You finished a couple fine focuses there. mod kick I did a hunt on the subject and discovered almost all persons will oblige with your site. https://kickthebuddymodapk.info/
It is possible that your video card is Gone!!! Try to connect the monitor to another computer (to a laptop for example) to verify if it works properly.
For that when you power up the computer press F8 key then enter in enable vga mode .
Then go to display property and set screen resolution to 1024*768 then apply and ok.
if still not work then try safe mode then uninstall graphic driver and reinstall.
When you power up the computer press F8 key untill you see windows logo.
Let me know if you need further assistance.
Thanks for using Fixya.
On the majority of monitors the monitor goes into sleep mode when there is no input, but to turn off monitors altogether, on most monitors you press the power button to turn off the monitor altogether.
I have an hp media center that runs windows xp with service pack 3 and my monitor is an hpL1706 monitor and was running fine now it says no input and goes into sleep mode how do I fix it?
I had a similar problem whereas my monitor went to sleep mode after a few minutes. I'm running an HP LP 2065 in dual mode with another HP flat screen. However, I did resolve the issue after resetting the output settings.
How to do that:
right mouse click on the desktop
select graphic options
output to
extended desktop
Maybe some changings/modification will help you too.
