We had an AC tech change out the motor to the fan in the outside AC unit and a new compacitor. When it rains the motor does not come on (the compressor comes on but not the fan).
    Scholar:
  • 104 Answers
Weird!?! The only possible cause for this that I can think of is that the tech did not install the correct motor for an outdoor unit. Condenser fan motors are essentially sealed, it will look like a metal cylinder with a shaft sticking out one end and wires out the other. A motor intended for indoor use will have slots in the outside case to facilitate ventilation. Take a look and see if you see slots in the case of the motor where you can see inside to wires and the internal components. If you can, then you have the wrong motor, if it appears to be sealed to keep out the weather, then I haven't got a clue what it could be without getting my hands on it. Keep in mind that I am a service tech that usually diagnoses the equipment when it is in my presence.
Thanks,
Chillmaster
Posted on Jul 04, 2008
YORK OUTSIDE UNIT MODEL # HP036X1021A
You must change the fan motor or you will have more problems
with car temperature!
May 09, 2014 | Canvas Dipped York Brief - Grey
Replace compacitor on Carrier 5 ton 3 phase AC
Your 3 phase unit should not have a capacitor. I'm guessing it's single phase. If it's a single capacitor than the compressor should not be going to it also. To test the motor, common to start plus common to run should equal the ohms you get between start and run. For instance, 1.2 ohms+ 2.2 ohms= 3.4 ohms. Follow the wiring diagram on the inside of the door, send model number!!
Aug 29, 2017 | Carrier Heating & Cooling
I have a Ruud Zepher Serris Central A/C & Heat unit - forced hot air. I cleaner the dirt and debris out of the outside unit put back together and now the outside unit will not start. There is power...
if you have power to the outside unit and the fan is not turning - the most likely problem is that the fan motor is bad. I would make sure the power is all OFF and then try and turn the fan blade by hand. If it's stuck and will not turn or turns 'hard' - the bearings have gone out and the only fix is to replace the motor.
If the fan blade turns freely - then you might check the capacitor (small electrical device attached by wires to the fan motor) and see if all the connections are tight and complete and that the capacitor itself is not bulged.
If it's 'bulged' that is a good indication that it's bad and that could be your only problem.
Otherwise I would either change the motor myself (if the bearings are out) or get an AC Tech to troubleshoot the system.
Hope this has helped.
Aug 05, 2011 | Ruud UAMB042 Air Conditioner
We replaced the compacitor, when you turn the control on inside the outside unit clicks and starts to hum, you can hear the new comp running. The fan will not kick on. All of the wires are connected and...
You have to replace the capacitor whenever you replace a compressor. You may have a bad fan motor as well usually when capacitors go bad the motor isnt far behind. This unit will have a dual capacitor for the fan and the compressor and yes one side can go bad and the other side be good. Replace the capacitor and let me know
Jul 21, 2011 | Ruud UBHC Air Conditioner
Samsung split ac mdl # u24a2qc, system is about 10 years old. outside condensor operates fine until warmest part of day, then the fan on the compressor unit cycles on and off repeatedly although the...
I would guess that the motor is pulling to many amps, it could be to small (not the horse power as should be), could be bad incorrect fan blade (to many blades or pitch on blades) over loading the motor. I have seen fan motors get to hot and stop from a dirty coil. Take a garden hose and a nozzle use a solid stream carefully watching the fins don't bend by high water pressure. Throughly clean the coil every inch or it. Hope this helps.
Jul 09, 2011 | Samsung Heating & Cooling
Turned on AC was running fine. 30 minutes later began to hear a strange noise. Opened AC/Furnance closet & heard a sound best described as air letting out of a tire. It seemed to be coming from...
Hi!!
This means that the condenser fan motor (outside unit) failed, this caused to build hi pressure and either activated a safety valve to release the extra pressure or blew a line and R22 Refrigerant escaped from system.
The fix is to replace motor fan and capacitor find the leak and refill system with R22 Refrigerant Gas. It is safe to turn on the Fan Only mode on the Thermostat until a HVAC Tech arrives.
To perform this job parts and labor included will cost: about $300 -.$400. Look on the Yellow Pages for a Tech in your neighborhood.
Good Luck!! Don't forget to Rate this post!!
Aug 13, 2010 | Goodman CKL42AR42 Air Conditioner
Ac fan on, blowing air, but not cold
Check outside unit if unit and compressor are running feel the large line to see if it is cold. If compressor is running and line is not cold possible charge problems. You may have a capacitor problem outside. they go out quite often. You can change this yourself, Open up outside unit and the cap is the silver bullet with terminals out the top. Bad cap can cause compressor to not operate and also the fan. You need to clean the coil inside or at leat check the coil to see if it is clean. You can clean theis with a toilet brush do not go against the coil bit brush with the fins. You may need to call a service tech but try these options first. russ
Aug 15, 2009 | Heating & Cooling
OUTSIDE UNIT OPERATES BUT FAN DOESN'T TURN AND UNIT DOESN'T COOL.
the motor could just be locked in place from sitting...take a stick or something and try to see if it spins be sure of rotation! you can also give it a little nudge while it is on and it will take off! if this happens then you have a bad start compacitor but no there are no fuses that only protect the motor!
May 25, 2009 | Goodman CKL42AR42 Air Conditioner
Fan does not turn but motor seems to be running fine
Rain should not affect an outdoor unit. It is designed to be outside. The motor that you are hearing... could this just be your compressor running? If the condenser fan is not operational the compressor will run much louder. TURN THE POWER OFF! See if the fan will spin freely if it is pushed. If it doesn't replace the fan motor. If it does you need to check the power at the contactor going to the condenser fan motor. This is 220 volts BE CAREFULL.. If power is going to the motor and the motor is not running... Change the motor and capacitor. If no power is going to it it could be a bad contactor.
Good luck....
Apr 11, 2009 | Goodman CKL24AR24 Air Conditioner
PHKJ048-1 outdoor fan stopped
This is nothing but a bad fan motor. Probably caused by rain down pouring off the roof into the unit. Try adding channel diverters that diverts water (a lip on the edge of the roof) >!
Sep 05, 2008 | Goodman PHKJ048-1 Air Conditioner
Heating & Cooling Logo
70 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
