Question about HP Office Equipment & Supplies
Everytime i turn my computer on and try to use my printer won't go untill i go to printers&faxes and reset the default from one printer to the other printer-the icons in the printer/fax box are as follows-F300series[copy]ready the other one reads f300series deleting but i am unable to delete this icon so that is why it keeps on switching from one to the other if i could get rid of one of these icons it may return to normal regards pat ellison
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 93 Answers
Once remove the USB cable from the computer and perform spooler refresh by performing the below steps:
1. Click start >> run >> type >> services.msc >> locate print spooler and then right click on it and select stop and then again right click on it and select start.
Now open the printers and faxes folder and then try to delete the icon which is stating deleting.
Now right click on the other printer icon and click on properties >> adavanced tab >> print directly to printer >> click OK.
Now connect the USB cable to the computer and then try to print.
If you are still not able to print then remove the USB cable and delete even the other printer icon and insert the CD and click on add a device and follw the instructions and connect the USB cable at the middle and then try to print once it finishes.
We experience this type of issues if the printer driver is not installed properly.
Posted on Jul 04, 2008
Computer won't detect printer
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/nJ7AgN. Select your operating system, download and execute the file.
Feb 10, 2012 | Lexmark X1290 All-In-One InkJet Printer
Lexmark x7550 won't communicate with computer to scan
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/ngaKcu. Select your operating system, download and execute the file.
Oct 19, 2011 | Lexmark X7550 InkJet Printer
My Lexmark z2300 sends to the printer & it says it's printing, but it doesn't actually print. I've tried several file types & programs to print from but none of them work.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
Sep 14, 2011 | Lexmark Z2300 InkJet Printer
Lexmark X4650 prints fine & used to scan to computer, now when press scan>scan to computer>downloading application list & seems to freeze.
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list again, then try to print again.
Aug 31, 2011 | Lexmark X4650 InkJet Printer
Why won't my printer print after I installed the software? It says its ready but nothing will print
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 18, 2011 | Lexmark PhotoJet Z705 InkJet Printer
"Communication Not Available" message is displayed
2. Unplug and re-plug the printer into the power source to reset it.
4. Reboot your pc.
You may also try to update your printer driver by visiting the Lexmark website at . Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 16, 2011 | Lexmark X2670 All-In-One Printer
Hello. pls let me know how to restore my lexmark x6500 wifi printer??
To restore your Lexmark X6500 Series printer to its factory default settings, follow the steps below:
  1. Press the Settings button on the printer operator panel.
  2. Use the arrow keys to move through the selections until Defaults is displayed. Press the check mark button to accept this option.
  3. Use the arrow keys to move through the selections until Set Defaults is displayed. Press the check mark button to accept this option.
  4. Use the arrow keys to move through the selections until Use Factory is displayed. Press the check mark button to accept this option.
  5. Use the arrow keys to move to the required country, language, date & time, time format, fax number and fax name and press the check mark to confirm each selection.
  6. When the process is complete, the display will read Initial Setup Complete.
Source: How to Reset a Lexmark X6500 Series Printer to the Factory Defaults
To reset the printer's wireless network settings, please refer to this article: How to Reset the Network Settings on the X6570 Series AIO Inkjet Printer
Jul 27, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
Asks for cleaning all the time
Try NVRAM Initialization
turn off, hold ENTER and * buttons, turn on printer(still holding both buttons). Wait until you see PERMANENT STORAGE INIT. Release both buttons. Wait for READY.
See if that fixes problem.
Warning - this will reset printer to factory defaults. That includes fax settings and fax numbers and speed dial codes and all faxes stored in memory.
Jan 20, 2010 | HP LaserJet 2840 Printer
I cannot scan or fax after multiple tries. Can you assist
Hi
Thanks for using FixYa. Try to reset the printer by power cycling it for 4-5 min.s. Also tell me if you are able to print and not fax/scan. Make sure that all the cables are plugged in well. Also tell me if you are getting any error messages on the printer as well as on the computer.
Try and reset it & check if it works. To reset the printer go in the configuration menu where you can reset the printer back to factory defaults.
  • Press and hold the Start and Stop buttons and turn on the printer.
  • Hold the buttons down until “Performing Self Test” is displayed on the LCD.
  • Release the buttons and “Configuration Menu” is displayed.
  • Scroll to the RESTORE FACTORY DEFAULTS item on the menu and press select.
  • Now scroll to RESTORE BASE and press select this should reset your network card password.
  • There is also a RESTORE NETWORK, this will erase the network configuration but will not reset the password.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Sep 24, 2009 | Lexmark X5470 All-In-One InkJet Printer
OfficeJet 7310 FAX issue
Did anything happen prior to the issue? It almost sounds as if the DC controller (main board) has gone bad. What happens if you try to make a copy on it?
May 22, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
