Question about Emerson EWR10D4 DVD Recorder
How do I connect my dvd recorder xbr716 to the television?
Hi I bougth a zenith dvd recorder/video cassette recorder and i dont know how to connect it on my tv .i need step by step connection. the model # XBR 716. thank you have tried all combinations i can think of-whats the correct way?
  • 3 Answers
Posted on Jul 24, 2008
Zenith XBR716 DVD Recorder / VCR Combo parental bypass
I don't know if this will work but try entering four 0 (zeros) first. If it doesn't work enter as many 0 (zeros) that you can and see if that works. Hope this helps :)
Apr 20, 2014 | Zenith XBR716 DVD Recorder / VCR Combo
The machine will play some DVDs, but frequently
COPYRIGHT PROTECTION FOR DVD`S AND VHS TAPES RENDERS THE ZENITH XBR716 INTO USELESS JUNK. TOSS IT INTO THE TRASH BIN.
Jan 05, 2010 | Zenith XBR716
Zenith XBR716 every time i tried to record a dvd in the unit saids copy right protected
Hey! Usually, DVD-Video has protections such as Content Scrambling System (CSS) and region codes. These protections are designed to prevent the DVD user making backup DVDs. If you want to copy DVDs, you need to remove DVD protections first. Usually, DVD Copy Software can be of help which can backup dvds by removing DVD protection. I recommend you use this DVD Copy software. Hope that helps.
Dec 08, 2009 | Zenith XBR716
How to record vhs to dvd
THROW THE ZENITH XBR716 IN THE TRASH.
Oct 24, 2009 | Zenith XBR716
My Zenith XBR716 won't finalize a dvd that it has recorded.
Wrote in by "Guest" on 01/04/2008..."The document for the XBR716 needs to be re-written and re-issued, because it is missing information on how to finalize the DVD."
Solution:
Press the HOME button, then go to Disc Manager.
Select the Finalize menu, Finalize and OK to start.
Apr 01, 2009 | Zenith XBR716
Trying to record movies I have recorded on my dvr, the old unit I had recorded everything. this one keeps telling me anything I try to record is protected. how do I turn that off or work around it?
Try getting a dvd recorder that connects to the video and audio ports and record to that. Im not 100% sure but I believe it records whatever it sees on the tv screen
Dec 30, 2008 | Zenith XBR716
Zenith 716
THIS RECORDER DOES NOT HAVE A TUNER BUILT-IN. YOU MUST RUN IT FROM "AV" INPUTS INSTEAD.
Sep 22, 2008 | Zenith XBR716
Tiene tu televisor entradas de audio y video,si las tiene no hay mucha dificultad para conectarlo,el aparato trae unos cables rca con diferente color rojo blanco y amarillo, el rojo y el blanco los vas a poner en las salidas (outputs) de audio del dvd las que son del mismo color,el conector amarillo lo vas a poner donde dice video output, y en la tv los conectas donde dice inputs en el mismo color del conector.Pones tu tv para entrada de video y ya esta.
Mar 23, 2008 | Zenith XBR716
Zenith xbr716
ALL cable is digital.
What type of TV do you have? Does it have any scart conections on it? If not connect the Cable box with a scart lead to your VCR select the AV channel on your VCR, connect your VCR to your TV via the RF connection, (if it has not got one, its not a TV, its a monitor). Tune your TV in to the video channel.
You do not need an RF modulator for a home TV setup, whoever told you that is a fool.
Dec 28, 2007 | Zenith XBR716
Emerson EWR10D4 DVD Recorder Logo
104 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
