Question about BEL 950 Radar Detector
No sound, voice or beeps
My bel 950 has been in service for about 9 years. It now has lost sound. No voice or beeping. I pressed the city button to reset to factory settings and still no sound. Ummmmm, joeromack@verizon.net
  • Anonymous Apr 09, 2009
    my speaker sopped working. i opened it up and the connection appears ok.
  • 405 Answers
Good Day Joe,
Sounds to me like the internal speaker went, this is actually common on radar detectors. Although 9yrs is a lot longer than most will last. If you are handy with a soldering gun you can replace the internal speaker with a new one and get it working again. However be sure to take the unit apart before getting a new speaker so you can match up the size as it varies.
Good Luck and I hope thi shelps
Posted on Jul 04, 2008
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
How do i reset the sid display in 2008saab93turbo after replacing battery
pressing the CLEAR button for 8 seconds. on older 9-5 and 9-3 SID's, that you must press CLEAR once & release, then press CLEAR a second time, and hold for 8 seconds. While holding down CLEAR for this second time period, at the 4 second mark "CLEARED" will be displayed, and you will hear 1 beep. If you release the CLEAR button at this point, the DTE and MPG will be cleared out. If you continue holding the CLEAR button past the 4 and 8 second marks, you will hear a 2nd beep, and "SERVICE" will be displayed. This now means that you have cleared and reset the Time For Service message.
Dec 01, 2014 | 2008 Saab 9-3
Nuvi 2555mt lost voice
First, do you hear beeps when you press a selection on the screen? If yes, then your speaker is OK and the audio circuits are OK in the unit. Make sure that you have a voice selected in the voice menu. Some units have an audio mixer screen and provide different volume settings for navigation (voice) and system (beeps). maybe the volume for the voice (navigation) is set to off. If you don't hear any beeps when you touch the screen AND you don't hear a voice, make sure that the sound isn't set to be muted. If the sound isn't muted, you may have a defective speaker. More information on audio issues can be found here:
SHARCNET USA Out of Warranty GPS Digital Camera Repair
Apr 18, 2014 | Garmin nuvi 260W GPS Receiver
Lost audio
1. First, make sure that the sound is not checked to be muted.
2. Make sure that you have a text-to-speech (TTS) voice selected in the language menu.
3. When you press a function on the screen, do you hear a beep? If so, this indicates that the sound is not muted and that the audio circuits are working. If you don't hear any beeps when pressing a function on the screen AND there are no voice directions, then I would suspect a defective speaker. More information can be found here:
Mar 24, 2014 | Garmin nuvi 255W GPS Receiver
How to set the date
Time and date setting
are only necessary if automatic setting by radio broadcast is unsuccessful.
To set time, date, and options:
1) With time and day showing, press and hold SET.
2) City code flashes. Press START/STOP to select city that represents your time zone. See table below
for city codes.
3) Press MODE. DST (daylight savings time) setting flashes. Press START/STOP to select AUTO (obey
setting in radio signal), ON, or OFF (disregarding setting in radio signal for ON/OFF).
4) Press MODE. Hour flashes. Press START/STOP to change hour (including AM/PM); hold button to
scan values
5) Press MODE. Minutes flash. Press START/STOP to change minutes
6) Press MODE. Seconds flash. Press START/STOP to set seconds to zero.
7) Press MODE. Year flashes. Press START/STOP to change year.
8) Press MODE. Month flashes. Press START/STOP to change month.
9) Press MODE. Day flashes. Press START/STOP to change day.
10) Press MODE. Date flashes. Press START/STOP to select M-D (month-day) or D-M (day-month) format.
11) Press MODE. Hourly chime setting flashes. Press START/STOP to select ON/OFF. When ON is
selected, watch chimes on every hour.
12) Press MODE. Button beep setting flashes. Press START/STOP to select ON/OFF. When ON is
selected, watch beeps for every button press.
13) Press SET, at any step, when done setting.
Press and hold MODE to switch between 12- and 24-hour time format.
Press SET to view date. Year is at top of display and date is below.
Press RECEIVE to view current city.
Press and hold RECEIVE to begin manual reception of time signal, as described in ATOMIC CLOCK
SYNCHRONIZATION section.
(from the User's manual)
May 03, 2011 | Timex 1440 Prizefighter 53032 Sports...
Please send me a simple way to set the clokc to the current time. It is an hour behind. Also how to play the radio and sleep sounds. I lost the manual and I am not electrocially inclined. So please make...
