Question about Acer Aspire 5050-3242 Notebook
Error on start up
When starting up i get a dark screen and message saying SMART Failure. Replace hard drive as soon as you can. Just started to show up past couple of days.
    Sergeant:
    Champion:
  • 244 Answers
Yes, it's your harddrive is bad (SMART, it could be defective sector too).
You should start to backup your data and replace harddrive.
Posted on Jul 04, 2008
1720-smart hard drive detects imminent failure.
i have the same problem. put a new HDD and still shows the same message.
Jul 06, 2012 | Compaq Computers & Internet
SMART FAILURE PREDICTED ON HARD DISK 2 TOSHIBA MK2035GSS (S1) PRESS F1 TO CONTINUE. ON START UP COMPUTER GOES TO THIS SCREEN EVERY OPTION ON START UP OF F1 DOES NOT START WINDOWS AND COMPUTER RETURNS TO...
Unfortunately it sounds like Your hard drive has gone bad. If this is the Hard Drive that contains your operating system you would have to replace Hard Drive and then replace Operating system using your Restore cd's.
Jul 11, 2011 | Computers & Internet
Black Screen On Start-up with the eroor message how to repair a black screen with error message SMARt failure predicted on Hard Disk 0 on a inspiron mini 10
this type of error message can be a caused by a few things it could mean that your hard disk is about to fail/crash you should check
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error also
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input will damage your computer
hope this helps
don
Feb 28, 2011 | Computers & Internet
Hard disk error
Unfortunately this error occurs with a fault hard drive. You will need to replace the hard drive and then reinstall the OS.
Mar 20, 2009 | Hitachi (AU-160GBSATAHDHIT) 160 GB SATA...
When i boot up i get a message that my hard disk failure is immenent is there anyway to repair this problem
if you get a "Disk Controller Error" error messages that may occur before Windows XP or Windows 2000 is started. Imminent Hard Disk Failure This error may appear when the hard drive detects that it will fail or stop working sometime soon.
Backup Data Before Proceeding Although the notebook may continue to start Windows after displaying the message, it is advisable that you immediately backup your personal data from the PC by copying it to a Network Drive, CD, DVD or USB storage device. After completing the backup, use one of the following methods to resolve the error. Step 1: Test the Hard Drive Use the steps below to test the hard drive in a Notebook PC using the HP Hard Drive Self Test.
  1. Plug the AC Adapter into the Notebook PC.
  2. Press and hold the Power button for 5 Seconds to turn off the PC.
  3. Press and hold the F10 key while you press the Power button to turn on the PC. Release the F10 key after text is displayed on the screen of the PC.
  4. After the BIOS Setup Utility is displayed, use the Right Arrow key to select the Tools menu.
  5. Select Hard Drive Self Test
  6. Press the Enter key to start the test.
The Hard Drive Self Test will provide an Estimated test time . A Quick test, a Comprehensive test, and a SMART test will execute when the Enter key is pressed. If any test fails , order a replacement hard drive. If all of the tests pass, the hard drive is not damaged.
If all tests pass , press the power button to restart the PC. The error was most likely a result of a shock to the PC triggering a SMART error from the Hard Drive. Since the Notebook PC passed the Hard Drive Test, it is safe to use.
Mar 07, 2009 | Acer Aspire 3680 Laptop
Acer 1642 laptop is giving me much trouble. Was working fine until, fapoot... now i receive a message: SMART failure predicted on hard drive 0:ST6100825A-(PM), please help if you can
A SMART failure means that your hard drive is predicted to fail
soon. Fortunately these warnings are not right 40%-50% of the time. Go to the command prompt (start- run- type in "cmd")
In the prompt type in "chkdsk"
This will run tests on your hard drive and tell if there is anything wrong with it.
Dec 28, 2008 | Acer Aspire 3610 Notebook
1720-SMART HARD Drive detects immenent failure. What shall I Do?
Sounds like your hard drive is about to pack up. You can disable SMART for your hard drive in your CMOS setup. which will allow you to boot up your pc. I suggest you back-up all your data as soon as possible before the hard drive fails completely.
Nov 29, 2008 | HP xw6600 Workstation with 650W 80 PLUS...
Disk error searching for boot rercord from CDROM not found
Hi rmirish,
The hard drive has built in SMART diagnostics to check itself to make sure all is well. If the SMART is showing status BAD then the hard drive is either either starting to go out. Your best bet is to try to backup any data (if you have any) on the hard drive and replace the hard drive.
Hope that helps,
Take care,
Michael
Nov 17, 2008 | NEC Computers & Internet
SMART error
i think u have to try to RE-install OS
Nov 03, 2007 | HP Compaq Presario v3000z Notebook
Acer Aspire 5050-3242 Notebook Logo
64 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
