DVD player reads no disc. Was working just fine earlier today
  • 173 Answers
Try these solutions: 1. Check to make sure the discs you are using are not scratched or dirty, if so clean them with a soft cloth and a small amount of rubbing alcohol on the rag. 2. Remove the cover from your dvd player by using a Phillips screw driver > Then push the eject button > Once the cd tray is out unplug the dvd player from the outlet > Take a few cu-tips and dip them lightly in a small amount of rubbing alcohol and with a small light source look in the carriage and you will see a small round glass looking bubble > This will be your laser optical lens, gently clean off the optical lens with the cu-tip moistened with alcohol > Repeat cleaning with a new cu-tip a few times > Dry off the optical lens with a dry cu-tip and let the dvd player air dry for 1 minute > Replace the cover and plug your dvd player back in and check to see if it plays the dvds.
You might want to invest in a optical lens cleaning disc which are cheap to buy. You should clean your optical lens at least once a month or as needed.
Hope this helps and let me know if it doesn't.
Posted on Jul 04, 2008
Disc load problem
DVD players need a finilized disk. When the program finilizes the disk, it's writing the TOC which is where the players go to find the files.
Mar 12, 2014 | Toshiba RD-XS34 DVD Player/HDD Recorder
How can I play a disc reading incorrect and error It worked fine this morning
Try some other discs first or try that on another player, usually if cannot read the disc either a dirty of bad Optical Pickup in the player.
Dec 16, 2012 | Toshiba SD-V291 DVD Player/VCR
Have an LG LHB306 blu-ray player. Worked fine until today. Put disc in , states
If it states no disc, cannot read, etc you have either a dirty or bad optical pickup in the unit.
Jun 17, 2012 | LG BD370 BLU RAY PLAYER
Player will not read discs. keeps saying "no disc" when discs are inserted. Worked fine until today.
Easy option first , clean laser with a laser cleaning disc ,if that doesn't work then (I assume you have tried more than 1 disc). a laser won't read a dirty disc, you may have a laser mechanism fault ie laser sticking in its tracks. you could try oiling the cradle that the laser sits on. other than that it is a costly repair.
Mar 06, 2011 | Toshiba SD-3990 DVD Player
Was working earlier today, now won't. Turns on
i will suggest you check the lens if it is still working properly. then you can tell why it seems to be giving such fault.
clean the lens and try it again.
the disc you are trying could also be a problem so you make sure the disc is ok before trying to play it on your dvd.
Feb 04, 2010 | Insignia NS-BRDVD Blu-Ray Player
Won't play DVDs.
I put in a dvd and get the "disc error" message. This magnavox dvd player is less than a year old.
Jan 05, 2010 | Philips Magnavox DVD/VCR Dual Player
Dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would...
dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would it just wont read. any ideas?
Oct 12, 2009 | Cyberhome CH-DVD 300 DVD Player
No disc error only for DVDs
This is problem laser unite replace it
Sep 05, 2009 | Sony DVP-NS575P DVD Player
Polaroid pdm-0732 wont read dvd
I just solved my issue. My 2 year old son set the AV switch on the side of the player to 'in'. I switched it to 'out' and now it works fine.
Nov 25, 2007 | Polaroid PDM-0732 Portable DVD Player
Televison & Video Logo
126 people viewed this question
Top Televison & Video Experts