Hello
To set time manually do the following.
1. To change your time setting, press and hold the J Time Set Button so that the clock display begins flashing.
2. While the display flashes, press the 1 Reverse and 6 Forward Buttons to set the time. Hold a button for a few
seconds to set the time rapidly. Be sure to set the correct AM/PM time, shown by the PM Indicator.
3. After setting the time, press the 4 Enter Button or wait about ten seconds for the clock to beep twice and the setting
to lock into place.
4. To change the calendar, press and hold the 9 Date/7-5-2 Button until the display shows the flashing year.
5. Press the 1 Reverse and 6 Forward Buttons to set the current year. When you have selected the year, press the
4 Enter Button, then use the 1 Reverse and 6 Forward Buttons to set the month/day.
6. After you have set the date, press the 4 Enter Button or wait for the display to beep twice and lock into place.
AUTO TIME SET ZONES
Z-01 Atlantic Standard Time
Z-02 Eastern Standard Time
Z-03 Central Standard Time
Z-04 Mountain Standard Time
Z-05 Pacific Standard Time
Z-06 Alaskan Standard Time
Z-07 Hawaiian Standard Time
3. Find your time zone, then press the 4 Enter Button or wait about ten seconds for the clock to beep twice and the
setting to lock into place.
Apr 04, 2011 | Timex (T307S) Clock Radio
How do you turn off the POP ALERT on cobra 878? I turned it on and now it is annoying me becuase it goes off constantly... Does anyone have manual or suggestion on how to turn off? Please Help
Press and hold Dim and City buttons for four seconds
Voice Response with say, "Pop On" or "Pop Off" Tone Response will be, Pop On = Two Beeps, Pop Off = One Beep
You can find the full manual here:
http://www.manualnguide.com/manual/cobra-xrs-878-manual/
Sep 11, 2010 | XRS 9440 Radar Detector
How do you get rid of the beeping noise when you dial on a Toshiba Business Phone - Model #DKT3210-SD?
Dial Pad and Button Beeps
Digital telephones can emit a “beep” sound whenever a dial pad or feature button is pressed. The “beeps” are On by default. Follow these steps to turn the “beeps” On or Off on 3000-series DKTs.
1. Press 3+6+9+Hold(simultaneously).
2. Press 0.
3. Press Feature Button 1 (FB1) to toggle On/Off.
FB1, LED On: buttons beep.
FB1, LED Off: buttons do not beep.
4. Press hold to set the option.
5. You must also go off-hook, then on-hook to exit the program mode.
Mar 03, 2010 | Toshiba DKT 3010 Corded Phone
Voice mail message waiting light does not light
Press down the "find handset" button until the paging beep stops (about 5 seconds) and this will reset the indicator lights on the handsets.
Sep 20, 2008 | Uniden TRU8865-2 Expandable System...
Nokia N72
to record voice memos, press the menu button, and select OFFICE->RECORDER. To record a conversation, choose RECORDER during a voice call. Both parties will hear a beep every 5 seconds while call is being recorded.
May 16, 2008 | Nokia N72 Cellular Phone
How may I set the vg 2 on my express 795?
Entering Selectable Features Mode
1. With the unit OFF, press and hold the CITY button then press
the PWR/VOL button. The amber X LED will illuminate and a short
“beep” will sound.
2. Immediately after the “beep”, digit #1 will appear and indicate
the status of the sws™ Selectable Feature. To select digit #2 (VG-2
Guard®), press the CITY button again. To select digit #3 (sws™
Voice), press the CITY button a third time and to select digit #4
(Digital Voice prompts for Radar/Laser/VG-2 Guard®) press the
CITY button once again. Use the CITY button to select one of the
four digits.
3. If the selected digit is solid, feature is ON, but may be canceled
by pressing the AUDIO button. Two “beeps” and the flashing digit
will confirm feature is OFF.
4. If the selected digit is flashing, the feature is OFF, but may be
activated by pressing the AUDIO button. A single “beep” and
solid illumination will confirm the feature is ON.
5. Press the PWR/VOL button to retain your new settings for Selectable
Features. Two “beeps” will confirm that you have exited from
Selectable Features Mode and your unit will be ON.
Dec 09, 2007 | Express 795 Radar Detector
BEL 950 Radar Detector Logo
358 people viewed this question
Top Beltronics Vehicle Parts & Accessories Experts
John Nolan
Steve
Jerry Greenberg
Jerry Greenberg
Are you a Beltronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
