Question about Kenmore 17024 Built-in Dishwasher
Dishwasher stuck in dry cycle
The lock picture is lit under the dry cycle and it want do nothing
  • 2kimpossible Jul 04, 2008
    i have the same problem.....hope you get an answer
  • AFparalegal Jul 08, 2008
    It must be the season.... Yesterday, my lockout button turned on too... Tried the reset button (held for more than 5 sec) several times, no luck. Turned off the circuit breaker, no luck either. Ironically, Monday we ordered a new dishwasher because we are remodling. It sounds like we need to call a repair show....
    I hope you all find an answer. Best of luck
SOURCE: My Kenmore dishwasher has the
I held the "Heated Dry" button down until the lock light went out. It may have been 10-15 seconds. All seems well now.
Posted on Dec 17, 2008
SOURCE: Dishwasher will not start
turn unit off at the breaker and leave off for 10 mins before turning back on,  if this does not reset the unit, then your control board is probably bad or the heating element could be going bad.  call a repair man for service
Posted on Oct 12, 2007
SOURCE: Frigadaire Dishwasher PADLOCK Icon lit, dishwasher won;t run
I have an FDB1502RGB0 model but had the same problem. I reset the circuit breaker and its working fine now. I'm not sure what caused the problem but it seems to be fine now.
Posted on Feb 11, 2009
  • 2187 Answers
SOURCE: Our Asko 1885 Dishwasher is stuck in drying mode
Check if the other functions of the dishwasher are OK such us when filling, draining or the heating element heats up properly. The control board may have detected some errors and it is not proceeding. You may have to have the parts involved in the faulty function checked out such as the valves for the drain and the fill if your machine is not filling or draining properly or filters blocked. Check the heating element and inspect the assembly for burns especially on the relays. The machine may not be heating correctly that is why it is not finishing the cycle. If these parts checks out OK, you may want to have the control board checked out or replaced.
Posted on Oct 09, 2009
SOURCE: dishwasher won't turn on, lock light comes on when I try to start
my husband found the solution on line when he googled the problem. He read that the drain could have been blocked, or it said press the drain button. That did the trick, and now I have clean dishes! He didn't have to pay anyone to solve the problem which was nice.
Posted on Dec 04, 2009
WDT790SAYMO dishwasher will not start. Appears locked. Help
Control Lock On
Use the Lock to prevent your dishwasher from accidentally being turned on. Use the Lock, also, to prevent accidental cycle or option changes during a cycle.
LOCK ON
When LOCK ON is lit, all buttons are disabled.
NOTES:
The dishwasher door can be opened while the controls are locked.
You can turn on the Lock while the dishwasher is running.
To turn on the Lock:
Press and hold NO HEAT DRY for 4 seconds. LOCK ON glows.
If you press any pad while your dishwasher is locked, the light flashes 3 times.
To turn off the Lock
Press and hold NO HEAT DRY for 4 seconds. The light turns off.
If the lock light flashes constantly this indicates that a key (or keys) is most likely shorted or stuck. If this is the case the console or touch pad must be replaced. The console is only available in black (part number 3384340).
Jul 31, 2017 | Televison & Video
How to program the safety lock on and off model 66517039402
From Page 15 of the complete owners manual available here:
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0409033.pdf
Lock On
Use the Lock On to prevent unintended use of the dishwasher.
You can also use the lock feature to prevent unintended cycle or
NOTE: The dishwasher door can be opened while the controls
are locked. However, the lock must be turned off and the Start/
Resume button pressed to resume the cycle.
To turn on the Lock
Press and hold HEATED DRY for 4 seconds. LOCK ON glows.
flashes 3 times.
Press and hold HEATED DRY for 4 seconds. The light turns off.
Sep 24, 2015 | Kenmore Dishwashers
Disherwasher will not start
Are you sure it is the Dry light that is lit, or is it the little Lock symbol located ABOVE the Dry button that is lit? If it's the latter, you can turn off that light (turn off the control lock) by pressing and holding the Dry light for 4 or 5 seconds until that light goes off.
Aug 04, 2014 | Frigidaire Dishwashers
GE GDWT160R dishwasher.
Some type of dirt or dust got in your panel, now the contacts don't touch. Not a diy job.
Jul 27, 2017 | GE GDWT160R Dishwasher
Heated dry cycle light on
see the cause and fix it:God bless you
Failure Code Condition Check/Repair "L" persists in washer display Lid lock failure Replace switch, linkage, lock solenoid or control board.
Jul 21, 2012 | Maytag Quiet Series 300pan Dish Rack...
Dishwasher will not work. heated dry and child lock lights are lit up. tried holding heated dry button for 3 seconds to turn off child lock nothing happens.
Try finding the electrical circuit that powers your dishwasher. Turn off the breaker for a while (15-30 min.) This may reset the computer to factory defaults.
Apr 29, 2011 | Haier ESD310 24 in. Dishwasher
I have a sears dishwasher, lock light is lit but
Press and hold the 'Heated Dry' button for 4 seconds then let go
Apr 24, 2010 | Kenmore Dishwashers
Dishwasher won't turn on, lock light comes on when I try to start
Dec 03, 2009 | Maytag 24 in. MDB8600AW Jetclean II...
Kenmore dishwasher ultra was quiet guard 3 model 56516012403 control panel will not activate red lights blinking on normal wash and cancel drain. did the hold the heat dry button then the normal wash...
that would be model # 66516012403 correct??
you may have inadvertently set the lock on function..
check this out from your manual...
Lock On
between cycles. You can also use the lock feature to prevent
unintended cycle or option changes during a cycle.
To turn on the Lock
flashes 3 times.
NOTE: If the Heated Dry option is selected, the light will
temporarily turn off until Lock On glows.
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Kenmore 15912 Built-in Dishwasher
Maytag Quiet Series 300 Will not work at all, only the lock feature is lit.
I had the same problem. The lock button light was on, nothing happened when pressing start, cancel, etc. I also tried holding the heated dry button (lock) for 3 seconds and no luck UNTIL holding down for three seconds while also pressing the cancel button. I was then able to start cycle as normal.
Apr 18, 2008 | Dishwashers
Kenmore 17024 Built-in Dishwasher Logo
310 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
