Question about Car Audio & Video
JVC KD-G340 Power Problem
I just bought a new JVC receiver for my truck to replace the factory one that had stopped working.
When I hook up the yellow wire (unit is grounded, red wires connected), the unit will start up, buzz a second or two (::think CD ejecting sound::), then go off. Pushing the I/O doesn't do anything, but if I hit the eject button, the unit will try to eject, then go back off.
Any ideas?
  • bballgoof Aug 25, 2008
    I have the same exact promblem. If i press the display button or eject button it lights off but immediatley turns back off. I double checked the wires and everything. I matched the wires from my 2002 saturn sl1 and the jvc kd-g340 and it looks right. But it wont turn on.
  • htes7588 Aug 25, 2008
    Have everything wired right, CD player worked until I went to put it all back together, now it will take or eject a cd but will not power on fully. I didn't change anything but the speakers, what's wrong?
    Thanks, Seth
I had this same problem...you probably have the wires wrong. Double check your connections for the red and yellow wires from the headunit. Make sure that your red wire is going to a 12 volt source that only switches on with the ignition.
Posted on Jul 28, 2008
How set bass on kd g340
Do you have User manual? If not, it can be downloaded from jvc website: http://books.jvc.com/booklist.asp?Model=kd-g340. Refer to page 20. Press EQ, then use up/dn to select mode, then use right/left to select tone, then use vol to adjust.
Feb 14, 2015 | JVC Car Audio & Video
Why does my jvc kd-r526 reset to factory default everytime i turn it off
Try connecting the yellow wire to a constant power source. That is, a source that still has power when the key is turned off. The yellow wire controls the memory of the radio.
Jun 02, 2011 | JVC KD-R800 Car CD/ MP3 Player
Jvc kd-g340 rear speakers not working. I recently bought the car with this unit installed. I noticed that there is a l/r cable, power, ground in the trunk which means there was probably a subwoofer...
check the wires in the back of the stereo if not then make sure the back speakers are not hooked up to a internal amp and if it is make sure that it is not blown
Mar 31, 2010 | JVC KD-G340 Car CD/ MP3 Player
How do you set the clock on a jvc kd g340 cd player
you stop being lazy and open your manual or google seach or the pdf manual if you dont have it anymore like seriouslly man the time you spend finding this site and whining about a fake problem and waiting for a answer you could set 100 different clocks probally built your own.
Jan 15, 2010 | JVC KD-G340 Car CD/ MP3 Player
Need to wire JVC model KD-G340 into a 97 Kia Sephia
Do not cut the wires from the car. Instead, call Crutchfield at 888-955-6000 and order the adapter part number 120701003. When you call them, ask for color coding. For JVC, refer to the attached picture. Match the adapter color code with that of JVC. If the adapter color code is the same, then connect ground (black), battery (yellow), and wire from ignition switch (red) securely. Turn on the car and see the radio works. If it works, connect one by one speakers and confirm. Remember, perfect connection gives reliable installation.
Nov 22, 2009 | JVC KD-G340 Car CD/ MP3 Player
Try rewiring it. Yellow to a full time hot 12v and red to an ignition switched 12v
Feb 18, 2009 | JVC AM FM CD DET FACE CAR STEREO
New CD player. KD-AR390/KD-G340
Orange connect to illuminator for where blue is remote out meaning ur amplifier
Jun 17, 2008 | JVC AM FM CD DET FACE CAR STEREO
Car Audio & Video Logo
469 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
