Question about Hitachi 43F300 43" Rear Projection Television
Magic focus where is the magic focus button on my Hitachi 55vs69
  • Hitachi Master
  • 8,617 Answers
If your model has magic focus it should be behind the flip down cover on the front panel next to the auxillary video inputs
Posted on Jul 04, 2008
The blue light comes on for a while the cycles thru the blue, red, red, and so on..
Look for a recessed button on the front of the set "magic focus" which can cause the set to keep trying to do that function.
Jun 11, 2012 | Hitachi 55VS69 55" Projection HDTV
How do i adjust the magic focus?
  • Press "Menu" on the remote select the "Magic Focus" option in the Video menu or press the "Magic Focus" button on the front panel to adjust the convergence of the three picture tubes that create the proper color for the picture. Pressing the button on the TV initiates the automatic adjustment, and accessing the feature through the Video menu allows you to choose automatic or manual adjustment, though the "Automatic" setting must be selected for the button on the front of the TV to begin the process.
  • Aug 04, 2011 | Hitachi 53UWX10B 53" Rear Projection...
    We cannot get the color to align. It appears like there is a blue or yellow background around words
    If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
    If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
    You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
    Mar 02, 2011 | Hitachi 57F500 57" Rear Projection...
    Magic focus error Hitachi 52
    The model number you have selected here does not have magic focus--if you really want a answer post the correct model number.
    SD TECH
    Dec 12, 2009 | Hitachi 52LDX99B 52" Rear Projection...
    Is there a Magic Focus function on 53XDF01B?
    The correct model is 53fdx01b. There is a mogic focus button on the front of the set. Procedure for Chassis DP05F, DP05, HP11, HP12:
    1. Press and hold the DIGITAL ARRAY or CONVERGENCE ADJUST button on front panel.
    2. While the button is held down, then press the INPUT or ANT button on remote control.
    3. The unit will now be in the DCAM.
    NOTE:
    1. Proceed with digital convergence adjustment.
    2. Remember to save the correction data.
    3. Units with MAGIC FOCUS only - Failure to initialize MAGIC FOCUS sensors after saving
    convergence correction data will result in a STATIC (+) display when MAGIC FOCUS attempts
    to run. The technician will then be required to access the service only switch behind the front
    cover to get back into the DCAM to initialize the sensors, since the procedure to access DCAM
    without removing the front panel, requires MAGIC FOCUS to be running.
    4. To exit, press the POWER button on the front panel.
    Apr 23, 2009 | Hitachi 53UDX10B 53" Rear Projection...
    Magic focus won'f fix misalignment
    YOU NEED CONVERGENCE REPAIRED EST AROUND 300.00 CALL TERRYSTV IF IN N. CALIF
    Mar 28, 2009 | Hitachi 43F300 43" Rear Projection...
    Yellow and blue color ruins total picture on 50" tv,can't get rid
    lupe0112,
    I'm no expert, but I think that you have a problem with the convergence of the 3 color guns. I've been working on a similar problem. As a first step, have you tried "Magic Focus?" The Magic Focus button for the Hitachi 53UDX10B is at the left of the small front panel controls that also include your RCA composite and SVideo connectors. Let the set warm up for about 20 minutes (as recommended by the user guide), and then press the Magic Focus button. When you press the Magic focus button, the set will auto align the 3 color guns. If this doesn't fix your problem, unplug the TV for at least 4 hours and try again.
    Jan 08, 2009 | Hitachi 53UDX10B 53" Rear Projection...
    Magic Focus does not work.
    Convergence issues usually resolved by changing convergence output amplifier IC's.....Original STK392-110 should be replaced
    with upgrade Stk394-160E Hitachi part # CZ 01341,change both
    for reliability.....check B+ feed resistors for over-heating....T.
    Feb 04, 2008 | Hitachi 43UWX10B 43" Rear Projection...
    Won't turn off
    Go to the panel (on the tv set), hit magic focus on there....then hold power button for several seconds long. It should go off and fix your problem.
    Jan 22, 2007 | Hitachi 46W500 46 in. TV/DVD Combo
    Hitachi 43F300 43" Rear Projection Television Logo
    156 people viewed this question
    Top Hitachi Televison & Video Experts
    Jaime Hernandez
    Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
