Question about GPX HI2817 Shelf System
Setting alarm I have tried setting the alarm and have followed the instructions in the manual given me and the alarm never goes off when supposed to. I have also noticed that it is difficult to set the alarm when the radio is on it has to be off.. Can anyone hlep.. than you
Alarm can only be set or disabled when the power in "Standby" mode. The manual refers to it as power "off" mode, but the LCD display will still be readable only darker. To set the alarm push the Standby button until the sound stops and the LCD is dark. Then push the AL SET button (which doubles as the volume down button when the power is "on"). The hour should start flashing. Adjust the hour by using the two buttons at the bottom on the right side just above the IR sensor. Once you've set the hour, push the AL SET button again and similarly adjust the minutes until you have the right time that you want the alarm to go off. Now push the AL SOURCE button (which also doubles as the function button when the power is "on") to toggle between Radio, CD, iPod or buzzer for your alarm. After you're satisfied that the time is right and the source is right push the AL SET button again. The LCD should still be dark, but should also show the word "ALARM" in the upper left hand corner.
To set the unit so the alarm doesn't go off push the "Standby" button until the sound stops and the LCD is dark. Push the AL SET button until the hour is flashing. Don't bother to adjust the time, just push the AL SOURCE button until none of the following appear: CD, iPod, Radio, Buzzer. As you push the AL SOURCE button it will toggle between these options. Once you're sure none of them appear on the left of the display, click the AL SET button again. The LCD should still be dark, and you should not see the word "ALARM" in the upper left hand corner.
Posted on Mar 13, 2010
Discovery kids rocket clock - no manual
I can't upload a manual but I can give you instructions:
1) set time: hold down "time set" button for five seconds, then use up and down arrows to change, and press "time set" button once to toggle between m/d/y/hour/minute. If it goes to the alarm setting instead of time setting, try again.
2) set alarm: hold down "alarm set" button for 5 seconds, use up and down arrows to change, press "alarm set" button once to toggle between hour/minute. press "time set" button to return to clock
3) turn on/off alarm: press "alarm set" button once, press "up" to turn alarm on and press "up" again to turn alarm off. press "time set" button to return to clock
4) to project the images: push the buttons that read "time" or "image". to focus the image, rotate the cylinder around the lens that projects the image. use the dial under the lens-cylinders to select a different image
5) military time: press the "up" button when the time is displayed (not when you're setting the time) to change from 12 to 24 hr or vise-versa
Good Luck!
Dec 03, 2012 | Discovery Channel Discovery Kids - Rocket...
I have an Armitron 40/8125 watch. I try to set the time as follows 1)Hold B - Alarm hours flash 2) Press C - Alarm minutes flash 3) Press C - It goes back to Alarm hours flashing where it should advance to...
You need to press button A to enter the time setting mode and then press C.
If you have lost your instructions, you can get instructions from the Amitron web site.
Copy "www.armitron.com/watch_instructions.asp" into your search engine and you will see a list of illustrations of watches and associated
instructions.
Choose the one that looks like yours and download the PDF file.
Mar 18, 2010 | Armitron 40/8125BLK Digital Sport Watch
ISymphony CRDCD clock radio alarm programming
Play around with the Alarm1 button, test it every minute and when it goes off press Alarm1 again to stop it, not snooze. Then try pressing vol + as nothing is playing. Keep trying until your alarm goes off at the desired volume that you put in your Alarm1 settings
Mar 07, 2009 | iSymphony CR8CD CLOCK RADIO MUSIC SYSTEM...
Setting time/date on old Seiko
With our 10 year old grandson's help, my husband was able to figure it out. Took a while, but he is now wearing his watch again!
Thanks for the follow-up.
Feb 08, 2009 | Seiko Watches
Alarm problems
When creating a new alarm, the LG Shine will start with the "Set Time" function where you can set a 15 minutes alarm jump (by moving the navigation button horizontally). If not desired, you can go one step down onscreen to set the alarm time manually. If you accidentally jump back to the 15 minutes jump method in the previous function, it will automatically postpone the alarmsetting with 15 minutes increments again. Please verify you don't use that function by accident while setting up the alarm time manually. If all of this is not the case, I would suggest to return the phone because there could be a problem with the phone or software.
Feb 06, 2009 | LG Shine KE970 Cellular Phone
Good Morning. I was given this alarm clock which is driving me crazy cause i cant figure out what to do. I tried researching the internet for a manual, but failed. It is a RCA CD Clock dual wake Radio....
Following are the instructions for the RP5610 which looks very similar to the 4801A (that I also have). The only difference in the instructions is that the 4801A doesn't have a clock icon, just press the SET button until the center colon dots are flashing, Press the rewind or fast forward arrows on the circle next to it to set the time. Set the alarms by pressing the set button until bell 1 or 2 is displayed. Nap is also set with the set button - not sure how to stop it yet.
To set the clock:
  1. Press the SET button until the clock icon is displayed (circle with hands at 10 and 2)
  2. Press |<< REV or >>| FWD to set the time.
  3. AM or PM icon will show besides the time.
Dec 24, 2008 | RCA Radio Alarm Clock
Alarm clock and time w/ clok smooth ipod system
According to the instructions that we received with our clock. You should be able to get the Instruction manual from prodinfo@gpx.com. It is also supposed to be under the support section of the website www.dpi-global.com but I couldn't find such a link.
However the "Operational Support" insert has the following:
Setting the clock
1. With the unit powered off, press and hold the "Clock/Display/Play/Pause Button" for at least 4 seconds.
2. While holding the "Clock/Display/Play/Pause Button", press the "Hour" and "Minute Buttons" to adjust the hour and minute on the time.
3. When the correct time is selected, release the "Clock/Display/Play/Pause Button" to set the clock
Setting the Alarms
1. With the unit powered off, press and hold the "AL1" or "AL2" Button for at least 4 seconds.
NOTE: An alarm icon will begin to flash on the LCD display.
2. While holding the "AL1" or "AL2" Button, press the "Hour" and "Minute Buttons" to adjust the hour and minute on the alarm time.
3. When the correct time is selected, release the "AL1" or "AL2" Button to set the clock.
4. Press the "AL1" or "AL2" Button consecutively to switch alarm one and alarm two between sounding to a buzzer, the currently set radio station, or a docked iPod.
Nov 28, 2008 | Digital Products International Clok Smooth...
Emerson Smartset alarm clock
Hi - You can download the manual from the link underlined in blue below:
CKS3528
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Jun 25, 2008 | Emerson Smartset Clock Radio
Alarm goes off at midnight & repeats for half hour, and not set
what you have to do is
1. press the mode button until you get to the setting that has "AL" at the bottom right.
2. then you press the "receive" button to switch between the four alarms.
3. as you are going through each alarm time, you need to look in the circle at the top right. When you are going through the alarm times, if there is a mark next to "ALM", you need to press the "time memo" button so that the mark next to "ALM" is no longer there.
4. repeat step fout for all of the alarms, and the problem should be fixed.
Apr 13, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Setting alarm
You can download the manual from the link below: http://emersonradio.com/owners/SmartSet%20Series/CKS3020_072706.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 27, 2007 | Emerson CKS3020 Clock Radio
GPX HI2817 Shelf System Logo
175 people viewed this question
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
