Question about Maytag Atlantis MDE7400AY Electric Dryer
The problem in heater element sensor .i got a site more information about error code of Maytag dryer and they are saling spare parts also on line..
http://www.repairclinic.com/0078.asp#Maytag5
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
Posted on Jul 04, 2008
Drying is too slow
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent
Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork
Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
The heating element may damaged try to replace it.
Hi
are you sure the thermostat is ok? or why you take a look the filament? maybe this is defective thats why your unit is abnormal function!
Thanks!
Dont rate me if not fixed your unit
thanks!!!!
just go to this links. http://www.repairclinic.com/0088_8_1.asp...
Have ou check the heating element, the thermal fuse..?
Mar 19, 2010 | Maytag PYE2300AY Electric Dryer
Feb 22, 2010 | Maytag Dryers
Oct 12, 2009 | Dryers
Aug 09, 2009 | Maytag MDE308DAYW Electric Dryer
Jun 04, 2009 | Maytag PYE2300AY Electric Dryer
Dec 29, 2008 | Dryers
Dec 29, 2008 | Maytag PYE2300AY Electric Dryer
Dec 01, 2008 | Maytag Performa PAV2200
241 people viewed this question
I checked the thermal fuse and the heater goes red because it's hot.
That does not help, i checked already, anything else? please
there are only 2 thermostats, 1 on the heating unit 1 on the blower unit.
I replaced them just in case, they are brand new, problem is still not solved.
Seems like everything works and heat and everything, but clothes are still wet.
heating element goes red and heats
he will look into reading the book sent.
Im sure he will find out whats going on
