Built-in speakers suddenly don't work. Toshiba Satellite A305-S6825. Using Vista. Drivers are current...speakers not muted...checked hardware in control panel...no problems. Help...thanks
  • 28 Answers
I've had to deal with this SO MANY times! Go into control panel -system -hardware -device manager to look for the problem (should have a red or yellow "X") (if something is wrong with the driver, which is what has always happened to me for no reason whatsoever!). So, just delete & reboot; this should reinstall the driver. Hope this helps!
Posted on Jul 04, 2008
Shuts down after a few minutes
Try another battery.
If it's doing this while plugged in, there's probably failing electrolytic capacitors in the external power unit. Repair or replace it. Chances are the power supply will test as good under no load.
May 15, 2012 | Toshiba Satellite A305-S6825 (4400 mAh)
Where can i find a cord for toshiba satellite 8305-s6829
If you are referring to the AC Adapter, you can find out here:
http://www.buy.com/prod/new-ac-adapter-for-toshiba-satellite-a305-s6825-a305-s6829-a305-s6833/q/sellerid/24353325/loc/101/214314182.html
Otherwise please specify the type of cord you are looking for.
May 05, 2011 | Computers & Internet
Toshiba built in camera not working properly
I found an article that suggests some more ideas to solve webcam problems. Maybe one of them will help in your situation.
Jan 05, 2010 | Computers & Internet
Toshiba built in web cam not working
Remove both Webcam driver and skype with a software called Vista Manager from yamicsoft.
Why a third party tools to uninstalled a software?The answer is it will remove even the files or registry key that is concern with that software.
Download the file using the link below
http://www.yamicsoft.com/vistamanager/software/vistamanager.exe
If you are with windows 7 then downalod Windows 7 Manager
Here is the link :
http://yamicsoft.com/windows7manager/software/windows7manager.exe
after unstalling reboot your system.
First installed your webcam driver and check webcam work or not. Then installed skype software.
It will work.
Note: Lastest skype version have problem with webcam synchronisation.so used a little older version.
Dec 28, 2009 | Computers & Internet
Laptop Assistance
Yes, the Toshiba A305-S6872 has a built in modem. It is the only port where you can plug in a phone line.
Jul 23, 2009 | Toshiba Satellite A305-S6863 Laptop
Can not find a proper driver for my network controler
are u talking abt LAN driver thats what u mean then download the follwing driver and install it will work 100% actually ur machine came loaded with vista and u are using Xp thats why toshiba is not providing driver for XP but no problem try the link below
Pls rate me FIXYA for help if u need more help i am here to assist !!
http://www.realtek.com/downloads/downloadsView.aspx?Langid=1&PNid=13&PFid=5&Level=5&Conn=4&DownTypeID=3&GetDown=false
Mar 31, 2009 | Toshiba Satellite A305-S6883 Notebook
Bios information using window Vista
You can install Lavalys Everest program to get all the info about your computer.
Trial version can be downloaded here.
Jan 16, 2009 | Toshiba Satellite A305-S6863 Laptop
Pioneer dvd-rw dvr-k17a
Are these drives you have fitted yourself, or been added as after market drives?
If so you have run in to the odd way Toshiba set their optical drives as master or slave, although this is generally and IDE #1 error.
To fix this you need to solder pin 45 and 47 together.
47 is the key pin here, as it controls whether the drive is in SLAVE or MASTER mode.
grounded, the drive is in MASTER, open, it is in SLAVE.
pin 45 is simply a grounding pin.
So you'll need to open up the drive, turn it over, and put a small blob of solder on the two pins next to each other - 45 and 47.
If they are original drives or used to work then uninstall the drives and the IDE controllers in Device manager and reboot, letting windows redetect and install the hardware. Also try reinstalling the motherboard drivers available from Toshiba's support site.
Oct 08, 2008 | Toshiba Satellite A1O A15 A20 A25 A30 A35...
Dear Sir/Madam,
This is the problem of not matching/support the motherboard of your driver with Pioneer DVD. U just go the manufacturing site of Pioneer dvd and download the driver / updates and then install it. (Before u uninstall the driver). Then fix it.
Thanks
"Don't Forget To Rate the Solution"
May 19, 2008 | Computers & Internet
Computers & Internet Logo
83 people viewed this question
David Payne
David Payne
