Question about Dell Inspiron 2200 Notebook
Dell Inspiron 1150 - No Screen
My granddaughter had yanked on her power cord and the plug-in was sitting kind of sideways on the back of her notebook. My brother welded the plug-in area back in place. Now, we don't have a picture.
I've tried plugging in a monitor and still no screen came up.
You can tell the notebook loads up - hear the fan - but no picture.
I took it into a repair shop and they refused to even open it up. Said that it was now worthless.
There was one ribbon that was not connected and I re-connected it with no success.
Can you ofer me any tips? I have no experience working on notebooks at all.
Thank you for any suggested fixes.
  • dmccalip Jul 05, 2008
    Thank you for your help. I appreciate your quick response.
    I was hoping for a different answer as I don't understand how welding the plug-in would take out the motherboard when it was working fine before my brother welded it. Could it be something else? Hopefully, a cheaper fix? Could something have come loose somewhere that would cause the video not to come on?
    The fan area gets real hot. Could the fan getting real hot have caused something to happen?
    I appreciate any offered suggested fixes.
  • dmccalip Jul 06, 2008
    Thank you so much for all your help. I will try that. :o)
  • 3,940 Answers
Replace the motherboard, it appears that the video circuit is damaged. Replacement motherboards are less than $150
http://cgi.ebay.com/Dell-1150-Intel-Motherboard-F3542-TESTED-GOOD_W0QQitemZ160256506429QQihZ006QQcategoryZ60265QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Posted on Jul 04, 2008
  • IQUIT Jul 06, 2008
    Here are some things to try, but I'm not real hopeful
    1. Reseat the LCD cable connection to the motherboard, then boot the system.
    2. Connect your external monitor. Press the Fn key + F8 once, and wait 15 seconds to see if there is any difference on the display. If not change press Fn+F8 again and wait again. The Fn+F8 is a "Toggle" that switches from LCD, to Both External and LCD to External only.
    If you have no video from LCD or external monitor after cycling the Fn+F8 toggle 3 times, then the video port is no longer functional.
    The problem with re-soldering the power connector on to the motherboard is the circuit board is 4 layers thick. In the process of soldering, unless he is very expert in microcurcuit soldering, is you can cause another failure on the card (in this case video)
Dell inspiron 1150 wont power up the power light flashes green and batery light flashes orange but the fans or any thing else wont work
You may have a burnt board or the input pin is bad, try wiggling the pin while it is plugged in to see if you can at least get the fans to start you obviously have a short of power in the power button area. You may want to try replacing the power button board for your model this may offer you a solution. If you take it in they can test it with a meter to make sure that this is the problem before a board issue is determined. It is difficult to diagnose this kind of things without the machine in front of me. My advice is to take it in and have the power investigated.
Just because the lighting on the battery is going and showing signs of life does not mean the power button is not bad or not getting the proper power to start the computer. It seems to me that the power button board is bad. Or the input cord pin may be shorted out and only supplying power to the mains but not the power button circuitry. Just a good guess!......John
May 11, 2012 | Dell Inspiron 1150 Notebook
I have a dell inspiron 1150 when i connect the charger the battery and the power light keeps on blinking and nothing happens oh turning the power button
Sounds like the adapter is being overloaded ... Dell is one of 2 or 3 manufacturers using a 3 wire adapter plug jack. And ... well ... lets say they can be problematic ... it's a great system but very sensitive to battery malfunctions. I suggest you remove the battery then pug the adapter in ... if all is OK then have the battery checked
Feb 23, 2011 | Dell Inspiron 1150 Notebook
1150 dell inspiron. Laptop won't power up. If
This seems an issue with inverter board need to checked by an expert.
thanks
Jul 27, 2009 | Dell Inspiron 1150 Notebook
Screen on Dell Inspiron 6000 turned sideways. How
Power off the laptop.
Power it on and tap F2 at the Dell logo. check if the screen is sidways in the BIOS or not. If it looks normal in the BIOS restart the computer and go to control panel and uninstall the Video drivers. Restart the computer. It will boot up with basic drivers. Install the video drivers and the issue should be fixed.
If the display is side ways even in the BIOS try a BIOS update from support.dell.com and if you dont have an update reflash the BIOS with teh version availbale on the website.
Jun 18, 2009 | Dell Latitude D600 Notebook
Dell Inspiron 1150 Blue Screen
Here is the list of all the drivers and downloads for your model. http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=INS_PNT_P4_1150&os=WW1&osl=en&catid=&impid=
Feb 16, 2009 | Dell Inspiron 1100 Notebook
Dell inspiron 1150 won't turn on
Remove the battery the memory the ac adapter,the hard drive, the cd rom.Press and hold the power button down for twenty seconds.try again if no go you will have to replace the systemboard.
Good luck
Jan 13, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Dell inspiron screen problem
-Yes you can reseat the lcd cable, follow some steps on your manuals ,If you dont have manula download the manuals from support.dell.com use your service tag. after reseating the lcd cable and still the screen is half ,try external monitor if the desktop is displaying properly may be you can consider that the lcd screen back light is damaged.try replacing the whole LCD or bring the whole system to a local store and repair the lcd back light.
Oct 11, 2008 | Dell Inspiron 1150 Notebook
Dell Inspiron 2200 Notebook Logo
73 people viewed this question
Alun Cox
