Question about GE GBS22HCR Bottom Freezer Refrigerator
Freezer works refrigerator doesn't
My wife cleaned the fridge leaving the door open for some time and now it doesn't seem very cold.
Freezer is working fine.
Any thoughts or suggestions or do I need to call a repair service?
Thanks for your help,
Joe
    Novelist:
  • 161 Answers
Try finding the defrost timer and slowly click by click turn it just until the compressor stops. let it finish the defrost cycle. Let it run for about 3 hours then do it again. Sometimes if the frost builds up too much the defrost system can't handle it. If you can't find the timer, take out the food, unplug it and leave the doors open for at least 24 hours. Then plug it back in. It can take up to 10 hours to cool down completely. Use a thermometer. you should be around 38 degrees in the fridge and between 0 and 10 degrees in the freezer.
Posted on Jul 04, 2008
My freezer works but my refrigerator part is not cold
The is normally a duct between fridge and freezer which can over ice can take 3or 4 days to defrost with both doors open and unplugged.
Jan 14, 2014 | Refrigerators
Subzero 532 refrig fan(& compressor) doesn't shut off
the higher the number on a fridge the warmer it is so setting it to 1 is close to 0C
when working on a fridge or freezer always turn it off at the wall
if the fridge is keep cold but not cold enough set it back to say 3
if the compressor is running and the back fins / wall is hot then the fridge is working
use a piece of paper between the door seal and the fridge edge to ensure that it is sticking to the fridge and sealing off properly
Jul 16, 2017 | APW Wyott SubZero Refrigerator Freezer...
LG gn253sqa electro cool- temp. control lights in fridge keep flashing and fridge not cooling so good, help?
This has happened to me a couple of times.The problem is that when the fridge door is opened too may times the warm air of summer will block the cold outlets in the fridge with ice.The cold air comes direct from the freezer and the chamber connecting to the fridge clogs up with ice.What one has to do is completely empty the fridge and freezer,leave open both doors so the the ice build-up can melt.Then after about at least 4-5 hours (very important to stick by this time-frame as I tried a less time,but it did not work.),close both the freezer and fridge doors and switch it on.After about 1/2 hour replace your goods in the fridge.The down-side of this is that you will need the kindness of a neighbor or two to use their fridge to store your food whilst this fix is underway..
Feb 28, 2013 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator not cooling. doesn't seem like fan is blowing. freezer still working
all that happens is the cold air from the freezer gets blown into the fridge section by the evap fan motor brhind the inside back wall of the freezer so if you open the freezer door and don't hear the fan blowing i would say that yes you do have a bad evap fan motor and that's why the fridge section is warm.next time send the brand name and model number so i can help you better
Sep 17, 2011 | Refrigerators
We inadvertently left the freezer door slightly open the frrezer ran continuusly for twenty four hours. Would this cause the condenser to frreze up and burn out? The frrezer is still cold and we...
leaving your freezer door open does nothing ,but work the freezer harder,,,it wont cause no of the prolems you stated,,it will cause your electric bill to rise ,,your ok...the condenser is part of the seal system and it exspell the heat usally under the fridge...good luck
Sep 03, 2011 | Kenmore Top Freezer Refrigerator
Fridge not cooling, Freezer is working (upside down fridge/freezer)
We experienced a smilar problem with your Fisher & Paykle fridge/freezer.
The fan that sends cold air to the Fridge section of the appliance didnt appear to be working leaving the Fridge poorly cooled.
I suggest the first step is to turn the fridge off and leave it to totally defrost.
Build up in ice in the freezer section seemed to have an impact on the proper operation of the fan which seems to relie on a thermostat for its operation.
Having defrosted and cleaned the fridge the problem was solved.
The fans have a delay before switching on after the door is closed. Place a magnet over the door sensor switch and wait to see if the fan works.
The problem could be that the unit has iced over itself over a period of time and defrosting it could solve the problem.
Feb 28, 2011 | Fisher and Paykel Active Smart E522B...
There is a sweet smell seemingly coming from my refrigerator when I open the door (either refrigerator of freezer door). It spreads through the house. Is it the coolant? Is is possibly leaking. And...
I thing something leaked in either compartment. remove all items, clean the fridge with soap, water and vinegar, then turn it on and leave baking soda in both fridge and freezer.
Tony
Jan 14, 2018 | Refrigerators
Frost on back of bottom freezer of a 3 year old kenmore
how long did you leave it unplugged? it's possible all the frost didn't defrost .you need to leave it unplugged and the doors open for at least 12 hrs.
May 20, 2009 | Kenmore 76283 Bottom Freezer Refrigerator
Fridge not cooling
hi there.
welcome to fixya.
initially try to defrost the ref and clean it.
Feb 26, 2009 | Amana ASB 2623 Side by Side Refrigerator
GE GBS22HCR Bottom Freezer Refrigerator Logo
149 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
