different options until it is clear.
Hope this helps.
Dec 04, 2007 | Gateway GT4010 (RBGT4010) PC Desktop
HP cp1700 printer display panel blurred
is it the print coming out ok or blorred go to hp website and download drivers and software plus contact them for assistance on your printer. hope this has helped
Aug 14, 2007 | HP cp1700 Color Inkjet Printer
E-Machines e15t 15" Flat Panel LCD Monitor Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
