SOURCE: I need a power supply for a tascam 424 mk iii. It
Check these out: http://www.audio-depot.com/index.php?main_page=product_info&products_id=1571¤cy=USD
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=350275805259&rvr_id=&crlp=1_263602_263622&UA=M*S%3F&GUID=c3a1fd4411e0a0b586e289a2fff2035d&itemid=350275805259&ff4=263602_263622#ht_600wt_941
Testimonial: "Thank you very much!"
SOURCE: I have a Tascam 424 mkIII that I just got in the
You may have a bad impedance matching situation. Check the level at the headphone jack for starters. If that seems low, there is a problem with the playback amp, which may be the same as the record amp in that model, I'm not sure. The switching mechanism that flips the amp from record to play may be hanging up. Start with the headphones. If that's good, your impedance match is way off, or you simply are using a bad cable, as it feeds from the same amp as the outputs in most cases.
