Question about Kenwood DV-5700 Multi-disc DVD Player
Stopped playing after I inserted damp CD in 200 disc loading mechanism
Kenwood DTSMultichannel digtal outlet CD324M
  • melbee11 Jul 10, 2008
    I have already dried the CD and the Cd playerout long ago,,,,It just wont do a thing
    will do
  • 4,472 Answers
Doe sit recognize the cd? It will open and close? does it attempt to read the disc? Have you tried a CD/DVD lens cleaner?
Thanks,
Lee
Posted on Jul 10, 2008
  • 6,487 Answers
Try using a CD cleaner to clean your player ...
Hope that helps....
    Guru:
  • 1,894 Answers
This can be due to some moisture in lens.
leave the unit to get dry for 2 days.
Posted on Jul 04, 2008
We can't get the factory 6 disc cd player to load more than 1 disc. What is the sequence for loading additional discs?
The following is the owner's manual for your 2004 Dodge Neon:
http://www.dodge.com/en/owners/manuals/index.html?year=2004&nameplate=Neon
P.99 describes how to load discs:
1. Select and press any numbered button without an illuminated light above it.
2. Insert the CD while the light above the chosen button is flashing and the two lights on either side of the slot are illuminated.
3. Upon insertion, the CD will begin to play, and both the button light and the lights in the corner of the loading slot will illuminate.
4. Repeat the process for loading any additional CDs. The CD playe rwill stop while additional CDs are loaded.
Playing Discs
The radio will show the CD number, the CD track number, and the Track Time Elapsed while the radio is in the CD mode. IF more than one CD is loaded in the changer, the changer will automatically play the next disc after playing the last track of the current disc.
Wow, that's a lot of typing.
I didn't know the 2004 Dodge Neon had such a nice changer.
Good luck.
Jul 04, 2010 | 2004 Dodge Neon
I have a Kenwood music system (quite old ) cd player DP-322 after you load the disc it sometimes just plays 1 track or doesn't play at all if you open the draw and then close it and select random play it...
you need to have the lazer lense cleaned by a pro or buy a lens cleaning cd and load it about 5 times i think youl find it will fix your problem
cheers
sonic boom electronics australia.
Apr 21, 2010 | Audio Players & Recorders
Car cd player will not work
It sounds like it's not loading the disc propperly, it ejects immediatly yes? A mechanical loading fault.Try banging it as the disc loads..... not a cure but the knocking might dislodge something, it may have to come out and be fixed.
Apr 05, 2009 | Car Audio & Video
Sony CDP CX 235 200 cd changer-cd's dropping off
Hi there.
I reckon that they are not being put back correctly by the loading mechanism! This is a common problem with these units. It is highly unlikely that they are actually falling off the carousel.
Open the unit, and watch it as it loads and replaces the cd's from the carousel. You will probably find that instead of grabbing the disc off of the spindle and putting it back, it might be grabbing before the cd is even in its grip. This then simply bumps the cd out of the way, and it will fall inside of the unit.
The good news is that it can be fixed with a bit of very gentle bending and persuading. But be very carefull when doing this!
Good Luck!
Jan 22, 2009 | Sony CDP-CX235 200-Disc CD Changer
Kenwood cd stopped pla computer made cds after i dropped it now will play for about 1min then stops
hi 1paullawrenc, try get your lens cleaned by using a lens cleaner hope this solve your problem.
raj..
May 11, 2008 | Kenwood CD-203 5-Disc CD Changer
Kenwood RXD25 CD player intermitent??
Hi jenoss
Sounds like the unit has either a failing load belt to the cd drawer mechanism,not allowing the transport to fully load the cd. Give the unit a gentle tap just after the drawer closes and see if it resolves the problem.
OR a faulty spindle motor, you will have to take the lid off and after pressing play, give the disc a gentle "kickstart". If it then begins to run, then the motor is the problem.
If you find it is neither of these, get back to me here and I we shall go further
regards
Graeme
Mar 16, 2008 | Audio Players & Recorders
CD-423M
The amp may be damage.
Feb 02, 2008 | Kenwood CD-423M 200-Disc CD Player
CD won't play; continually shuffles from one CD to another
did it just start doing this....how long have you had the unit for?
Dec 16, 2007 | Kenwood CD-223M 200-Disc CD Changer
Stopped playing cd`s
Lots of options- listen to it- see if the disc is being spun. If so, either the laser died, the lens is dirty (not too likely if suddenly happened) or some bump or kick has shot the allignment. most of these are a biggish prob, except if you are a handy person, you could get inside and clean the dust off the laser lens with a cotton bud. The hard part is cleaning the mirror and the back side of the lens! BE CAREFUL not to mix up the allignment- this is a very critical mechanism of the player!
Jun 10, 2007 | Kenwood KDC-C467FM 6-Disc CD Changer
Remove DISC010 error
If there is a disc in the changer (I guess it's in the tenth slot), try removing it, if it doesn't work by 'normal' means and you feel brave, try shaking the unit a bit. If it doesn't help or you don't feel like banging on it, you'll have to take it for a repair (they open the unit and extract the disc, they get jammed sometimes).
Nov 05, 2005 | Kenwood CD-423M 200-Disc CD Player
Kenwood DV-5700 Multi-disc DVD Player Logo
179 people viewed this question
Top Kenwood Televison & Video Experts
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Kenwood Televison and Video Expert? Answer questions, earn points and help others
