Question about Nikon Cameras
Nikon d60 flash coupler
I just bouight my nikon d60 and found out that there are no outlet for corded flash what will i need so that i can use my corded flash
    Genius:
  • 1,673 Answers
If the camera has a flash shoe, you can get adabtors that go from the shoe to a cord and or connector. Check at a professional photo supply shop for details.
If there is no flash shoe, you can try using a flash with an optical slave to work with the camera's built in flash. But, this process has limitations, is expensive to do at high quality and reliability, and is not always the best way to go. Optical flash shoes can miss at times, and are subjected to reflection problems.
Jerry G.
Posted on Jul 09, 2008
How can I get the latest firmware for Nikon D60
Go to the Nikon support at the Nikon website at www.nikon.com and look for firmware updates for your camera. There should be instructions as to how to download and install the updates in your camera. You will need the appropriate cord to connect your camera to the computer. Best I can determine the cords are standard so if you've misplaced yours, a similar USB cord that will fit your camera's port should work. You can also order replacement cords from Nikon.
Jul 10, 2014 | Nikon D60 Digital Camera
Could the Sakar Dedicated Ittl Flash work For Nikon D60
Probable will not work on the Nikon's hot shoe because the contacts on the Sakar flash gun won't match the contacts on the Nikon's hot shoe.
You can use the Sakar flash gun as a slave flash by connecting a optical flash trigger to the Sakar flash gun and use the Nikon's flash to trigger the Sakar slave flash.
Feb 27, 2013 | Sakar Dedicated Ittl Flash For Nikon D60...
I've used the Quantaray PZ-1 DSZ on my Nikon N80 film camera and had no problems. I would like to use it on my digital Nikon D60.
There is no problem with the trigger voltage, which I assume is your primary concern. You may not get all of the features you would with a Nikon flash, but you should be able to use it with the D60 just as you use it with the N80.
Jan 05, 2013 | Quantaray PZ-1 DSZ for Nikon TTL Flash
Will the nikon sb16 flash unit work with the Nikon D60
Yes. The trigger voltage of the SB-16 is well within the safety range of the D60 and other digital cameras. I use mine with my D90 without any problems. However, be aware that the SB-16 is a rather old flash, and will not work in the iTTL mode with the D60.
Oct 29, 2011 | Cameras
Flash on Nikon D60 does not work
Hello. When i first bought a D60, it was working perfectly outdoors at day and would work without a hitch with external flash. However, the internal flash would never get released. No menu option would be of any use, only symptoms were flashing 'flash' and 'question mark' symbols in the finder. NIKON service fixed it - There was nothing wrong with the camera electronics. The little flash release mechanism somehow acted up and NIKON staff fixed it in +- 5 minutes. I do hope you have yours in full working condition by now.
May 19, 2009 | Nikon D60 Digital Camera
Using a speedlight
the SB-22 has a voltage of around 4.5v this means that it will not fry you D60 SLR so the answer is YES you can use you old flash gun with your D60
Feb 21, 2009 | Nikon Speedlight SB-22S TTL Flash
Using a vivitar 2800 flash on a nikon d60
The old series Vivitar 2800 flashgun has a very high trigger Voltage, that can damage your D60's circuitry. Even measuring the trigger voltage with a voltmeter is not a solution since you can't rely on the voltmeter to indicate the peak voltage.
Feb 05, 2009 | Vivitar 2800 Flash
I have just recently boughta Nikon D60 and currently own a Tamron 28-300 lens and a 90 macro lens. I think that I want to buy a strob after a workshop I went to this past weekend. I want to be able to...
The SB-600 will probably do everything you want.
One caution: To use flash off your D60 you're going to need either an external sync cord or a wireless controller. The SB-800 (and the current SB-900) can be used as a controller, the SB-600 can't. But the controller goes on the camera, so you'll end up needing two flashes.
Oct 22, 2008 | Nikon Cameras
Cameras Logo
205 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
