Question about Gateway FPD2185W 21 in. LCD Television
Trying to fix lcd Gateway Monitor.
My Gateway Monitor shows , Gateway icon, when , turn on, for 2 sec, and became black.
Thanks
    Problem Solver:
  • 5 Answers
There's a couple capacitors you need to replace. On the video board, not the power supply board. There is (3) 470uf16v on the video board. They have to be the smaller ones, you can not use the larger ones (they will not sit flush onto the board) Any questions, e-mail me at Andrew@CreativeAudio.biz
Posted on Jul 04, 2008
When connect ps3 to monitor it turns on then goes black then on and off
If you try the monitor elsewhere and still does that, there are chances that the hight voltage work for few seconde then stop.
Most monitor experience this with age, I use to open the monitor and look for condenser that have the top carved, not flat anymore.
this mean that the condenser dry and made internal gaz.
Those should be all replaced. 2 time over 3 it does fix this issue.
then if you try you monitor on a computer and it does work correctly, then it would be the PS3 , I suggest trying to unplug the PS3 for a 30 sec then try rebooting it. (did happend to me once)
Jan 04, 2014 | Gateway FPD1975W 19" LCD Monitor
Vaio LCD problem
Periods.......Nice little items because they denote the End of a sentence.
See how this works?
"I have a vgn cs36gj, I was working with it, suddenly the LCD became pale black, I connected it to external monitor and it has a picture, sometimes after turning on for 30 minutes LCD start working normally, but after turning off and disconnecting power when I turn it on, it only shows a pale black picture, you know it is on but only black!"
Now you try it.........
"I have a vgn cs36gj. I was working with it, suddenly the LCD became pale black.
I connected it to external monitor and it has a picture."
Okay, I got that part.........
"sometimes after turning on for 30 minutes LCD start working normally, but after turning off and disconnecting power when I turn it on, it only shows a pale black picture, you know it is on but only black!"
WHICH LCD?
Laptop LCD?
External monitor LCD?
Man on the moon LCD?
1) If the external monitor LCD goes 'pale black', the problem is the graphics chipset.
This I do not believe
2) If the laptop LCD goes pale black, this I believe.
Post back in a Comment.
Regards,
joecoolvette
Apr 25, 2013 | Computers & Internet
When turned on, monitor (LCD)shows desktop for +/-1-2 sec. and goes black
Have you tried this monitor on a different computer? If it happens on a different computer then most likely the monitor is defective.
Nov 19, 2010 | Gateway FPD 1730 17" Flat Panel LCD...
FPD2275w monitor monitor powers on but shuts off after 1 sec shows a picture perfect before it goes black all buttons light up and stay lit sounds like they r working
This model will likely have 2 or 3 bad capacitors in the power supply. You can see the tops bulging. They are 1000Uf @ 10 volts.
Monitor Mike
Aug 20, 2010 | Gateway FPD2275W LCD Monitor
The monitor will shot of will show no pictur ,if u restart the pc it will come back for a sec or 2 but than no pic a gian i try it on my other pc and he did it agian,i chack the conecsion i chek the...
coolvegasmik, Sorry, to hear that your "cold cathode-fluorescent-lamp-back-lit-lcd-monitor" is not working. Did you hold and point a bright flashlight 1 inch from the lcd panel when it went to "black-screen"??? Did you see any icons on the "black-screen"?? Software NOT a fix for this "black screen of death" problem. You or electronics technician will need to open L91A and look for bad capacitors or bad soldering on the power supply printed circuit board. If unit is 4 to 6yrs old, just trade-in for new wide screen unit. See video clips of swollen bad capacitors at YOUTUBE when you search "lcd monitor repair". All lcd monitors (99%) use same basic design and principle of operation. Sometimes ccfl back-lit lcd monitors can be repaired for less than $6 in parts and monitor will work for 1 to 3 more years. 12fixlouie
Jul 21, 2010 | Hyundai L91A 19" LCD Monitor
When I power up my computer the Gateway icon shows up but monitor stays black...I repeatedly hit the power button on the monitor until the screen finally shows up..and once its on it stays on all day until...
hi, these are exellent monitors. i have repaired and made good profit on these. there is about 8 capacitors on the main board that go bad. all are 470uf 25 volt. if you have good knowledge of soldering, you can perform this repair. even broken, these monitors go for 100 dollars on ebay. contact me back if you want more info on how to repair yourself.
Feb 08, 2010 | Gateway FPD2275W LCD Monitor
Gateway 22 inch LCD monitor suddenly goes black...blue on light works but pic only stays on for 3 secs when computer is turned on.
Your inverter or backlight need to be replaced those are the main components that light up the display.
If you find this helpful please rate so.
Thanks
May 04, 2009 | Gateway FPD2275W LCD Monitor
Screen only stays on for 1 sec
Assuming you changed all the caps and did it correctly.
IF you get flickering, It could be a transistor on the inverter board.
OR !!! and probably more likely,
It could be one of the bulbs in the lcd itself is failing. It only takes one bad bulb to stop an inverter from firing up !! You can check them one at a time if you have another working monitor.
If you do unplug a good bulb from the good monitor and try each of the questionable ones, one at a time.
Doesn't have to be a gateway monitor to test it, just needs the same backlight plug.
ebays bammbammfran
Jun 05, 2008 | Gateway FPD2185W 21 in. LCD Television
Open Questions:
See all Gateway FPD2185W 21 in. LCD Television Questions
Gateway FPD2185W 21 in. LCD Television Logo
185 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
