Question about Maytag Washing Machines
My maytag Performa PAV3360AWW had three problems going. It quit agatating and spinning, and the water keep filling and overflowing. We replaced the belt, and also discover that a hose had come lose on the back. It now agigates and the water shuts off but it won't spin. Any suggestions as to what is wrong?
  • 3 more comments
  • spacebear Jul 07, 2008
    The motor is running. Is the pulley kit hard to put in? Can you give any insructions on how to put it in?
    The motor is running. Is that the same thing as a thrust bearing kit?
  • spacebear Jul 09, 2008
    Hi Again,
    My husband took off the pulley and it didn't appear that there was anything wrong with the parts. Is there something you would be able to see by looking at it ? There is only one belt on the bottom. There are two small pulleys and the large one. Is there another belt or does this model just have one. Maytag pav3360aww. Any other suggestions?
  • spacebear Jul 11, 2008
    Hi Again,
    The basket is out, and no sock inbetween. The agitator spins, but turning the pulley the otherway it moves a little bit and then is stuck. Is it the white disc under the shaft that moves to make it spin? Any other suggestions?
  • spacebear Jul 15, 2008
    OK Thanks
  • 481 Answers
Please bear with me as i am committed to help you. but i need to know if the motor is running while it is trying to spin or if it is silent. if the motor runs but no spin then you may need a transmission pulley repair kit (approx $30). or if is silent then you may need a lid switch.
let me know if you need more help
Posted on Jul 04, 2008
  • 1 more comment
  • Mike Durland
    Mike Durland Jul 07, 2008
    yes it sounds like it needs the thrust bearing kit.
    • lay the machine down on its side and look at the bottom
    • take off the belts
    • on the large pulley you will see a C clip
    • take this C clip off and the pulley and all the parts you need to change will come off.
    Item
    1042142
    at repairclinic.com
  • Mike Durland
    Mike Durland Jul 09, 2008
    put the pulley back on and turn it. turn it one way it should move the agitator, turn it the other it should disengage the break and the basket should spin freely. if it does all that correctly then you know the problem is somewhere else. if you cant disengage the break and spin the basket then these parts are needed. if the break disengages but the basket is hard to turn then it might have a sock or something between the tub and basket.
  • Mike Durland
    Mike Durland Jul 11, 2008
    the whole function of this thrust bearing kit is to disengage the brake so the basket can spin freely. so if you compared the old parts with the new parts and they look perfect, then the only other thing would be the center bearing completely locked up (rare). this usually does not happen unless the center seal has leaked water on it.
    i still think that the plastic pieces in the trust bearing kit could be bad. this is a very common problem with these machines.
Model #110.49962600 water fills agates will not spin
And the code is!? Gee I hate when that happens! OK look at these:
F1--Water supply/low water fill.
o 1. Check water supply to machine.
o 2. Replace water inlet valve.
• F2--Water level too high.
o 1. Plugged/Bad water pump.
o 2. Faulty water valve.
• F3--Pump problem.
o 1. Check pump trap and clean.
I go with the last one..Common, then the pump is bad then the valve. But You didn't tell Us!
Jan 16, 2014 | Kenmore Elite 45986 Front Load Washer
Hi my washer will not drain or spin Please help
lid switch or pump 1st start washer is the washer agatating lift the lid if it stops you need to ck the water pump all wasers need to drain the water befor thay will drain
Jun 24, 2011 | Maytag Performa PAV2200
My washer fills with water and keeps filling doesn't stop on the selected water level for the load. It doesn't wash because the water keeps filling. What's wrong with my washer? Help please (Maytag...
The problem is simple and easy to fix. Your washer has a tubing which runs from the base of the tub to the water pressure switch. It might have vibrated loose from the switch, or their can be some sediment in the tub. Blow out the tubing and reattach it securely to the switch and pump out the water in the tub. Then try it again. I wrote an article about this:
Help my washer is overflowing !!!
Jan 07, 2011 | Maytag PAV2300 Top Load Washer
My Maytag Performa washer loves to flood the house!!!!
sounds like pressure switch is bad or pressure hose is plugged or water valve is bad or drain overflowing
Apr 22, 2010 | Maytag Performa PAV2200
Maytag PAV2300 washing machine
You may need a new fill switch.Or you can try to remove the small hose from the outer tube to the water level switch and clean it.That is a short cut that may work but i would go with a new water level control switch hope i helped:)
May 16, 2009 | Maytag Performa PAV2200
Maytag top loading washer won't agate. Instead it fills with water and spins, then drains, fills for the rinse and spins. Thanks Bill
Open your control panel.
Disconnect then reconnect your timer wiring harness.
If this does not correct the problem,replace the timer.
Feb 25, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Water fills but won't stop filling-overflows and won't spin out
This is joyce
You might want to check into the Valve that lets the water flow into the machine or it may be the switch that controls the water flow to the machine, it is either one of the 2. go to maytag.com and dowload your document to your machine type and see if you can get help.
let me know how it goes
thanks
joyce
Feb 19, 2009 | Maytag Performa PAV3200
Maytag performa washing machine
yes im a expert (laugh)...your drain hose is to low..the drain hose must go up the height of the unit abut 3 feet before it can go down...now if you have your drain hose connect directly to your drain pipe ,,the waste pipe will **** the in coming water right out of unit,,we call this a sphion effect...booth easy fixs,,,onthejob
Jan 22, 2009 | Maytag Performa PAV2200
Maytag performa
does the water overflow from the waser. also try and fill the washer up with water and when you feel it should be filled to capacity shut the water off to the washer. and turn off the power. After you have done that turn the water back on and turn the power back on to the washer if the water stops running it could be your water valve and is easily replaced. if the water continues to run it could be the pressure switch (water level switch) or it could be a hole in the pressure switch hose.
Dec 30, 2008 | Maytag Performa PAV2200
Washing Machines Logo
986 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
