Question about Refrigerators
Side by side refrigerator icemaker not making ice. Hotpoint mdl HSS125IFMD Tried installing new filter. Getting water but no ice being made.
  • nancykoehler Jul 04, 2008
    Water dispenser works on Hotpoint side by side fridge, but no ice is being made. Replaced filter. Checked icemaker switch. When I turn it off and then back on, a small spurt of water goes into icemaker, but then nothing.
    Water is not going into the icemaker, so it is not cycling. Temp in the freezer is 0.
  • 3,037 Answers
I would first try replacing the solenoid valve which lets the water in. Also, how are the ice cube arms aligned? They should be vertical
Posted on Jul 04, 2008
  • Benjamin Patri
    Benjamin Patri Jul 04, 2008
    also, the water hose isn't clogged even a little bit correct? If you disconnect it, do you have full pressure?
    Novelist:
  • 161 Answers
What is the freezer temperature? What happens to the water that is in the ice maker? Is it frozen and just not popping out? Is it filling completely? If it is full and just stopping , the icemaker is probably bad. If the freezer temp is below 10 degrees It should cycle with no or little water in it. If it is cycling try replacing the valve. If the temperature is right and it is still not running at all. replace the ice maker. (Usually just 2 - 3 screws and plug the new one in.) valve will run about $25 ice maker about $75
  • 2,071 Answers
side by side refrigerator icemaker - icon1.gif With the wires disconnect from the heating element you should get continuity.
Here is a link to your fridge model HSS22IFMD CC.
Here is your heating element.
    Scholar:
  • 83 Answers
Refrigerator - Icemaker Not Dispensing, Making Ice
Check that the feeler arm on the icemaker is in the down position and is not blocked.
If the icemaker does not have a feeler arm make sure the icemaker paddle is not blocked under the icemaker.
For more information on the causes of new icemakers not making ice.
For more information on normal ice production.
Side by Side models:
  • The filter may be loaded with sediment that can cause low water pressure.
  • The water pressure must be between 40 and 120 psi.
  • Pressures below 40 psi may cause a malfunction of the icemaker (i.e. producing hollow cubes or no ice production).
Test the water pressure:
  • Dispense water from the dispenser into a large measuring cup for 20 seconds. If the measuring cup contains less than 13.5 ounces (400 metric centimeters), the water flow is inadequate.
If the amount of water is less than 13.5 ounces then the refrigerator fails the test, remove the filter and test the refrigerator again with the by-pass plug in place.
  • If the refrigerator dispenses the proper amount of water with the by-pass plug in place, then the filter should be replaced.
  • If you no longer have the by-pass plug and it has been over three months since the filter has been replaced, you should replace the filter.
  • If the refrigerator fails the test again and you know you have the proper water pressure in your home, you should call service to check the refrigerator.
If the amount of water collected is over 13.5 ounces then the refrigerator passes the test and the dispenser is working correctly.
  • Shaun Harris
    Shaun Harris Jul 04, 2008
    If your unit is new then this is what you do
    View a short video about troubleshooting your icemaker:
    Play Video
    Refrigerator - Icemaker New and Not Producing Ice
    If the icemaker has just been installed, there are a few things that must happen before it can produce ice:
    • The icemaker will not start immediately after being plugged in. The mold temperature must first reach 16 degrees Farenheit before a cycle will begin. It is recommended to wait 24 hours before expecting ice.
    • If the water line was just added to the machine, it will take about 1 1/2 hours to initiate a cycle.
    • The icemaker is dependant upon the temperature of the freezer. If the temperature in the freezer is too high, ice cubes will take longer to form.
    • In new installations, there may be air in the water supply line. The icemaker will cycle it out in a couple of cycles. The first cycle will produce a small amount of water, and the second cycle will fill over this. It may overfill slightly but this is normal.
    • The icemaker must be plugged in and turned on (electronic models). Icemakers are shipped in the off position. It should be plugged into the left rear wall of the freezer.
