Question about HP Office Equipment & Supplies
Trying to install HP Officejet 6300 all in one and after I connect usb to computer the installation stops & tells me another installation is already in progress & complete that installation before proceeding to install. I have tried several times to install & only get to this point
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 93 Answers
We will experience this issue if the previously installed software is not removed completely.
Insert the software CD and click on uninstall and then uninstall the software.
Now restart the computer and then try to reinstall the software.
If the issue persists disable the firewall and antivirus and then try to reinstall.
Posted on Jul 04, 2008
How do i connect an hp officejet printer to a wireless laptop
Download and install the drivers & software necessary for your printer from HP's website (www.hp.com) on your laptop. After the software and/or drivers are installed, connect the printer to the laptop with a usb cable. As long as the software is installed the pc should recognize the printer as soon as the usb cable is connected. Then just print as normal.
Oct 26, 2011 | HP OfficeJet 6110 All-In-One InkJet...
HP Officejet 6310 drivers will not install
When you install the printer wait till you are prompted to hook up the usb cable. If you hook it up sooner that is the problem. You can have the usb cable to printer but not to the computer. Then run your install disc and you should be fine.
Mar 01, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
My printer has been installed but it still states that there is no connection, what do i do?
Did you have the printer plugged into the usb port while installing the software, if so, you can't do that try re-installing and wait till the program tells you to connect to printer and computer.
You might want to check and make sure that the usb cable is secure in the usb port.
Feb 21, 2010 | HP Officejet J5780 All-In-One Printer
Scanner does not work It keeps telling me "no conncetion to computer" but the printer is conected . I can copy from the computer. Wher can I find an instruction manual for Officejet Pro L7590 My last HP...
The Driver of the scanner and driver of the printer, this two miscellaneouses of the driver, in addition is fixed. Attentively install both drivers with mounting disk. Else use the cable USB from kit of the supply, scanner can not work since long шур USB.
Sep 25, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
I have a office jet 5600 I started using 1 mo.
Solutions straight from HP...
If your HP All-in-One and computer are not communicating with each other, try the following:●Check that the HP All-in-One print queue is not paused (Windows) or stopped (Mac). If it is, choose the appropriate setting to resume printing.
For more information about accessing the print queue, see the documentation that came with the operating system installed on your computer.
●Check the USB cable. If you are using an older cable, it might not be working properly. Try connecting it to another product to see if the USB cable works. If you experience problems, the USB cable might need to be replaced. Also verify that the cable does not exceed 3 meters (9.8 feet) in length.
●Check the connection from your HP All-in-One to your computer. Verify thatthe USB cable is securely plugged into the USB port on the back of yourHP All-in-One. Make sure the other end of the USB cable is plugged into aUSB port on your computer. After the cable is connected properly, turn yourHP All-in-One off and then on again.
●Check other printers or scanners. You might need to disconnect older products from your computer.
●After you check the connections, try restarting your computer. Turn your HP All-in-One off and then on again.
●If necessary, remove and then install the HP Image Zone software again.For more information, see Uninstall and reinstall the software.
Aug 07, 2009 | HP Office Equipment & Supplies
Computers not sensing scanner via LAN
Scanning over network usually requires software to connect. First go to the drivers page as below. Windows Vista | Windows XP, download the latest drivers (the Full Feature one) as well as the firmware update for the OfficeJet. Plus the "Update" files that's dated newer than the Drivers.
Upgrade the firmware (this will reset all custom settings in the OfficeJet like IP address) with a USB connection.
Run the full feature installer and if there is an option for Networked OfficeJet, then tick it. Also you may need to change/disable firewall for the installer to pick up the networked OfficeJet.
Scanning over the network usually connects with a customized TCP port. And most likely the Windows "Scanners and Cameras" will not pick up network scanners unless it's been defined manually (installer can do this part).
Jun 15, 2009 | HP Officejet Pro L7650 Printer
Lost instalation cd and instructions for 5610 Officejet All-In-On
If you do not have the software, you need to download the software from one of the following locations:
HP Officejet 5610 All-in-One Printer
Select your operating system HP Officejet 5610 All-in-One Printer
After downloading is finished, unplug the printer USB and run the software that you downloaded.
The software installer will tell you when to connect USB.
Apr 15, 2009 | HP Officejet 5610 All-In-One InkJet...
Can't see scanner
Hi
Try this
1.Right click on MY computer ->Properties->Hardware->Device manager.
2.You will get Device manager window popping out.
3.Scroll down to "Universal Serial BUS controllers".Click on the (+) sign.
4.Check for the "USB Composite Device" and right click on it, click Uninstall.(IMPORTANT NOTE:wE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for wat location says, Eg -LOCATION : HP DESKJET F2100
5.Disconnect the USB and reboot the PC.
6.Connect the USB after reboot, you will get popup "Found new hardware".Then the Drivers will be installed Automatically.
Thanks
Riz
Dec 29, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Hp officejet 5610 all in one printer
you can use the serial/usb adaptor to connect it to your computer
May 07, 2008 | HP Officejet 5610 All-In-One InkJet...
Original supplied software not allowing printer installation
On the off chance you have a bad disk and it has a corrupted file you can also go here and download from the website - click on the download only button and then install. If you have the same issue I would say your WHQL is corrupted.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-40459-2&lc=en&cc=us&product=1119598&os=228&dlc=en&lang=en
Feb 28, 2008 | HP OfficeJet 6310 All-in-One Printer...
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
