Wireless-n access point will not power on - Computers & Internet
  • Shaun Harris
    Shaun Harris May 11, 2010
    What brand is your access point? This is a router correct?
  • 83 Answers
You have not clarified anything to this statement of yours. The best I can say with what you stated is make sure the device is plugged in and if so and it still doesnt power on, I'd bring it back to where you purchased it and get a replacement.
Posted on Jul 21, 2008
Check connections
The connection of the USB cable
Verify that the USB cable is connected between your Brother machine and your PC.
The connection of the LAN cable (if applicable)
Verify that the network cable is connected between your Brother machine and access point and the machine is powered on.
1.Access point/router
2.Wired Network machine (your machine)
3.Wireless capable computer connected to the access point/router
4.Wired computer connected to the access point/router
The connection of the Wireless network
2.Wireless Network machine (your machine)
Still having Problem Then follow Us For
Brother Printer Support
Feb 20, 2014 | Brother MFC 7840W Printer
Both ethernet and power led flashing and never get steady for wap300n access point
Try another power adapter. Power should be constant and Ethernet when engaged will blink on and off.
Jan 29, 2014 | Cisco Consumer Linksys WAP300N Wireless-N...
Need basic step-by-step instructions on how to install my router.
To Configure the Router with Internet Access
Connect to one of the wireless router/access point's LAN Ethernet ports, turn off its DHCP server, and give the wireless router a static IP on your LAN:
  1. Connect a PC directly to a LAN port on the wireless router with an Ethernet cable.
  2. Power on the wireless router/access point.
  3. Reboot the PC.
  4. Log in to the wireless router though a browser. (Usually, with User Name = admin and Password = password, unless you changed them from the defaults).
  5. Go to the LAN IP menu and disable the wireless access point’s DHCP server by unchecking Use router as DHCP server.
  6. Select LAN IP, and change the IP to
  7. Click Apply to save the settings. You will lose the connection to the wireless router/access point , since its IP changed.
  8. Log in to the wireless router/access point with the URL:
  9. Connect one of the wireless router's Local (LAN) ports to your existing network.
This completes the wireless router/access point configuration.
  • You can now log in to the wireless router/access point at its new address of and configure wireless features such as WEP and Access Control List
  • UPnP, DMZ, Port Forwarding, and Port Triggering are not used on the wireless router/access point, and it doesn't matter how they are configured.
  1. Configure the LAN IP address to be within the same subnet as your PCs.
    • Take care not to use an IP address already being used.
    • Limit the number of addresses in the DHCP range and assign an IP address outside of the range to the router you want to use as the Access Point.
  2. Disable DHCP on the wireless router/access point.
  3. Connect one of the LAN ports on the wireless router/access point to a LAN port on the Router.
  4. Configure the SSID and any security settings on the wireless PCs to match the wireless router/access point's SSID and security settings.
a. SSIDs must be the same on all wireless devices. (These are case-sensitive: netGEAR is not the same as NETGEAR.)
b. Tip: Make sure the wireless PCs can connect before configuring WEP, WPA-PSK, or other wireless encryption.
Jan 02, 2010 | NetGear WGT624 Wireless Router
My wireless assistant won't turn on?
Check to make sure there is power to the power adapter and the DC output is coming out on the end that plugs to the Access Point. if not replace the power adapter. If power is Ok replace the access point
Dec 27, 2009 | HP Computers & Internet
1. Shut off the power to your cable or dsl modem for about 30 minutes.
2. Connect the ethernet cable from your modem to the Internet port on the router.
3. After 30 minute power on ONLY the modem NOT the router
4. Wait about 60 seconds and power on the router
Try it now.
Oct 29, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
If you want to use a wireless broadband internet on any mobile you need to use a gate way for that or an access point. is the best esyest & economical way as you can acceess internet on other gadgets simultenusly. go ahead with Lynksys or netgear.
Jul 09, 2009 | Linksys Access Point WAP54GP Wireless-G...
Wireless light does not light
Hey Nassim, ;
Please note that the concerned product is a wireless access point and not a wireless adapter.
For drama_que916
Please reset the Access point by pressing the reset hole on the back panel of the AP when it is being powered on. after 30 seconds release the rese hole and then turn it off and then turn it back on
Now check if it shows proper lights.
Mar 17, 2009 | NetGear WG602 54Mbps Wireless G Access...
How to Configure Nomadix AG2000W from scratch
-- what is the exact model number of your access point and router?
-- what is the ip address of your access point and router?
-- what is the operating system of your computer?
-- Is your computer directly connected to the router?
-- Do you have a wireless computer? what is the model number of the wireless adapter
if you want to configure your access point with your router you may try the ff:
Step 1: Connect the Ethernet port of the access point to one of the Ethernet ports of the router
Step 2: Make sure the power adapter is plugged to an available power outlet
Step 3: Check if the corresponding LEDs on the access point are lit
Step 4: After connecting the devices together, configure the access point’s wireless settings
Step 5: Open the access point’s web-based setup page
Step 6: When the access point’s web-based setup page opens, change the SSID, Channel, and Wireless Security.
Apr 21, 2008 | Nomadix AG-2000W 802.11a, 802.11g/b...
3com router doesnt work at all
contact your ISP for proper settings for the router.
Nov 11, 2007 | 3Com OfficeConnect Wireless 108Mbps 11g...
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
