Question about Coleman (100076) Compact Refrigerator
Coleman generator needs repair?
I have a brand new 1400 watt coleman pro force generator. I bought it about two monthes ago and tested it after purchasing. When I tested it I'm afraid that I may have overloaded the generator because I ran a table saw then a power saw to check out it's performance. The circuit breaker never tripped. The generator powered the tools but the load was well over it's capacity. Later I used it to power a PA System and the sound would go on and off. I then hooked up the generator to a Neon sign alone and it would flicker, never steady on.
To me the generator is useless in this condition.
I think the voltage is fluctuating because I fried something in the electrical generator? Can anyone help? I believe Coleman is Out of Business???
  • james2182 Jul 16, 2008
    I have the same problem with my 7.5 kw. I replaced 2 diodes and a capacitor, the flicking stopped but when the neutral and ground wires are connected the voltage drops 50%. Have you found any solutions?
    E-mail me at james2182@yahoo.com
  • Anonymous Feb 03, 2009
    I replaced the circuit board that regulates the voltage. It solved the problem. First check all connections and brushes. My generator was a 7.5 KW. There is a company called Pramac that stocks coleman parts.
    Problem Solver:
  • 10 Answers
Coleman generators are junk and are not broken in at all from the factory. The most likely problem is that your brushes are not making a good contact or they are worn down completely. The cause is that the slip rings on a Coleman are very rough. As long as your engine is run at 60-62 hz steady there is nothing else that will cause you this problem period! Unless when the wires where stuffed in the generator end" from the factory" they where stretched to tight and have come loose and/or rubbed again the rotor. I have seem this problem very few times, but it is a Colem quality. Don't go replacing the diodes and the capacitor. If a diode goes out it goes out. If a cap goes out it goes out. If either one goes out you have no output, very simple.
Posted on Feb 02, 2009
  • Bill Dickinson Oct 08, 2013
    how do i tell if is a diodes or a capactor on my colman 5K. system ran fine last fall, put in garage for storage and when I took it out for maintenance this fall, no pot
Grrr...! Okay, I had the 1400 for 2 years, loved
If you've only bought it 2 months ago it will still be under warranty.
Apr 22, 2010 | Epson Stylus 1400 InkJet Photo Printer
We bought new a few years ago .we started it once a month for a few months , never had to use it , now it does not send any voltage .
did you just start it or also set it to 1800 rpm sometimes at idle speed de gen does not go to work make also sure that the overloadprotectors are switched on can also be a button to reset earth failure.
Feb 09, 2010 | Coleman Powermate 7,000 Watt 13 Hp...
My standby generator is just cranking but wont turn all the way
If it was installed only five months ago, it should still be under warranty. Call Home Depot and have them send out a repair person.
Jul 01, 2009 | Generac 13,000 Watt / 13,000 Watt Home...
Coleman powermate 3750 watt brand new I started it
Check the oil level & try again to start many times until it became loose because the engine became stock up for long time not use.
Mar 12, 2009 | Coleman Powermate Powermate 5000W...
Coleman 6200 won't work
Hi Judy,
Generators DO last a good long time for the money, but they have to be both used and maintained in order to keep working properly. What has most likely happened is that you didn't use the generator at all for a year, after it sat on your dealers shelf for a few months not being used, and so the tiny bit of magnetism it uses to "kickstart" the process of making electricity has worn down. The good news is that this is easy for a generator shop to repair, no parts involved and the minimum labor that they charge. They need to do something called flashing the field of the generator. What they can't do is get Coleman to pay for it since they aren't around anymore, go ahead try the 800 number (waits patiently).
Be nice to the poor generator techs at the shop.
Nov 24, 2008 | Coleman Powermate Premium Plus 6250W...
Brand new Generator not working
first check push button breakers on generator. let me know, troy
Sep 26, 2008 | Coleman Powermate Premium Plus 6250W...
Coleman (100076) Compact Refrigerator Logo
1,120 people viewed this question
Top Coleman Home Experts
john h
Tom Chichester
Are you a Coleman Home Expert? Answer questions, earn points and help others
