Hi, im james from the philippines, i just got my k800 from my sister from australia..i got it unlocked succesfully at a local workshop and after a few hours while i was exploring my phone i got a little curious and opened a program in the games menu called "executor", it loaded with the java screen for a while and it turned off by itself, i tried to turn it on back again but it won't do, next i tried to charge it but nothing happens, same ways i did when i plugged it in my computer nothing happened..pls help me on this thanks! :)
It is a very well known issue tha only appears after unlocking. Seriously :)
Go back to the guy that unlocked it and ask him to unlock it again, this time with "enable preloader security bypass" checked then to delete the executor application. If he doesn't know what the above means then I suggest you find another guy that actually knows what he is doing...
Cheers,
Meow
Just Click On The Problem or
Phone Model For Solution,
Motorola RAZR V3
Unlock Software Hardware
Motorola SLVR L7
Motorola RAZR V3i
Sony Ericsson K800i
Sony Ericsson W200i
I always see operation failed whenever i try to open applications or games. please help me. i try to update my phone but still didn't work. i have master resetted ma phone but still didn't work.
Hi I have the same problem, I clicked on the executor and the phone flashed on and off and started again ok. So I clicked on it again!!!! (curiousity killed the cat!!!) Then my phone turned off and wouldn't start. Has anyone been back to the unlocking shop, have they managed to repair? I downloaded the system that they use and I can see the option "enable preloader security bypass" on there but i don't think i have the right cable as i am only using the USB that came with the phone and I can't connect my phone without it being turned on I have heard you need a cruiser cable to do this but i'm not sure what that is??????
I have got the same problem in 2 K800i mobile phone. Both are dead after running the game application executor. How can someone unlock the phone again if its dead?
THERE IS A PLACE IN LOS ANGELES TEL 323-651-5555 THAT CAN FIX THESE PROBLEMS
I dont think that it was you i think it might have been an extreamly bad coeinsidence you need to ring up sony erricson on 1300-650-050 (Toll Free)
I was one of those curious people who was victimized by the executor application located in the games menu of sony ericsson. this is due to a previous visit to the repairman to make the phone "open line". and so the piece of **** executor was left behind. if you have the bypass procedure thing, i think you could fix it by yourself. there are some websites that explain the steps. just type bypass operation whatever you call it. But if you dont want to make it worse. i suggest you go to a repairman,just like I did. but. i had to pay again eventhough it was his fault.well, sort of.
recently my sony ericsson k800i just shut down after I tried to open an application soon after shutting itself off I tried switching it back on but it would not go on.Is it possible to flash a phone that is switched off
i have the same problem how i make it ?
my sony phone died after i selcted executor in the games menu. what do i do :((
i was applying themes and wallpapers when it just shut down tried to turn back on but only a little red light flashed a couple of times inside the infared lens
i tryed everything but my phone would not work.
