Question about Whirlpool Washing Machines
Need instructions to replace the rubber boot (door bellow) on the whirlpool duet washer GHW9200LW
  • Anonymous Mar 16, 2014
    whirlpool duet door bellow screw broken
  • 5,911 Answers
Here ya go...follow this link:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
If you get stuck along the way and/or require further assistance, please let me know. I hope this helps you.
Posted on Jul 04, 2008
On my whirlpool duet washer the little pin in the door (black) that pushes in when shut broke and now my washer wont kick on
Is this pin on the door or the frame? If the frame then you need a new door lock assembly that you replace by peeling back the rubber tub bellow after removing retainer spring.
Sep 23, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer ghw9250mw1 door won't close (latch will not catch and lock shut) How to fix?
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
http://media.fotki.com/1_p,wkkrqtwwwgtsgwdxgtqsskgwtqkq,vi/krqsddwkbxktttdstrw/1/1303472/5961857/image48287img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet troubleshooting
1. Unplug washer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!@#$
Mar 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet washer give code "F dL. What is it and how to fix?
1. Unplug washer.
Mar 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washer leaks. It is not the
The following link explains how to determine where a leak may be coming from in a Whirlpool Duet:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
In many cases, the rubber bellow (door seal) is the source of the leak and will need to be replaced. If the bellow is ripped or torn the following link explains step-by-step how to replace one:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
NOTE: THe bellow does wear out from time to time and will need to be replaced. However, using too much detergent, the wrong type of detergent, or loading the washer excessively can contribute to premature wear and tear and deterioration.
If you have any questions, or are having problems determining where the source of where your leak may be coming from , please post back and let me know. I hope this helps you.
Dec 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer leaking water
If the washer is leaking around the door area, more than likely the bellow (rubber seal) is ripped or torn. If you pull back the rubber folds in the bellow and inspect, you may find a rip or tear causing your leak.
Another cause can be the rear bellow clamp (clamp that is affixed to the front of the wash tub) can come loose causing a leak between the bellow and tub. All you may have to do is tighten the clamp if this is the case.
The dispenser tube on the left hand side of the door, if not seated through the rubber correctly, can also leak during the fill or rinse cycles. The tube should be inserted through the rubber in the bellow to the flange on the tube. If not, water can fill behind the rubber and drip into the bottom washer casing.
The following link explains how to access and/or replace the the door bellow on a Whirpool Duet:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
Searspartsdirect.com, appliancepartspros.com, pcappliancerepair.com and repairclinic.com carry the bellow. All these sites offer competitive pricing, so shop all of them for the best deal.
If you have any questions, or require addtional assistance, please let me know. I hope this helps you. NOTE: The bellow can also become mishapened over time after frequent use. This can also cause leaks around the door. Look to make sure the bellow is sealing around the door glass. If not, it should also be repalced.
Jul 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Moldy smell in Whirlpool duet GHW9200LW
The part you are referring to is called the door seal, or door boot seal, or door diaphragm
Look in yellow pages for whirlpool service if you live in the u/k.
Please rate my solution.
Thanks.
Jul 29, 2009 | Whirlpool GHW9200L Front Load Washer
Terrible mildew type smell
Water forms in the Bellows it is a rubber boot between the door the drum.. clean this out real well ..To prevent this in the future leave the door cracked open when you are done using the machine to allow it to dry out.
Aug 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
I'm trying to replace the rubber liner in my whirlpool duet washer. Our puppy bit a small hole in the rim, and it now leaks. My husband ordered the part, but can't figure it out.
If you are talking about the gray rubber boot around the door, it is called a "bellow". The following link will provide you with step-by-step instructions:
If you get stuck, or require further assistance, please let me know. I hope this helps you.
Jul 05, 2008 | Whirlpool Washing Machines
Rubber door seal rip...
The rubber door boot (bellow) commonly wears out on these front loaders. A replacement will run you about $80 just for the bellow. Labor could run as high as $180 if you decide to hire someone to replace it for you. If you wish to perform the repairs yourself, post back with your intentions and I can provide you with step-by-step instructions on how to replace it. It is labor intensive as you will have to remove the entire washer front in order to do the job right. It IS possible, however, if you wish to pursue a repair option on your own. Just let me know.
PS I can also provide you with the part number if you reply with your washer model number (found along the door opening).
Nov 06, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
341 people viewed this question
Dan Webster
Dan Webster
prem mathew
