Question about Maxtor One Touch II E01H300 (EO1H300) 300 GB Hard Drive
My system WindowsXP stopped reconizing my maxtor HD
My System (XP) no longer sees my Maxtor external HD
  • seabpa Sep 16, 2008
    My XPS computer is no longer recognizing my Maxtor, why?
Mon cd d'installation est gater
Posted on Jul 14, 2008
I have a Maxtor 3100 100gb external HD and tried to backup my computer and it would only backup 4gb. I got a message that if the HD is formatted in FAT32 it would only backup 4gb. I need to backup about...
1. Please connect you external HD to your computer
2. Fat32 can only handle a limited amount of data
3.Go to the Control Panel
4. Open up Administrative Management
5. Open Computer Management
6. Open Disk Management
7. In the denter panel you will see your Maxtor expressed
8. Right click on the drive
9. Click format
10. Choose NTFS
if not given the coice, it will usually format to NTFS anyway, but get smart, explore Disk Management and make sure
11. I'm giving a general scenario across 3 different Windows OS Sytems
12. When you tell us your exact Operating System, we can be more helpful
TheSelkie
Oct 04, 2010 | Maxtor Personal Storage 3100 (M01E100) 100...
I have Windows XP with service pack 3. My system no longer recognizes the Maxtor 3200 external hard drive. Do I need to get an updated driver to the hard drive? When I first connected the Maxtor HD. ...
When you plug in via USB, does the USB recognize it and not display as HDD? If that is the case, then it's probably disabled somehow. Access Computer management, and check from there.
If that doesn't work, try on a different computer. If it doesn't work, your HDD has gone faulty. And if you recently changed your board, make sure you have a high speed USB port.
May 24, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
Cannot get external hard drive to work
- Make sure that the hard drive (HD) is properly connected to the computer.
- Try connecting it to a different computer to make sure that the HD is the problem.
- Check the Disk Management in your computer to see if the HD could still be detected. Once detected, reformat the HD and it should work again.
To check the Disk Management:
NOTE: Make sure that the external HD is connected and turned ON.
1. Right-click "My Computer" (XP) or "Computer" icon (Vista)
2. Select Manage and click on "Disk Management".
3. From the Disk Management, you will see a drive letters
4. Write down all the drive letters and then disconnect the Maxtor HD from the computer.
5. If there's a drive letter that disappears, then that is your Maxtor HD.
6. Reconnect the Maxtor HD and reformat it. You may right-click the drive letter and there's an option to format the HD.
If you're hearing a clicking sound while the HD is turned on, mostly, it's already defective.
Have a great day!
Oct 17, 2009 | Maxtor Hard Drive
MAXTOR EXTERNAL HD IS NOT OPENING
Does it give you an error message ? Are you running Windows XP or Vista? If so post it here so the problem can be further narrowed down.
You might want to try a chkdsk.
In Windows XP and Vista both, a shortcut to get to the command console is holding the Windows Key and pressing R.
in the command console, type:
chkdsk X: /f /r
Where X is the drive letter of the drive giving you problems.
This will run a chkdsk on your external, restoring files and folders that cannot be accessed.
I also have a Maxtor External hard drive and have to do this quite often. It's pretty frustrating.
Apr 04, 2009 | Maxtor 160GB OneTouch III Mini USB 2.0...
My pc dose not come up my maxtor basics external desktop hard drive
What OS are you using? Windows 98SE does not always recognize exterrnal hard drives. Try the external HD on a computer running Windows XP and see if that works. If it works on WinXP and not Win98SE or possibly WinME the External HD is good.
May 06, 2008 | Maxtor Hard Drive
No longer recognized by Win Me PC
UNINSTALL THE HARD WARE FROM THE SYSTEM ..UTILITIES FOLDER IN CONTROL PANEL
IF ITS RECOGNISED THERE IT MEANS THE DRIVE NEEDS THE SAME WIN ME DRIVERS WHICH COULD BE CORRUPT
YOU CAN TRY TO CONFIG IN SETUP TOO.
CONFIGURE THE HD IN HARD DISK DETECTION NOT AS AUTOMATIC IN BIOS , BUT AS LBA MODE DEFINING THE CYLINDERS AND THE HEADS AND OTHER DATA WHICH IS USUALLY WRITTEN ON THE HD WHITE COVER.
May 04, 2008 | Maxtor One Touch III 500GB FireWire/USB2.0...
Maxtor One Touch III mini ext HD 120 GB
I am not sure what model you have but the Maxtor hard drive downloads site has many system drivers, original software and Vista driver updates. The site is located at:
http://www.seagate.com/www/en-us/support/installation_assistance/installation_instructions/external_drives_&_personal_servers/ot3
If that does not work contact Seagate (they own Maxtor) at 1.800.SEAGATE (1.800.732.4283).
Feb 12, 2008 | Maxtor OneTouch III Mini Edition 120GB...
Maxtor OneTouch II 300Gb can't recover data after a system restore
I had the same problem a few weeks ago.
The way I solved my problem was to make sure when I restored Windows to the default settings that I did it up to the same support packs and hot fixes then when backing up the system with the Maxtor HD. It took me many days to figure this out... was written it the Maxtor HD documentation and it works fine.
Hope this helps.
Chris
Jan 15, 2008 | Maxtor OneTouch II external hard drive...
Maxtor personal storage 3200 problem!!!
I will tell you how to solve it, but this will void your warranty!
I had the same problem. What i was intended to open the box take the HD and use it as an internal HD.
When I opened the box I saw the HD jumpers were set on Cable Select I picked the jumper and plugged it to Master. Plugged it back to AC power and USB. It works. I donno why but it just worked.
Good Luck!
Nov 21, 2007 | Maxtor Personal Storage 3200 (U01E200) 200...
Get a Code 10 and yellow circle
You can check if your external hard drive is detected by the BIOS during bootup. You can also check this by Right click on taskbar > properties > startmenu > customize > advanced > scroll down completely and select system administration tools "Display on the all programs menu" > ok. Click on start > all programs > administrative tools > computer management > double click on storage. click on disk management(local) here you should see your lacie. If you dont then the drive is probably not detected. If you see, you can just partition it from here and it will appear in your my computer. If it is indeed detected, you will have to use a application like Recover my files to recover your data and then partition and format the drive.
Nov 19, 2007 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor One Touch II E01H300 (EO1H300) 300 GB Hard Drive Logo
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
