Question about Brother MFC-3240C All-In-One InkJet Printer
Printing after being on same phone line as printer/fax
My brother called me and wanted me to do research on my computer, but unfortunately I used the only phone nearby which I suspect was on the same line as the brother mfc-3240c printer and fax machine. It said Telephone on the lcd display and I tried to print his article but now it just says, "Unable to clean, see troubleshooting and routine maintenance chapter in User's Guide." I have the brother Quick Setup Guide, but not the other User's Guide. How do I reset it back to normal? The other people said powering down and back up again doesn't work. Please help!!
    Problem Solver:
  • 12 Answers
This link will open the Users Manual, but you will need a PDF viewer such as Adobe Reader or Foxit Reader in order to open it.
Go to page 12-4 in Chapter 12, Troubleshooting and routine maintenance. Follow the actions recommended for the Unable to clean error message (and the four other Unable to... error messages).
Posted on Jul 21, 2008
Hi i have a brother called MFC 8660DN, he is not recieving or sending any fax since this morning and i can't find the problem.
Try these things below to narrow down the problem.
  1. Plug a standard phone into where the fax line is plugged into to check for dial tone. if you have dial tone try replacing the phone line between the wall and fax. If not you have a phone line issue.
  2. Make sure the printer is actually responding to print commands from a computer, this could indicate a hardware issue if it does not.
  3. Check the ink levels. If the printer thinks it is out of ink then it will not print faxes.
I hope this points you in the right direction Regards GM
Apr 26, 2011 | Brother MFC 420CN All-In-One InkJet...
How do I receive faxes with the 240c
Manual mode turns off all automatic answering functions unless you are using the Distinctive Ring feature or you are using an external answering machine on the same line as the Brother machine.
*Distinctive Ring is a function of your Brother machine that allows a person with one line to receive fax and voice calls through two different phone numbers on that one line. Brother uses the term "Distinctive Ring," but telephone companies market the service under a variety of names, such as Custom Ringing, Personalized Ring, Smart Ring, Ring Master, Ident-a-Ring, Ident-a-Call, Data Ident-A-Call, Teen Ring, SimpleBiz Fax & Alternate Number Ringing and BT Call Sign.
  1. Setting the Receive Mode
    1. Press Menu.
    2. Press the up or down arrow key to select Initial Setup.
    3. Press OK.
    4. Press the up or down arrow key to select Receive Mode.
    5. Press OK.
    6. Press the up or down arrow key to select Manual.
    7. Press OK.
    8. Press Stop/Exit.
Receiving Faxes in Manual Mode
  1. Lift the handset of a telephone that is on the same line as your Brother machine.
  2. When you hear the sending machine's fax tones (short beeps that occur at regular intervals), do one of the following:
    • If the telephone you answered is near your Brother machine or connected to its EXT jack(socket), press Black(Mono) Start or Color(Colour) Start.
    • If the telephone you answered is not connected to or near your Brother machine, press *51 (*91 for New Zealand) on its dial pad.
  3. Your Brother machine will produce receiving tones.
  4. Replace the telephone handset. Your Brother machine will begin to receive the fax.
< Easy Receive (Fax Detect) >
The Easy Receive (Fax Detect) feature allows you to receive faxes in Manual Mode by simply lifting the handset of a telephone that is on the same line as the Brother machine. Your Brother machine will automatically generate fax receiving tones, at which point you can replace the telephone handset and wait for your fax to be received and printed.
Your Brother machine's Easy Receive (Fax Detect) feature is turned ON by default. To adjust your Brother machine's Easy Receive (Fax Detect) setting, please follow these steps:
  1. Press Menu.
  2. Press the up or down arrow key to select Fax.
  3. Press OK.
  4. Press the up or down arrow key to select Setup Receive.
  5. Press OK.
  6. Press the up or down arrow key to select Easy Receive or Fax Detect.
  7. Press OK.
  8. Press the up or down arrow key to select On, Semi or Off. *In some brother machines, Semi may not be in the options.
    If you choose Semi, your Brother machine will only answer an incoming fax if you answer using its handset or by pressing the Hook, Hook/Hold, Hold, Speaker Phone or Tel/R key on its control panel.