    • There must be food in the fresh food and freezer sections, or temperatures will not drop sufficiently to cycle the icemaker.
    • The rear air vent located near the icemaker in the top mount no frost models must be pointed down so the air will blow directly over the water in the mold.
    Note: If your unit has a water filter, it may be clogged. A clogged filter restricts water to the icemaker and reduces the amount of ice made. The restriction will also be seen at the dispenser with slow water flow.
    To see if the water filter is clogged, remove and replace it with the filter bypass plug. If you have a water dispenser, you can check the flow rate by filling a glass with water. You should be able to fill an 8 oz glass within 10 seconds. Normal filter replacement should be every 6 months.
    Guru:
  • 1,342 Answers
Here's a good Troubleshooting Guide
Icemaker on hotpoint refrigerator model no. hss25gftcww makes ice slow and not as much
have you changed the filter? if so try a complete defrost of machine and pull the inlet line from back of icemaker and make sure there is no calcium lime deposits restricting water flow
Jul 04, 2012 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Ice maker does not work on my Hotpoint sise by side. the water dispenser works, i've replaced the filter, the green light is on, but nothing happens with the icemaker, no running water sound, no ice
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Jul 01, 2009 | Hotpoint HSS25GFP Side by Side...
Whirpool fridge won't make ice
a loss of water supply to the refrig could cause this problem. check the fill tube that supplies water to the icemaker (this is the tube that omes into the rear of the icemaker) i think you will find it is frozen up. you can clear this out wiht a hair dryer. I just looked at a diagram for the model number you provided and the fill tube is the black tube that comes into the fill cup on the far right hand side of the icemaker. you will have to raise the icemaker door to see it. but heating this and clearing the ice will fix it thanks peyton
Mar 02, 2009 | Whirlpool GS2SHAXM Side by Side...
Icemaker on Hotpoint Model HSS25GFPAWW Refrigerator not working
try turning the temperature for the freezer down a little bit. it has to at least be around 17 degrees before the older ice makers start to work.
Jan 20, 2009 | Hotpoint HSS25GFP Side by Side...
Replaced water filter now icemaker not working
check to see if the direction of the water flow is correct on the filter
Dec 31, 2008 | Maytag MSD2456G Side by Side Refrigerator
I had the same problem and even called a technician only to be told they would come out for $70.00.
I got a tip and learned that nothing was ever wrong with the icemaker. What you must do is turn the temperature up to the maximum for a period of at least 8 hours. Especially after changing the water filter or unplugging, power failure, etc. Once the icemaker is producing you can then lower your temperature gauge.
Sep 13, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Ice machine not making ice
Hi, everak11,
Three possible solutions for you.
1: No water coming in from inlet valve. Check voltage on inlet if you have voltage and no water then replace valve.
2:Icemaker not cycleing. Lift the arm on the icemaker to shut it off and leave it for about an hour. Come back in and turn the icemake back on by lowering the arm. If the icemaker does not begin a new cycle and the arm start rising then the problem is most likely an icemaker. Replace Icemaker
3:Refrigerator not cold enough. If the freezer is not getting cold enough the icemaker will not cycle. Check the temperature in the freezer and make sure it is getting down to 0 degrees. If not then you may have another problem with your refrigerator. I hope this helps you, Let me know if you have any other questions or symptoms. Mike
May 08, 2008 | Refrigerators
Hotpoint HSS25GFP icemaker stopped working
are u sure that model # Is right.. DOnt come up in any of my model data bases Seems like u might of got a bad icemaker.. if the water is coming into the icemaker from the water valve.. icemaker has to have power, to do that... all funtions after that would be controled by the iceaker .. The only other thing i can think of is your refrigerator has to be a certain temp to activate icemaker somewhere around 0 give or take some to be safe
Aug 21, 2007 | Hotpoint HSS25GFP Side by Side...
Water leaking inside freezer ice maker
sounds like the line was frozen but the water fill indicator is faulty.
Jun 05, 2007 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
1,354 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
