There
is only 1 reason as to the unit still running but not heating if its
running then all thermos must be intact so it has to be the heating coil
take the unit appart make sure the two heating points still have the
cables attached if you can do a polarity test on the element that will
define its blown then replace the coil in most cases when the coil blows
you can see a burn mark were it did
best luck
please take the time to rank this advice
merry christmas
With the Avanti D110, it also uses an additional fan belt which, if it breaks, will not heat. This is separate from the drum rotation belt. My dryer was spinning the drum fine but not getting any heat. The secondary fan belt was broken and was the problem. While it was open, the heating coil and other electrics were checked to be ok.
That is the part that broke on mine also, but I cannot find anywhere to get the part # or to order it... any help appreciated!!
On the parts exploded view in the manual, it doesn't have the part number. You actually have to call Avanti and tell them the part you need, the secondary fan-drive belt.
ahh thanks so much!! I got all the numbers off the dryer so I'll be set when I call.
