Question about Canon PC-860 Black and White Copier
2nd side copying jams with multiple sheets of paper
1st side copies okay. Flip over to copy 2nd side and paper jams multiple sheets. Static electricity holding sheets together. How do I eliminate static?
Asa
Posted on Jul 04, 2008
Why does xerox work center 5020 copy only and yet the duplex is okay
Hi Wandekera,
I think you have a operator error problem. If the duplex is working then there is no mechnical problem have you got 2 sheets to copy then you should still have something on both sides of the paper.
Further investigation would be necessary.
Good Luck.
May 04, 2015 | Xerox Office Equipment & Supplies
Constantly jammed paper when print or copy multiple pages
check if the paper size not match with that sitting in printer sitting and the aplication you use
Dec 09, 2014 | Office Equipment & Supplies
I have an imagerunner 2800 and it only seems to jam in the tray loading area, just bends the long side of the paper randomly. It changes it's performance just like the weather, sometimes I can get multiple...
A couple of things to consider:
Do not load the following types of paper in the paper drawer. Doing so may cause a paper jam.
- Severely curled or wrinkled paper
- Heavyweight paper
- Transparencies
- Paper on which color images have been copied.
- Paper which has been copied on using a digital full color copier (do not copy on the reverse side
either).
- Paper which has been printed on using a thermal transfer printer (do not copy on the reverse side
either).
Also, what # paper are you using?
Oct 12, 2013 | Canon (6981A002AA) for imagerunner 2200,...
During multiple feeds, the 1st copy is okay, but on the next succeding copies, top margins spacing varies that will cause the bottom copies to be cut
Meikriezl Ulit:
Remove the paper tray and use a "Q-Tip" dipped in alcohol to clean the paper pickup roller and the double-feed prevention pad (below the paper pickup roller.
Feb 24, 2013 | Toshiba Office Equipment & Supplies
What does an adf jam mean? what do i have to do to fix that? dell photo 964
The ADF is the "automatic document feeder". It's at the top of the printer. It's where you place multiple sheets of paper on a tray to get fed into the copying part of the printer.
There is either a sheet of paper jammed in there or a piece of a paper stuck in there.
May 26, 2011 | Office Equipment & Supplies
MPC4000 jamming when copying double-sided color paper. Is there a fix?
1st question is does it jam on regular plain white paper dbl sided ? if yes it depends on where it jams and what the service jam code is, if no then how thick of color paper is it ( is it within the copier specs ? ). If the paper is within the specs you should set either the paper tray or bypass tray for the correct paper weight in user tools, because it does two things : 1 it slows down the copier speed and 2nd it increases the heat level.
Apr 14, 2010 | Ricoh 4506 Copier
Ricoh copy machine 3025 paper jams every time we try to print
Make sure the paper that is in the drawer matches the orientation and size indicated on thje Op Panel Display, If NOT, MAKE IT MATCH.
Mar 31, 2009 | Ricoh Aficio 3025P Black and White Copier
Samsung ML2010 paper feed
clean the rubber pickup with water or alcohol by cotton cloth and try again
Feb 26, 2009 | Samsung ML 2010 Laser Printer
Printer says paper jam and stops- but it is not jammed
your description indicates you need to thoroughly check printer for any bit of paper ........rolller too has to be checked so that paper is moving smoothly ......
Feb 02, 2009 | Brother MFC 420CN All-In-One InkJet...
Canon PC-860 Black and White Copier Logo
102 people viewed this question
old marine
old marine
