Question about Electrolux UltraLux 2000 Bagged Canister Vacuum
Electrolux 2000 Mod# c151c
Vacuum starts and stops about every minute, What causes this?
  • AerusGuy
    AerusGuy Mar 08, 2018
    Fyi, Electrolux Corporation, the manufacturer of the Model C151C Ultralux 2000 cleaner, changed its name to Aerus LLC in 2000 when it sold back the Electrolux trademark and brand to its original parent company, AB Electrolux of Sweden.
    Go to aerushome.com to locate an Aerus dealer for assistance, sales, parts, literature, and service.
    Best.
  • 43 Answers
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
http://evacuumstore.com/
Posted on Apr 17, 2010
  • 73 Answers
Turn the knob on top all the way to the right
Posted on Aug 28, 2009
Electrolux L E Canister stopped working
It sounds like it may be a bad control valve assembly, which is found inside the machine. This part is controlled by the dial on the top of the vacuum and does wear out eventually.
If you've got a clean bag in the vacuum, this is the most likely cause. There may be other things that could cause the problem.
This is a repair that needs to be done at repair shop, I recommend one that has personnel trained in repairing the older style Electrolux vacuums like yours.
Dec 17, 2013 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Vaccum afuera 550 start few minutes and stop few secondes, after 10 min its stop 30 sec and start 3 sec, after 20 min start ok
Your vacuum may be clogged, overheating and shutting off. Check for obstructions in the hose by laying it as straight as possible and shining a flashlight in one end while looking thru the other end. If you have a curved hose end, try holding the suction hose from another vacuum while checking for airflow in the opposite end.
Nov 06, 2013 | Electrolux Central Vacuum
Electrolux ultraactive vacuum won't start
Hi There, The E2 error is caused by the terminal block pins where the hose plugs into the vacuum become bent out of shape. This is the receiving pins at the front of the vacuum on the inside. If what I am saying is confusing then it probably needs to go to a technician, it is a 10 minute job to fix if you have done it before. There is also a slim possibility that you may need a new hose for it too. If you are in Melbourne I can fix it I run the VacuumSpot business.
Jul 06, 2013 | Electrolux Vacuums
Electrolux EL7020 SHUTS OFF Constantly!
That problem have 2 causes..#1 is loose electrical connection inside or on the power cord..#2 is worn out carbon brush inside of vacuum motor..
Carbon brush is the one of the most serviceable parts of a vacuum cleaner because our vacuum cleaner motor is very hard working parts so the brush inside will possible worn or not connected to the armature of rotor...
Jan 12, 2012 | Electrolux EL7020A Oxygen 3 Ultra Canister...
What size vacuum bags does an Electrolux Ultralux 2000 bagged Cansister have?
It takes the "C" (canister) bags made by Home Solutions for Aerus Electrolux vacuum cleaners.
Apr 24, 2011 | Electrolux UltraLux 2000 Bagged Canister...
The power chord on the 2100 electrolux will not retract
Try standing the vacuum on end, or at a near vertical position, and gently tugging on the cord a few times. This will usually cause it to retract. The problem is usually caused by pulling the cord out too far. Avoid doing this as it can result in disconnecting or breaking terminals and/or wiring.
Jan 12, 2011 | Electrolux UltraLux 2000 Bagged Canister...
Protection light
it might be the bag or the sensor inside the machine.
Jun 28, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Power nuzzle keeps stopping
Get a new "Short Cord". These have a habit of going bad at the connector. Only a couple of bucks.
Dec 11, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux UltraLux 2000 Bagged Canister Vacuum Logo
488 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
