Question about KitchenAid 24 in. KUDI01ILBS Stainless Steel Built-in Dishwasher
Upper rack dishes dirty
Water is not getting to the dishes in the upper rack.
  • 2 more comments
  • bailey4266 Jul 17, 2008
    yes, it is filling with water, but the top rack sprayer is not working, only the bottom sprayer
  • Anonymous Sep 22, 2008
    same prob
  • Anonymous Feb 12, 2009
    I have the same problem. The upper dishes seem to end up dirtier than they started.
  • Anonymous Mar 15, 2014
    bottom rack worse than top rack
    Novelist:
  • 161 Answers
Is it filling with enough water. Look or if you don't know how much water is supposed to be there , Just add a gallon of hot water to the machine after it fills. If this solves the problem check the filter in the fill valve or replace the valve.
Posted on Jul 05, 2008
Why are my dishes still dirty
Try adding some TSP (tri-sodium phosphate to your dishwashing detergent.
Aug 05, 2014 | Whirlpool Dishwashers
I have a maytag quiet series 300, dishes dont get clean on top rack and sometimes it doesnt drain. do i need to clean some trap or drain?
Check the screen area around the sump right below the lower spray arm if it is built up with lime deposit then the wash pump is starving for water and cannot pump water to the upper spray arm this would also starve water to the drain pump.
Mar 06, 2014 | Dishwashers
Kenmore 3380957 rev a won't get dishes clean
Make sure that that upper arm is free to turn. Check it while you have dished installed, because sometimes, dishes on the lower rack may stick up too high and hit it. Otherwise, check the back of the water-supply tube attached to that upper rack.... Is it lining up with the water feed port or hole at the backof the dishwasher? Is there a gasket that is either ripped or missing? And check that wash arm carefully.... Might it be split or bent? Are the holes on the bottom clear? (Those holes are usually angled to push the arm around; if they are clogged, the arm won't rotate.)
Mar 15, 2012 | Kenmore Dishwashers
My dishes come out dirty and glasses are cloundy.
#1 check the upper spinner arm to see if it is clogged with particles if it is, clean the holes outi f they get clogged the arm-sprayer will not clean the upper rack
#2 if it is not clogged got to your local Grc.chain and purchase a bottle of dishwasher cleaner for about 8.00 follow all instructins on bottle make sure water is hot by running hot water tap closest to dishwasher.use it in an empty dishwasher.You will be amazed how clean your dishes will come out after the first wash
Jan 23, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Kitchenaid KUDP02CRB - top rack dishes are not getting clean
maybe not... if unit is incorporating more than one spray arm,chances are the upper spray arm is not getting water.pull top rack forward,gaze under top rack near rear manifold.slowly push rack back in.notice if manifold inserts into upper wash feed.if so,possible motor issue. if not,bingo was his name-o!
Nov 13, 2009 | KitchenAid Dishwashers
Will not clean dishes on the upper rack
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
Jun 16, 2009 | KitchenAid KUDR01TJ Dishwasher
Dishwasher repair - Bosch
Can you remove the upper spray arm (is yours under the upper rack?)-mine unscrews and then you have to wiggle it off. Run faucet water into the arm; sometimes little bits of crud get stuck in the holes that spray the water out, and this prevents a complete rinse. I just had to clear these holes myself due to same problem (I might have a different machine, though). You can do the same for the lower arm.
Jan 25, 2009 | Dishwashers
Dishwaser not rinsing properly
I had this problem twice with my Bosch and both times required different fixes but they both worked. 1. I got this one out of the manual. Make SURE that you push the upper rack totally back. There is a connection back there that fits into a fitting on the back of the rack and pushes the water through the upper arm. 2. I had taken off the extra rack that attaches to the back of the lower rack. Then I put it back on wrong. It should not have the prongs appearing behind the rack. Both of these situations caused cloudy/dirty dishes. Also, because of the lack of water, it clogged up the filters. Remove the filters and clean them well. Then make sure you have neither of these issues going on. My dishwasher returned to great washing.
May 01, 2008 | Dishwashers
Dishes not getting clean
brittgee, there has been a number of service flashes on this model. One that has to do with the upper spray arm assy. Complaint is poor washability; gritty glasses, food redeposited on glasses, especially in the corners. They redesigned the upper spray arm to improve water spray to all corners of the upper rack. The new part number is 8269022. They also redesigned the third level spinner for more consistant rotation and better washability. This was also under a service flash. Part number.8193768. Other reasons for poor wash would be; low water temperature, rinse aid disp. not working, loading etc. Catriver...post back.
Nov 25, 2006 | Kenmore 24 in. 15933 Built-in Dishwasher
Open Questions:
See all KitchenAid 24 in. KUDI01ILBS Stainless Steel Questions
KitchenAid 24 in. KUDI01ILBS Stainless Steel Built-in Dishwasher Logo
449 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
