Question about Canon MultiPASS C530 InkJet Printer
Can not install printer
Cannon C530 printer
  • JEANP74 Oct 22, 2008
    1. CAN NOT INSTALL CATRIGES
    2. NEEDS HELP INSTALLING THE INK.
  • Eduardo Perez
    Eduardo Perez May 11, 2010
    What kind of problems do you have?
    Errors?
  • 92 Answers
Follow the below steps and I am sure you will face no problem. This is to install the printer software ..
  1. Visit Canon's website at www.consumer.usa.canon.com.
  2. Click DOWNLOAD LIBRARY from the top menu.
  3. Select 'Multifunction' from the first drop-down list, 'Inkjet' from the second drop-down list, and your model from the third drop-down list.
  4. On the DOWNLOAD LIBRARY page for your model, click on the 'Drivers / Software' link and you will be presented with all driver files available. Find the file(s) appropriate to the operating system you are using (ex. Windows 95, 98, Me, NT, 2000 and XP). Please take note of any "update" files that may be listed. These will ensure that your drivers work properly with operating system modifications, such as the updater for Windows XP Service Pack (SP) 2.
  5. At the bottom of the DISCLAIMER screen click on [I Agree - Begin Download].
  6. When you reach the download screen for your selected driver, you will find detailed instructions to assist in installing the files. You may wish to print these instructions (right-click in the window and select 'Print') or remember how to get back to them for later reference.
  7. On the File Download screen you will be asked, "What would you like to do with this file?" Be sure that 'Save this program to disk' is selected and then click 'OK'.
  8. On the Save As screen, make sure 'Desktop' shows beside 'Save in' and then click 'Save'.
  9. Once the download says it's complete, verify the file size. (Right-click the downloaded file on the desktop and click 'Properties'.)
  10. When you have confirmed the file size to be the same as previously noted, close the Properties window and double-click the filename to start the extraction and install process.
Posted on Apr 29, 2009
  • rajonline Apr 29, 2009
    Installing / Replacing the BJ Cartridge
    Follow this procedure to replace the BJ cartridge:
    1. Make sure the MultiPASS is plugged in.
    2. Open the document tray.
    3. Lift the document guides to open the ADF (Automatic Document Feeder).
    If the ADF (Automatic Document Feeder) does not open easily, slide the document guides outward and then open the ADF (Automatic Document Feeder).
    Or slide the Document Feed Lever to either the automatic or manual setting.
    4. Press. If installing the BJ Cartridge for the first time, skip to step 6.
    Caution: Do not try to manually move or stop the cartridge holder since this may damage the unit. Do not touch the components shown or any metal parts since this may adversely affect operation of the unit and/or affect print quality.
    The MultiPASS has an automatic protection feature that helps keep it from overheating. If the cartridge holder does not move, unplug the MultiPASS and let it cool for several minutes. Then plug it in again.
    Press to move the cartridge holder.
    5. Raise the blue cartridge lock lever on the cartridge holder and remove the BJ cartridge.
    Caution: Discard the old BJ cartridge immediately according to the local laws and regulations for disposal of consumables.You may want to place it in a plastic bag to keep any residual ink from spilling. Spilled ink can stain any surface; protect yourself and your work area. If removing a BJ cartridge to use one of the optional BJ cartridges, be sure to store the BJ cartridge in the container provided with your MultiPASS. Otherwise the ink will dry and affect print quality.
    6. Remove the new BJ cartridge from its package, then remove the orange protective cap (1) and tape (2).
    Caution: Discard the cap and tape. Never attempt to reattach them to the BJ cartridge print head. Install the BJ cartridge immediately after removing the cap and tape. Spilled ink can stain any surface; protect yourself and your work area.
    7. With the label facing outward, insert the BJ cartridge into the cartridge holder. Lower the blue cartridge lock lever until it locks into position.
    8. Press .
    The cartridge holder moves to its home position on the right side of the unit and begins cleaning the BJ cartridge print head. This process takes about 55 seconds.
    9. Close the ADF (Automatic Document Feeder).
    10. Close the document tray.
    Note: If you need to unplug the MultiPASS, wait until the unit is in standby mode (date and receive mode displayed in the LCD). Otherwise the cartridge holder may not be in its home position causing the BJ cartridge to remain uncapped and dry out.
  • 61 Answers
Cannon mp530 series
you need to clean your heads
Mar 03, 2009 | Cannon MULTIPASS C530 Printer
Print quality is poor
if you replace the black ink cart with an original one then it's the print head
Solution: Cleaning the Print Head - C555 / C560 / C635 / C530 / C545
Untitled Document Follow this procedure to clean the BJ cartridge print head:
1. Press c755funckey.gif 2. Press c755cleankey.gif 3. Use c755down.gif or c755up.gif to select the [HEAD CLEANING]..
4. Press c755set.gif.
The MultiPASS cleans the print head.
Feb 12, 2008 | Cannon MULTIPASS C530 Printer
Installing
I do not have a cd to install printer, what do I need to do
Dec 26, 2007 | Cannon MULTIPASS C530 Printer
Software for pixma iP 1700 printer
please help where to download driver for pixma iP1700 i needed badly
Nov 06, 2007 | Cannon MULTIPASS C530 Printer
Canon MultiPASS C530 InkJet Printer Logo
75 people viewed this question
old marine
old marine
