Machine Error 71 Brother MFC-8500 makes loud noise
  • Anonymous Sep 01, 2008
    sale machine error 71
  • shilliard Nov 18, 2008
    My Brother MFC9600 has machine error 71 and produces a loud squealing noise. None of the buttons on the front of the machine work.
    shilliard@samplingplans.com
early1234
  • 871 Answers
SOURCE: Brother MFC 8500 Fax machine error "offline"
is your fax machine connected to the phone line? this usually indicates the connection status, thus, if your phone line is in...you wont have the "offline message".
hope this helps.
Posted on Jan 23, 2008
SOURCE: Brother mfc 8500 clicking noises
If you open the cover and remove the toner/drum unit, you will see (on the left side as you remove) a small hole with two triangle teeth.
on either side of this hole are two small phillips head screws. this is the problem we had with our clicking noise. As the machine tries to turn the toner/drum, the innards of the toner are becoming harder to turn. So the part of the fax machine that fits in the hole end up stripping the teeth in that hole. If you have an old toner cartridge, you can remove the gearing from it (where the small phillips head screws are) and use it to replace the gearing on the newer cartridge. Or go buy a new toner cartridge.
Posted on May 09, 2008
komguy
  • 2306 Answers
SOURCE: Brother MFC-9700 Machine Error 71
71 says the fuser unit is not installed, it means the fuser lamp is burned out, or the temp. sensors are bad. In either case the best repair is a new fuser which you'll find at www.precisionroller.com
Posted on Jan 18, 2010
  • 159 Answers
SOURCE: Hae brother MFC-8500 and just replaced
This is an easy one. With the power on, open the front door, where you installed the drum. Press the CLEAR button. The display will ask something like, "Change Drum? Press 1 for yes. Press 2 for no."
Press 1.
Close the front door.
Posted on Feb 15, 2010
Testimonial: "thanks for your help...this is an awesome way to get help!.....although I didn't think to go online and look up the manual.but with dial up it's slow"
  • 186 Answers
SOURCE: Brother MFC 9880 error 71
error 71 indicates problem with the laser unit motor.. 80% is the motor problem and 20% could be the LVPS board... make sure all the cover and interlock switch are close properly.. as any interlock switch which are not close properly will effect the voltage to the motor..
Posted on May 28, 2010
What is machine error 71 How to fix it?
Error 71 on a MFC-9600 means there is a problem with the motor inside the printer.
You can try unplugging and waiting a few minutes, then plugging back in again.
If it is still coming up with the error, if its still under warranty Brother will replace/repair it for you, otherwise you will have to pay Brother for the repair cost.
Mar 05, 2011 | Brother MFC 9600 All-In-One Laser Printer
SCREEN READS ERROR 71 CALL BROTHER, WHAT IS THE PROBLEM, WHAT NUMBER DO I CALL
This error means that there is a scanner motor error. Try and remove the error by following these steps: Press MENU *,2,8,6,4. The machine beeps for approximately 1 second and will display "MAINTENANCE" on the screen, indicating that it is placed in the initial stage of the maintenance mode, a mode in which the machine is ready to accept entry from the keys. Now you are inside the simulation, Press 01 to reset the error status. After that press 99 to exit the simulation.
- Pressing the 9 key twice in the initial stage of the maintenance mode makes the machine
exit from the maintenance mode, restoring it to the standby state.
- Pressing the Stop button after entering only one digit restores the machine to the initial
stage of the maintenance mode.
If the error comes back, call Brother support, here are contact details:
7777 North Brother Blvd.
Bartlett, Tennessee 38133
Phone: 1-877-BROTHER (877-276-8437)
901-379-1215 (fax)
Monday-Friday, 9:00am to 8:00pm Eastern Time
Jan 12, 2011 | Brother MFC 8500 All-In-One Laser Printer
Error 71
- Pressing the 9 key twice in the initial stage of the maintenance mode makes the machine exit from the maintenance mode, restoring it to the standby state.
- Pressing the Stop button after entering only one digit restores the machine to the initial stage of the maintenance mode.
If the error comes back call Brother support, here are the contact details:
901-379-1215 (fax)
Sep 15, 2010 | Brother MFC 8500 All-In-One Laser Printer
May 28, 2010 | Brother MFC 9880 All-In-One Laser Printer
Mfc9880 machine error 71
error 71 is a problem with the polygon motor which is in the laser unit. This error usually means that you would need the laser unit replaced.
I'd suggest calling out an engineer.
Dec 12, 2008 | Brother MFC 9880 All-In-One Laser Printer
Clicking noise
the clicking noise is the gear fro the paper feeding roller. seems that the gear is broken, need to have it replaced.
May 21, 2008 | Brother MFC 8500 All-In-One Laser Printer
Machine error 71
Error code 71 -- ( Polygon motor does not synchronize with the reference clock. ) What ever that means - hope that helps.
Mar 20, 2008 | Brother MFC 9700 All-In-One Laser Printer
MFC-8500 fax operation
If there is noise on phone line machine reduces speed to enable fax to be sent. Have line check or try machine on different phone line to ensure it is a phone line problem.
Dec 03, 2007 | Brother MFC-8500 All-In-One Laser Printer
Jul 24, 2006 | Brother MFC 8500 All-In-One Laser Printer
873 people viewed this question
jasbo
jasbo
