Question about Dryers
Whirlpool Senseon GGX9868JQ1 Dryer will not heat. I get a 04 code.
  • 1 more comment
  • sobrokesobro Jul 04, 2008
    dryer stays on sensing,doesn't heat up. I haven't had any code errors. It is 7 years old, i just replaced the calypso washer, same age. Broke and can't afford to buy dryer, I still am paying off washer. HELP,PLEASE
    KAT
  • Kerry Ingold
    Kerry Ingold Aug 01, 2008
    Dryer comes on and tumbles, no codes in the minute readout, but no heat; burner never ignites.
  • dnatomski Aug 27, 2008
    my gas whirlpool senseon dryer skips right over the sensing mode right to the wet mode. It tumbles but is not igniting/heating up. It is 4 years old.
5 Suggested Answers
  • 122 Answers
SOURCE: clothes not getting dried
Are you sure that the duct is clean and free flowing? If the duct is partially blocked the dryer's efficiency drops dramatically. I would double check the duct at both ends and clean out as required - air flow is very important - with the dryer on - go check the air coming out of he duct outside - if it is very forceful - then the problem is elsewhere - however if only a little bit of sir is coming out - your all plugged up!.
Posted on Nov 19, 2008
  • 2920 Answers
SOURCE: Whirlpool Senseon Dryer-drum doesn't spin & stuck on sensing mode
the belt on the drum could be broken
Posted on Feb 16, 2009
protek480
  • 1714 Answers
SOURCE: Whirlpool Senseon dryer GEW9868kq
The element is controlled by thermostats mounted inside the back of the dryer on the air exit box. There is also a contact on the motor that makes when the motor is running. Any of these could cause the problem. Try a different heat cycle, this may help narrow it down.
Posted on Jul 04, 2009
SOURCE: Our Whirlpool Senseon Dryer stopped heating. It's
I had the same problem. I replaced the thermistor,heating element and another part and still didn't correct problem. i finally had a friend come check it and believe it or not it was the 30 amp fuse in my fuse panel of the house.Come to find out the dryer will run and everything works like it should on 1/2 of the 220 plug but the other half runs the heating element.Both fuses must be good. I replaced the 30 amp round fuse and it works and heats perfect. I hope this helps you and saves you some time and money.
Tommy
Posted on Jun 09, 2010
SOURCE: In diagnostic mode, my Whirlpool senseon dryer
Idon't know the answer to this, but could you please tell me how to get into diagnostic mode on a senseon?
Posted on Feb 05, 2011
I have a Whirlpool Gold senseon Model number GeX9868Jq1 I can feel the heat inside to Dromm but when I push start it just clicks It's a electric dryer
Unfortunately, it sounds like the motor, since you aren't hearing it run. Motor turns the drum by way of a belt.If motor is running, but drum not turning, it would be the belt... I would also say door switch, but then the heating element wouldnt be heating up. Slight chance it could be the control, but I doubt it. DW
May 12, 2014 | Dryers
Whirlpool Senseon dryer control panel won't work
Could you please explain the problem in depth for me? Not sure what you mean by the control panel not working. Is it getting power? Do you have lights on inside the dryer (if it is equipped with it)?
Oct 14, 2012 | Whirlpool LER4634J Electric Dryer
Model gew9868KQ2 wont start E7 code
How do you remove the Toe panel off of the Senseon Electric Dryer?
Oct 18, 2011 | Whirlpool GEX9868J Electric Dryer
I have a Whirlpool Gold Senseon electric dryer that will run but does not heat. When the dryer is started it will remain in the "sensing" cycle for 9-10 minutes then jump to the cooldown cycle.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Sep 19, 2011 | Whirlpool LER4634J Electric Dryer
In diagnostic mode, my Whirlpool senseon dryer displays 79 insstead of 88. What does this error code mean?
Jan 19, 2011 | Whirlpool Dryers
Tommy
Mar 16, 2010 | Whirlpool Dryers
Jul 03, 2009 | Whirlpool LER4634J Electric Dryer
My electric whirlpool senseon dryer won't heat
lint screen on top///repl/thermal fuse in rear of dryer, if screen inside dryer remove front bottom panel, next remove blower housing on top off is the other thermal fuse ,, gurantee fix
Nov 29, 2008 | Dryers
My Whirlpool Dry Model GGQ9858JQ1 turns off in heat mode after a few minutes
HI. thanks for the question. the motor seems to be at fault here. did you clean the venting from the dryer to the outside. , did you clean the lint inside the dryer. if not do that, thanks.
Oct 07, 2008 | Dryers
Dryers Logo
380 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
