Question about Philips Magnavox 9P6034C 60" Rear Projection Television
No color adjustment
I have a 60 inch philips magnavox rear projection tv that I cannot adjust the color or the convergence from the front panel can I adjust it from inside. what do I need to do to correcty this.
  • 1 more comment
  • jhereford Apr 09, 2009
    so can i just take the back off and set it? I can not adjust the color from the front.it is a 42 " RCA tube big SCREEN TV
  • Anonymous May 03, 2009
    i have a phillips 60" tv and i have convergence i cannot adjust it with the remote any tips how to do mechanically
  • john Mar 27, 2014
    http://www.electronresort.com/hitachi-c-...
    Filmmaker:
    Uploaded 5 video answers.
  • 162 Answers
Problem with Hitachi 51F500 51 in. Rear Projection HDTV-Ready Television
i want to learn how to do convergence on my tv its a hitachi rear projection i have problums with colors not aligning,could you lead me in the right direction ps: i don't have the remote so i
can't magic focus
Posted by avatar13.jpgejaparks on Mar 03, 2011
AdChoicesMajor Appliance Repair
www.graysoncollinapplianceandac.comResidential/ Commercial, all brands Friendly, knowledgable technicians!
Get $75 of Advertising
www.Google.com/AdWordsPromote Your Business On Google. Claim Your $75 Coupon Now!
Solutions (1)
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Posted on Mar 09, 2012
Thanks for the info but I had to go into the back of the set and adjust the color until it was set correcly after that was done there was no need to set the convergence it works perfectly.
Posted on Jul 05, 2008
    Problem Solver:
  • 9 Answers
*CONVERGENCE SERVICE MODE PROCEDURES*
*Note: This procedure is required for all of the following geometry and
convergence adjustments.*
*Using the remote transmitter, enter the following seven-button sequence to
activate the convergence mode.*
* 06 - 25 - 97 - Menu (M)*
*The "Opening Menu" will appear offering choices:*
*Channel 3*
*Use Channel up/down to*
*Select a Channel with Video*
* Remote control key functions:*
* Use arrow up/down and left/right: Adjust Convergence*
* M: Advance "cross" location*
* Up, Down, Left, Right*
* 3: Exit Convergence*
* Status: Abort/Cancel Changes*
* M: Begin Convergence*
*Note: video information must be present to correctly adjust the
convergence. A signal source is required to lock the vertical and
horizontal sync. After entering the "convergence service mode" verify the
presence of a video source by confirming the presence of active audio (use
the volume up function on the remote). Use the channel up and down function
on the remote to select the desired tuning source.*
*Select item "M" from the first menu, the "Convergence Menu" will appear
featuring 5 possible selections.*
* Channel 3*
* Convergence:*
*1. green geometry*
*2. red To green Convergence*
*3. blue To green Convergence*
*4. green To red Convergence*
*5. green To blue Convergence*
*CONVERGENCE TOUCH UP PROCEDURE*
*1. Enter the "convergence service mode" as described above in the
"convergence service mode procedure".*
*2. Select the desired color requiring adjustment. Note: Do not
select Green Geometry (1). This procedure is described under "Major
Convergence/Geometry Alignment. If Green Geometry is altered during this
procedure a "Major Convergence/Geometry Alignment" maybe required. *
*3. Cover the Output Lens of the single color presently NOT being
adjusted. Example: If you select Green to Red Convergence (4) cover the Blue
Output Lens.*
*4. The highlighted adjustment Icon (Cross) should be illuminated on
the middle left side of the screen. Make the necessary Convergence
Adjustments using the following Remote Keys:*
*· Use the Arrow Up ( ) to adjust the selected color up.*
*· Use the Arrow Down Key ( ) to adjust the selected color down.*
*· Use the Arrow Right Key (-) to adjust the selected color to the
right.*
*· Use the Arrow Left Key (+) to adjust the selected color to the
left.*
*5. Move to the next location to be converged. It is not required
that the full Convergence Sequence be followed while performing the
"Convergence Touch Up Alignment Procedure". The following alternate Remote
Keys allow for positioning of the Icon to the desired adjustment location:*
*· Key 2 on the Remote Transmitter will position the Adjustment
Icon upward on the screen.*
*· Key 8 on the Remote Transmitter will position the Adjustment
Icon downward on the screen. *
*· Key 4 on the Remote Transmitter will move the Adjustment Icon
to the Left.*
*· Key 6 on the Remote Transmitter will move the Adjustment Icon
to the Right.*
*6. Return to the "Convergence Service Menu" by selecting Key number
3 on the remote transmitter or by sequencing the Icon to the last adjustment
point at the lower right corner of the screen and pushing the Menu (M) Key
on the Remote Transmitter..*
*7. Repeat steps 1 through 6 for other required Convergence
Alignments.*
*8. To Save the Adjustment completed in the last procedure,
Exit/Save the Convergence Service Mode by selecting Key 1 on the Remote
Transmitter. This forces the corrections to be written to the EEPROM on the
Convergence Module.*
*Note: To save the convergence corrections made above you must exit the
convergence menu by selecting Exit/Save Data (1)*
I have a 46" magnavox projection screen tv that has the red, blue, green colors on the left side of the screen when first turned on. After a few minutes of being on, the screen resumes to normal colors. ...
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
You can get a repair kit with parts and instructions from www.TvRepairKits.com
Sep 23, 2010 | Philips 60PP9352 60" Rear Projection...
My Philips magnavox 64 inch big screen tv has a green tint to it and i cant adjust with any of the color or tint options..
have the glycol ethelyne changed in your color guns, couple hundred bucks. i tried it myself and ruined my tv
Mar 27, 2010 | Philips Magnavox 9P6034C 60" Rear...
Bad color; everyone and everything is very orange
contact the store you bought it from. They will help you or refund you
Mar 07, 2010 | Philips Magnavox 9P6034C 60" Rear...
I have A 60 philips projection tv with triple picture
Don't adjust anything from the rear of the set unless you are a TV repair tech. It can get ugly real quick.
Try adjusting the convergence using your remote...Pull up the settings menu - goto picture - convergence - etc....See if you can adjust the color alignment back to normal. If not your convergence chips are most likely going out.
Nov 10, 2008 | Philips Magnavox 9P6034C 60" Rear...
Magnavox 60 inch TV
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 12, 2008 | Philips 60P8241 60" Rear Projection...
Picture is to light
Hello nita-1991,
Go to the Philips site http://www.philips.com and get the users manual. them get the remote for your TV from:
http://www.magnavoxremotes.com/
I hope this helps
Shuttle83
Jul 05, 2008 | Philips Magnavox 9P6034C 60" Rear...
No color adjustment or convergence
You need to replace both convergence ICs they are both STK3920110 Ics you may also need a couple of the 6.8 ohm 1/2 watt resistors as that chassis will usually open a couple of the 6.8 resistors. you can get repalcement ICs and resistors at the following link.
http://servicemanuals.vstore.ca/
Jul 04, 2008 | Philips Magnavox 9P6034C 60" Rear...
60 inch phillips magnavox projection tv
CRT coolant change and advanced convergence - how to
I documented the procedure I did on a Philips 55" rear projection 55p916
http://tinyurl.com/lmp6eu
CRT coolant change procedure
http://tinyurl.com/l7bd7r
basic and advanced convergence
Dec 24, 2007 | Philips Magnavox 51MP392H Rear Projection...
Tune up tv
sounds like convergence problems.
Dec 24, 2007 | Philips Magnavox 9P6034C 60" Rear...
Convergance adjustment
convergance amp ic bad
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 15, 2007 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
1,148 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
