Olympus Stylus 760 Digital Camera Logo
A
Anonymous Posted on Dec 21, 2010
Both of my instruction books are in a foreign language. I need to know how to download images to my computer
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Olympus Master 102,366 Answers
  • Posted on Dec 22, 2010
Olympus Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10428322
Points
622693
You can download the English-language manual from
http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=1286
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
How and why did my hp 4plus change from english language on the display to a foreign language?
Some times things just happen, click on start ,printer and devices , right click on printer image, click on trouble shooter and follow instructions, if the worst happens a uninstall and reinstall should fix it.
1helpful
COULD YOU PLEASE PROVIDE ENGLISH OPERATING INSTRUCTIONS FOR THIS UNIT
You need to identify what "unit" you are referring to. That usually means identifying the manufacturer/brand and model number. By Googling that information, you might find a manual on the manufacturers website or a manual available from one of the manual depository websites. Some are free, some are not. If the manufacturer's site is in a foreign language, try the translation features of Google. Yes, Google can usually supply a pretty fair translation of foreign sites. However, you are likely chasing the wind if you try to translate an entire operations manual using such. The manuals are usually PDF documents with images and that poses a challenge for translation software. If you are referring to having an operating systems which is putting text up on your screen in a foreign language, that is an entirely different question.
Iam logged into face book but my language has changed from english to a foreign language
On the middle right top of your facebook page there is a small triangle please click on it and you will see menu then click on settings the fourth from down .click General on the right than you will see option language on the left .change it to English and enjoy. Regards
Language set up
Push the Menu button. Scroll to the Setup menu. Language on that menu. Unfortunately the menus and everything else will be it the foreign language until you reset it. If you have trouble and can't figure out or find someone who knows the language your camera is set to, contact the Foreign Language Department at your local college or university.
2answers
Negative and bad effect of foreign business relationship
- Lack of Nationalism - Jobs leaving Country - Taxes and Tarrifs - International Tensions - Foreign Wars - Currency Fluctuations
I just got my phones home and the instruction book is in foreign language so have no clue how to put together. I drove 30 miles to get it.
Since you declined to specify the model of your Uniden DECT 6.0 phone I can only suggest that you select it from the list beginning here to download a copy of the manual.
1helpful
Instruction book for a micro cd shelf system
not solved - but not going to pay for an instruction book when it should be a 'downloadable' item by sharper image
1helpful
Would like to change Language settings for Epson Stylus Photo R290 Series Printer... Currently when printing a Test and when I go to the Print Preference, its showing as a foreign language... How can...
1. First of all, you must completely uninstall your current driver (with foreign language).
2. Download Epson R290 English Language Driver from here :
http://www.epson.com.sg/epson/drivers/driver_download.htm?dc=1&mode=3&mfalse&catid=1&pid=1259
3. Unplug your printer USB Cable from your PC
4. Run : Setup.exe
5. Follow the instruction, and thats it. You've English Language now :)
I have tried this and it worked :)
INSTRUCTION BOOK
I was able to download the manual from www.vivitar.com
From their homepage
Select: Support
Select: Vicam 8400 Under "vivicam cameras"
Then another pull down menu shows up asking for the language you want.
Select your language, then click "Go"
Select: Manual (it's a number 1)
Look for a pop-up window asking you to save it or open it. I recommend saving it to your desktop. The manual is in PDF. Do you have PDF?
By the way it took me a couple tries to get it download.
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
