Question about Belkin (F5D7230-4) Router (587009)
Wireless My Belkin G wireless router just stopped working. I checked the power cord and all the wires but it won't light up or do anything at all. Is it just dead or is there something I can do????
    Scholar:
  • 174 Answers
Change the power adapter and see ist working otherwise buy a new one
Posted on Jul 15, 2008
Wireless router will not power up?
Capacitors in the power supply have gone bad. Might be time for a new router.
Mar 06, 2016 | Belkin Connect N150 Wireless N Router
Belkinfsd7234-4v1 g wireless router stopped working for no reason. No lights on - any ideas?
Belkin uses a 9-12volt backward compatible power plug. Check make sure you did not grab the wrong power cord if not it could have just popped the power board inside replace the router. Walmart has the Netgear wireless N for around $38
Sep 23, 2011 | Computers & Internet
My Belkin F5D8236-4 v3 Router won't turn on. We had a storm last night and the power went out but the router won't turn on. I have tried to plug it into different outlets to see if that would work...
Try resetting the router. There should be a little hole somewhere on it with a button inside that you can press with a paperclip. Try holding that button down while you unplug then plug the router in while holding it (if possible). If that doesn't work, I'd suspect the storm might've damaged the router somehow. Was it plugged into a surge protector, and/or have you noticed any other issues with anything else that was turned on at the time?
Jun 16, 2011 | Belkin F5D8236-4 Router
I need my wep/wpa pass phrase
just configure again your router.
Step 1 : Connect modem - Router - Computer ( Wired )
Step 2 : Open router setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left side under internet WAN click Connection Type
Step 4 : leave the Password Blank and click submit
Step 5 : Choose the connection type as dynamic and click next
Step 6 : Leave the Host name blank and click apply
Step 7 : On the left Under Internet WAN Click MAC Address
Step 8 : Click Clone and Click Apply changes
Step 9 : If the Internet status on the top right is connected
Step 10 : Then check if you have internet
Step 11 : if not Then unplug the Power Cable from the Modem And the Router
Step 12 : Plug the power Cord to the Modem
Step 13 : Wait till all the lights are on
Step 14 : Plug the power to the belkin
Step 15 : Check the color of the light in the belkin
Step 16 :If green then Check if you have internet
If not working then call belkin
======= WIRELESS SETTING UP A WIRELESS CONNECTION ================
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Oct 10, 2010 | Belkin (F5D8231-4) Wireless Router...
How to connect Belkin N N 300 Router to Cox Cable Modem step by step instructions. Cox just installed a new modem since the old one "went bad" and was giving a wrong "number". Was working fine before and...
================================================WIRELESS SETTING UP A WIRELESS CONNECTION
Aug 30, 2010 | Belkin Wireless Play Router (F7D4302)
I just bought a Belkin Router Model # F5D8236-4. I have everything wired correctly, but the wireless light does not come on. I can't get the internet to come on to the computer I want to connect to? What...
Wireless light will lit up only if any wireless computer is connected to Belkin's wireless network.
First, connect to Belkin's wireless network that you can scan.
After you connect, try to go online
It ll work...
Jan 21, 2010 | Belkin (F5D8231-4) Wireless Router...
The ''wireless'' light on my wireless router is flashing amber
Contact Belkin for Care at 1-800-585-2494 Toll Free,,
Jan 09, 2010 | Belkin F5D8236-4 Router
Modem router light blinking (no wireless connection) F5D8631-4
Try restoring the Belkin back to the factory default by powering up the Belkin and pressing the RESET button on the back of the Belkin for 7 secs. Then connect a LAN cable from the computer to the Belkin, open IE browser and type the configuration IP address and configure the wireless settings ie. SSID, encryption etc. The computer wireless cards will need to be configured with the Belkin wireless settings to allow them to communicate with the Belkin.
Nov 12, 2009 | Belkin F5D8631-4 Router (F5D8631au4A)
Belkin G Wireless Router Not funciontoning: Power Light is Off
Its dead Jim.
I had one of those. Dead.
You can try hitting the reset button. Looking at the back there should be a small hole with a tiny button. Use a staightened paper clip or other object to hold it in for at least 30 seconds. That should set it back to factory defaults.
Doing that brought mine back to life momentarily , but it kept going out after a couple of hours and I had to repeat the process until it finally gave up the ghost for good.
Mar 04, 2009 | Belkin F5D7630uk4A Wireless Router
I unplugged the cable connected to my desktop and the wireless function stopped working
You must always have a 'host' adaptor whether you want a LAN or a WAN. Go to your configuration utility or control panel via your Run command to set or view your options. Steve Medley
Nov 07, 2008 | Belkin (F5D8231-4) Wireless Router...
Belkin (F5D7230-4) Router (587009) Logo
35 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