  9. Press OK.
  10. Press Stop/Exit.
Note Here are a couple of points to keep in mind:
  • If Easy Receive (Fax Detect) is ON, but your Brother machine doesn't automatically answer the incoming fax when you lift the extension telephone's handset, press *51 (*91 for New Zealand).
  • If you send faxes from a computer that is on the same telephone line as the Brother machine and the Brother machine intercepts the calls, turn Easy Receive (Fax Detect) OFF.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Jul 14, 2010 | Brother Multi-Function Center MFC-240C...
Brother (MFC-7340 FAX, Scan, Print) - Can send FAX...
Be sure to have a noise filter on the ADSL line so the line quality is good enough to send and receive faxes.
May 20, 2010 | Brother MFC-7340 All-In-One Laser Printer
Brother MFC-240 will not receive faxes...
I cant get my MFC-290 to receive incoming faxes
Sep 21, 2009 | Brother Multi-Function Center MFC-240C...
I want to review incoming faxes on my computer so I can choose which ones to print
Plug your fax line into the phone jack on your PC's/laptops modem. Run the fax software. Tellit to wait for incoming faxes. You're done!
Jul 07, 2009 | Brother MFC-7440N Laser Printer
Brothers mfc 620cn does not print incoming fax
If you're just trying to receive a fax over the phone line, the computer and software are irrelevant. For testing purposes, I would unplug the USB and network. Make sure the phone line is plugged into the jack marked LINE, not EXT, which for an extension phone or answering machine. If it's not sharing a line with regular phones, it should be in FAX mode to answer all calls automatically.
You can do some testing without another fax. Call it from another phone line - even a cell phone. It should answer after a few rings (how many is programmed in the menus of the fax) and annoy you with that high squeal in your ear. If it does that much, you need another fax to call it to learn more.
Are you on a regular, old-fashioned phone line? If you have one of those digital package deals with TV, Internet, and phone, you may not have the high voltages necessary to signal a fax. In that case call your cable company and tell them your woes. They should be able to provide the adapter you need.
May 07, 2009 | Brother MFC-620CN All-In-One InkJet...
We can send faxes but we can not receive faxes. The fax machine that sends the fax tell it that our line is busy. Is that a machine problem or a phone line problem?
Problem lies in your Receive Mode setting. If you don't have a dedicated phone line for the fax machine, you need to set it up for either Manual where you answer every call or Fax/Tel whereby the Fax machine determines if the incoming call is a fax or phone call. Instructions per Intellifax 4100 Manual.
Select a Receive Mode
Choose the mode that best suits your needs by pressing the Mode button
repeatedly until the FAX and FAX/TEL lights show the setting you want to use.
Manual
You must answer every call yourself.
The Brother machine must be started manually
to receive faxes.
Fax
For use with a dedicated fax line.
Every call is answered as a fax.
Fax/Tel
For receiving fax and voice calls on one line.
The FAX answers every call and receives a fax or
double rings for you to pick up a voice call.
TAD
For use with an answering device.
The TAD answers every call and stores voice messages.
Fax messages are printed.
Apr 20, 2009 | Brother IntelliFAX 4100 Laser Fax
Fax recieving faxs
If you only use this line for a fax the least stressful option is a fax to email service and re-direct the incomming calls.
If you use this line for fax and phone do as I suggest above except re-directing the calls but dont forget to tell those who fax you of your new number
Jul 10, 2008 | Brother MFC 7420 All-In-One Laser Printer
Brother 1270E won't receive faxes
make sure the phone line is plugged into the port marked "line" not "phone"
Jun 14, 2007 | Brother IntelliFAX 1270E Plain Paper Fax
Brother MFC-3240C All-In-One InkJet Printer Logo
192 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
