Question about Mitsubishi WS-65869 65" Rear Projection Television
WS-65903 HD1080 view on screen is wider on the edges than in the middle. edges are slightly out of focus.
  • ksw1958 Jul 04, 2008
    Even on standard format I have a full screen except in the middle. Kind of a reverse fisheye effect. The effect follows all formats, the middle is has a black curve on top and on bottom that dissapears at the edges.
    That fixes it when you turn it off and then turn it back on,--- uppps spoke to soon --- it just went back. It was ok for about 2 minutes.. Is there any particular manuel or parts list needed to correct this thing. (I dont have any cable box nor anything else, it plugs directly into the coax from the cable company.) (in answer to your first question)
  • 2,071 Answers
When horizontal amplitude is too small ,generally the right part of the picture shrinks more than the left part .It is presumed that the horizontal sawtooth wave current passing through the deflection coil is too small in amplitude . In order to change the horizontal amplitude ,you have to change the magnitude of the saw-tooth wave current that passes the deflection coil. The amplitude is adjusted by the variable inductance connected in parallel with part of the winding of the flyback transformer .If this inductance is made smaller the local current passing here will grow larger and as a result the deflection current going to the deflection coil will become so much smaller and the amplitude of the deflection will be reduced.The most logical cause of narrow picture that cannot be corrected by adjustment of the width control is insufficient horizontal drive .If the problem is in the horizontal oscillator circuits it will show up as a low output waveform from the horizontal oscillator.The most likely defects are open emitter capacitor in the horizontal oscillator transformer ,possibly off-value resistors.However,any number of defects could produced a low output.
The first step is to isolate the problem to the horizontal driver or the horizontal oscillator by waveform measurement .If the problem is in the horizontal oscillator keep in mind that the trouble can be in the AFC section.
Find a technician to do works for you , in order to avoid high voltage shock...
Posted on Jul 04, 2008
  • 105 Answers
I think the settings of the tv had been changed .try to reset it to the older level by adjusting the settings or by using the reset key.thankyou
  • 51 Answers
Press format key on mitsubishi remote control and try to get full screen.let meknow if it works if not do you have a cable or satellite box and what type?
  • DOUGLAS HERNANDEZ Jul 04, 2008
    turn tv off and wait 5 minutes and see if picture comes back to normal .This sets are know for having convergence problems giving you the fisheye effect, the solution to that is resoldering the convergence ics 2 of them, or replaced them STK392570
On my HD1080 Mitsubishi projection flat screen the picture is bowed on top and bottem and it look as if the projectors themselves are offset, but the picture is clearer as you come toward the center. If I...
You have poor contacts and or dry joints. Resoldering on the convergeance panel and powersupply/line timebase board will probably fix it.
It should take less than an hour in labour terms.
Feb 20, 2011 | Mitsubishi WS-65809 65" Rear Projection...
I have an mitsubishi medallion hd1080 big screen tv model# ws-55819 getting code 1,2. (hold the menu and input)
Try to unplug set and try it again as if the set was unplugged and then the self check done it will be 1,2 which means NO ERROR detected.
Let me know also what the set does?
SD TECH
Feb 17, 2010 | Mitsubishi WS-55819 55" Rear Projection...
Slight color changes on both sides of the screen
What you have , sorry to say is burnt CRT's this is caused by watching tv in the 4.3 mode , which shrinks the pic on both sides. so now the phosferous on each crt is only use in the center, that leaves the outer edges fresh and as new
There is no way to fix thin outher than replacing the crts sorry
Nov 23, 2009 | Televison & Video
Ribbon appears on the screen of mit ws 65903
It may be a problem in the TV but can also be caused by a poor RF connection either at the back of the TV or the satelite receiver. That of course would not be an issue if you are connecting your satelite via a composite or component or HDMI input.
michtech
Feb 12, 2009 | Mitsubishi WS-65903 65" Rear Projection...
Mitsubishi 55" 1080HD
it sounds as though your convergence board is going out or gone out
Oct 23, 2008 | Mitsubishi WS-55613 55" Rear Projection...
No picture
thats  it. The fuse for the main board which powers the CRTs is broken.Tell me one thing do u have sound when you switch it on?
Oct 14, 2007 | Mitsubishi WS-65903 65" Rear Projection...
Screen is distorted on the top and bottom
Loose connection on convergence board, you could tapp and should go back to normal, find loose conn. and solder back.
Sep 09, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi WS-65869 65" Rear Projection Television Logo
133 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
