Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ice and Water not dispensing. Light button not working
Fridge is a GE GSS25WG side by side black. Ice and Water is not dispensing from outside. Also, light button is no longer working. All other buttons appear fully functional including refrigerator and freezer temperatures, door alarm, etc... When I press light button a clicking sound happens at door 1 or 2 times. Same thing happens when I press to get water or ice - it clicks one or two times. Lights appear a little more dim than usual.
Refrigerator is still making plenty of ice. Water filter appears fine and water filter light did not come on. Not sure if problem is electrical at the door or possibly something else and I'm not sure where to start to check.
On my Ge PSS26NGPC model, a few months ago, the water/ice dispenser and the temperature control panel stopped working, making me think I had a bad control board.  A few days later, everything was working fine until 6 weeks ago.  Then water/ice dispenser worked intermittently - opening and closing freezer door seemed to get it working again.  I noticed when it was working, the light flickered, as though there was a voltage fluctuation at the panel.  I changed out the main control board, but had the same issue until the the water/ice dispenser panel stopped working completely - not even the green lights.  The last time it dispensed water, the light came on and stayed on, then the panel went dead. I then replaced this panel, but still not working.  Ran diagnostics, and the "0 3" and "0 4" tests both failed - not surprising since the dispenser panel appears to be dead.  I have double checked connections at main control board, dispenser panel, and temp control panel, and none are loose.  No combination of old and new boards will get the dispenser panel to work.  Oh, the other symptom, when the panel was alive but not working, the green light next to the water or ice button would flash.  Any ideas on what to check next?
  • Anonymous Mar 12, 2014
    light does not come on controj board, refriderator does not work on ac or gas, no fluids visible in back of unit, no lights on on control panel,
  • Anonymous Mar 23, 2014
    Model: XRSS267BB side-by-side with ice + water dispenser.
    Dispenser control panel lights flashing (filter+cubes+auto light) in following sequence: all three-auto light only-all three-auto light only-all three (and so on...)
    Genius:
  • 1,665 Answers
Http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Posted on Jul 04, 2008
    New Friend:
The door switch needs to be changed on freezer side. Thats shorted.
Posted on Mar 04, 2016
GE Eterna side by side fridge Model ESS2SLGMAWW
I've got the same problem...have de-thawed everything, (this was how we fixed it before) and still can't get water to dispense. Guess another 75 bucks service call...urgggg...
Dec 27, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice dispenser won't work, light won't work.ge side by side fridge
A GE uses a 12 volt bulb . It will not come on , if you went and bought a bulb with the same receptical end . HAS to be a 12 volt .
Sep 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge fridge makes Ice, doesn't dispense
turn freezer side to zero for 1 minute. press water dispenser
Jan 26, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
No light on water and ice dispenser not working
there sure seems to be a lot of problems with this GE refrigerator
I will try to find answers soon.
Jul 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
INSIDE THE DISPENSER ASSEMBLY IS A SEPARATE ELECTRONIC BOARD THAT CONTROLS THE DISPENSER.
OCCASIONALLY, THE DOOR SOLENOID OR THE CUBE ICE SOLENOID WILL SHORT OUT CAUSING A BURNOUT OF THE DISPENSER CONTROL BOARD. CHECK FOR A BURNT SMELL COMING FROM THE DISPENSER HOUSING. IF YOU SMELL IT, THE BOARD AND/OR SOLENOID NEED TO BE REPLACED.
Apr 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice & water control buttons
sound like a bad(shorted) dispenser user interface INTERFACE DISP ASM WR55X10415
Apr 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser in fridge door
Email me for the bulletin on water line freezing. Try turning on the dispenser light for 24 hours this should defrost the line.
amasuperbike@comcast.net
Jan 15, 2008 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
1,671 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
