Question about Char-Broil CharBroil 4637318 Grill
Char-Broil TEC Infrared Grill the nozzle is sputtering out the flame and is not getting the plate hot enough
  • 2 more comments
  • car75 Aug 11, 2008
    Infrared grill just sputters no heat
  • Anonymous Aug 25, 2008
    The infrared burner ignites then goes out - then a large amount of unlit gas ignites with a big WHOOSH. This cycle repeats, producing no heat, until I turn it off. I have cleaned the gas lines etc. No solution as yet.
  • Anonymous Apr 27, 2009
    Same, design porblem. need to replace tec burners.
  • jmccolgin May 23, 2009
    One of the burners makes a loud popping noise, then gurgles shortly after it lights... does not get hot.
Buy a Solaore grill.
Posted on Jul 07, 2008
What do we do about the sputtering tec gas line and no heat on tec burner
Posted on Feb 23, 2009
I need the assembly manual for a char-broil LP Gas Grill model # 4638975. Much appreciated!
The model number you listed 4638975, does not match any current Char-Broil models.
Please check again, confirm and let me know the correct model number.
Thanks for choosing FixYa.
Sep 20, 2011 | Char-Broil CharBroil Master Flame Gas...
I have a Char-Broil Tec grill everything works fine but after about 2 minutes into grilling, a loud popping sound and the tec-radiant burner goes out, this happens everytime I use the radiant burners
The radient burner most likely has a crack in the top. This will make the pop and the burner will go out. Inspect the top of the burner for any cracks, if you find one, the only solution is to replace the burner. Since these burners get very hot, I do not recommend having the grill lid closed when these burners are being used, this can cause them to overheat and crack the top surface.
Jul 03, 2011 | Tec RadiantWave Grill
My Char broil grill doesn't heat up enough, the flame is not as high as it used to be. Any ideas? thank you
try opening the tank really slowly. if you open it too fast the overfill protection devise inside the tank will restrict the gas flow. hope this helps.
Oct 06, 2009 | Char-Broil Grilling
My Char Broil gas grills flame is taller than it should be( not blue at all anymore) and make the food smokey?
You need to clean the burners/pathways, its not getting enough oxygen and the flame is starved.
Sep 05, 2009 | Char-Broil CharBroil Master Flame Gas...
Burners cleaned, propane doesnt want to make flames hot enough to heat grill
after you turn on the tank let it sit2/3 mins.before you lite it this gives the regulator time to adjust propper...thumbs up
VE6GAR73 88 99
Aug 10, 2009 | Char-Broil 463232103 Grill
New Char Broil gas grill heating issue
Did the kit come with NG orifices and did you use them.
Jun 23, 2009 | Grilling
Flames only come out very low on both sides
disconnect tank, hook tank back up, then open valve slowly. When opened to fast it thinks valve is leaking and shuts down.
Jun 11, 2009 | Char-Broil CharBroil Master Flame Gas...
Keeping Consitant Heat
After looking at this you need to purchase either cermic briquettes or plates. Make sure you buy enough to cover the lower grate completly.
Thanks
Zerko
Aug 26, 2008 | Char-Broil Santa Fe - 491 Grill
Low gas flame
Also read the manual, You must open the LP tank valve very slow, the new tanks have funny safety design, I had low flame on the 2nd use w/full tank and was puzzled because it was high flame on the night before.
Rizzo
Jul 01, 2008 | Grilling
Char-Broil CharBroil 4637318 Grill Logo
882 people viewed this question
Top Char-Broil Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dean Gruber
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
