Question about Sanyo DVW-5000 DVD Player/VCR
DVD Wrong Region
I bought 2 DVD's, but can't play them because the display says 'Wrong Region. Can you help me to solve this problem?
  • Ponkie Jul 06, 2008
    The DVD I have is Sanyo HV-DX350
    Ponkie
  • dianecope Jan 10, 2009
    Hi, I have the same problem as Ponkie but the solutions given did not work. My player is Sanyo HV-DX350AB dvd/vcr combo which I need to make region free
  • 376 Answers
Turn on unit
Select DVD
Open tray
Press 0520 then in sequence press arrow up, down, left and right
Enter desired Region Code ( 0 for multi region)
Press Enter to exit
Posted on Sep 08, 2008
  • L Jefferson
    L Jefferson Sep 11, 2008
    the above one is for the 380.
    this one is for the sanyo model listed in description:
    1. Remove all disks from DVD.
    2. Turn off DVD.
    3. Press power in the remote control
    4. Wait untile the NO DISC message appears in the screen.
    5. Press PAUSE
    6. Press the following numbers, which is a 314159
    7. The message CODE 1 (or whatever your default region code is) will appear.
    8. Press the region code that you wish. Press 0 to read discs for any region.
    9. Press PAUSE again.
    10. In the remote control press POWER to turn it off.
    11. After this procedure, turn on the DVD and insert a DVD from any region.. it should work
I have just bought a Toshiba SD590EKB dvd player and it will not play certain discs, it keeps on saying wrong regional code. How can I solve this problem?
Check the back of the dvd player and it will have a small sticker with a small picture of a globe (or earth) and it will have a number being one through to six, this will determine what region discs you can play in you machine. Ill list the regions and their codes, i hope this helps.
Region 1 - The U.S., U.S. territories and Canada.
Region 2 - Europe*, Japan, Middle East, Egypt, South Africa, Greenland.
Region 3 - Taiwan, Korea, the Philippines, Indonesia, Hong Kong .
Region 4 - Mexico, South America, Central America, Australia, New Zealand, Pacific. Islands, Caribbean
Region 5 - Russia (former USSR), Eastern Europe, India, most of Africa, North Korea, Mongolia
Region 6 - China
Good luck.
Nov 25, 2009 | Televison & Video
Have dvd that say check regional code how do i do this ?
sounds like you have purchased the wrong region coded dvd`s when you bought them from amazon? if you are in the US you can only play Region 1, Europe is Region 2 and so on. Unless you purchase a mlti region machine which is obviously not what you want to do then the only other play of playing the wrong region discs is to buy a cheap dvd player which has "DivX" compatability which will play any region for you.
Sep 07, 2009 | Zenith DVT216 System
Changing of region code
I have the same system and I changed the region code to muti by pressing STOP 7344660 after opening the tray as per instruction I read in the net.. It worked.. on the TV screen it displayed region as 0
Aug 05, 2009 | Philips LX3600D System
DVD Player D1816 shows Wrong Regional Disc message
Many DVD players are preset to one region and if you use a DVD destined for any other region, the player will refuse to play. Some players have the option to change this to universal mode. Check your player's manual if yours has this facility.
Yes. You can play VCD movies and and Audio CDs on most players.
Mar 18, 2009 | GPX D1816 DVD Player
I bought a dvd player in the US but it wont play Most of my dvds
Hi do you have the model number? If you check videohelp.com you can find Multi Region unlocking codes.
Feb 09, 2009 | Insignia DVD Player with MP3 Playback/JPEG...
Wrong region
check with another dvd you know the region.
check same dvd on another (not region 2) player and see if itsn't working.
find if you have to follow special instruction to activate the "all region"feature.
find on line instructions do remove the region lock.
confirm make /model/ sn where you bought it and I can help to find instruction.
Jan 14, 2009 | Coby DVD-588
Won't play DVDs from asia .. need region code unlock.. help.
try with the disc tray closed. and if that doesn't work turn player off by plug socket and turn back on and start from the setup menu part of the unlock code after turning player back on.
Aug 22, 2008 | Jwin JD-VD135 DVD Player
DVD Rejion problem
1. Turn on the unit
2. Open the loading tray
3. Press the "Setup" button on the remote
4. Navigate to the "Preferences" page using the right arrow key
5. Enter 138931
6. You will now see the current region code displayed
7. Use the Up/Down arrow keys to select the region required or "0" for all regions
8. Press the "Play" button on the remote
Jul 07, 2008 | Yamaha DVR-S120 DVD Player
Philips 7" DVD portable player
The PET702 will be a region 5 machine, whereas the UK DVDs are region 2.
DVD players from a particular region are designed to play only DVDs from the same region, due to copyright and distribution rights in each country or region.
However the PET702 can have the region protection removed by making it multi-region:
Switch on the PET702 and Open the tray.
Press SETUP button on the remote control, which will bring up the menu.
Highlight "PREFERENCES" and press OK.
Press [2], [5], [2], [3], [1], [5], [LEFT], [DOWN]
The screen will show: "Region Code: 2"
Press [1-6] to manually set the region OR [0] for multi-region.
You will now be able to play DVDs from anywhere in the world.
This is particularly useful, because region 1 DVDs from the US often come out when the movies are still in the cinemas over here. Region 1 DVDs can be bought perfectly legally by mail order or from the internet.
May 07, 2008 | Televison & Video
Philip PET 702/98 Poratable
On remote push "Setup", use arrows to find out page "Preferences", enter 9653 and change region code to 0.
Mar 31, 2008 | Philips PET702 Portable DVD Player
Sanyo DVW-5000 DVD Player/VCR Logo
604 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
