Question about Belkin Wireless G (F5D7130) (F5D7130FR) 802.11b/g Wireless Access Point
Connection i'm having problem re configuring my router i can't access my routers configuration setting and the set up assistant wasn't abale to connect to the router or se
  • 4 Answers
The setup page to configure Belkin routers is at http://192.168.2.1
If you have changed it, reset the modem to factory defaults by using a paper clip in the small reset hole.
Posted on Sep 16, 2008
I want to change the channel my Linksys is using. So I went to Internet Browser and typed in my IP address. It said I need a Username and Password. Where would I find that.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi Then save settings and restart router Then connect cable from internet service provider to WAN port of router and connect ethenet lan cable from computer to lan port of router. . If you are not able to access router with above user and password then yo need to reset it. For that press RESET button for 10 seconds it is in back side of router.Then configure it again with above method.
Let me know if you need further assistance. Thanks for using FixYa.
Dec 05, 2010 | Linksys Wireless-G WRT54G Router
ITS NOT CONFIGURED WHILE SETUP MANUALY.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi Then save settings and restart router Then connect cable from internet service provider to WAN port of router and connect ethenet lan cable from computer to lan port of router. . Let me know if you need further assistance. Thanks for using FixYa.
Dec 04, 2010 | Belkin (F5D7633UK4A) Wireless Router
What settings should i configure for networking?
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi .Enable DHCP in router. If you want to create network with router then connect ethernet cable from computer to router or put switch between router and computer. Then set tcp- ip property of lan to ip get automatic so it will get ip from router. Then o Let me know if you need further assistance. Thanks for using FixYa.
Oct 12, 2010 | Computers & Internet
I have no internet connection with the router but can surf without the router and only my modem
You need to configure your router WAN settings as your internet service provider.
If your ISP gives you static ip then configure it as static.
If ISP gives user name and password to connect inteernet then configure router as pppoe.
http://192.168.0.1
or
http://192.168.1.1
Click on wireless settings enable wireless then WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.If you are able to see password in * or # then you need o add new password but if you are able to read it then note down it then you can connect with it.
If you are not able to access router with above ip and user password then press RESET button for 10 seconds it is in back side of router.
Then you can access it with above method.
Jun 13, 2010 | NetGear WGR614 Wireless Router
How configurate this router? I lost the CD with configuration. Please ask me. Mabey in Polish language?:)
http://192.168.0.1
or
http://192.168.1.1
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
When you connect vpn router to wireless router set in wi fi lan property as your vpn network range set vpn router ip as gateway ip of wireless router.Then save settings and restart it.
May 20, 2010 | NetGear WGR614 Wireless Router
I have a Netgear router model 834G purchased in the UK. Will it connect to the french telephone network on ADSL without any problems?
yes you can use it with it.Just you need to configure your router as your french telephone ADSL settings.
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
Apr 23, 2010 | NetGear DG834G Router
Configure the modem without cd installer
http://192.168.0.1
or
http://192.168.1.1
Apr 22, 2010 | Encore 802.11G WIRELESS LAN ROUTER...
What is the pin of belkin G wireless router?
First connect your router to computer with ethernet cable.
Then you can access it with default link.
http://192.168.2.1
Type user as "admin" and password as "admin" or blank or "password" or 1234 then you can se configuration page of router go to wireless settings and enable WEP security add new code so you can connect with that code.
If you want to configure it you can do it with below method.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router.
Save settings and restart router
Then connect internet service provider cable to router .Then you can use it wireless.
Mar 30, 2010 | Belkin (F5D7230-4) Router (587009)
If i revert back to my factory settings on my netopia router, will this impact my at&t settings? i'm just trying to let someone use our wireless access and have misplaced the login info
Yes if you reset all settings to factory defaults.All settings will be lost so you need to configure your router again.
You can access it and configure with following method.
http://192.168.0.1
or
http://192.168.1.1
IF you are not able to access it with above ip then you need to reset it for access .Press RESET button for 10 seconds it is in back side of router then all settings are default.
Mar 16, 2010 | AT&T Computers & Internet
I want to hook up my laptop wireless with the Actiontec GT704WG how do I do this- it is my only comouter
To connect to your wireless router, it needs the router’s wireless settings configured and also needs the wireless cards in all the laptops and or computers to be configured with the router’s wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
To access the Internet you need to connect the DSL or cable modem to the WAN (Internet) port on the wireless router.
Nov 26, 2009 | Actiontec GT704WG Wireless Router...
Belkin Wireless G (F5D7130) (F5D7130FR) 802.11b/g Wireless Access Point Logo
165 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
