Question about Philips TS2768C 27" TV
SONY KV32TS36 Is connected but not within the hearing OR CLICK. Test the power supply and delivery DC smoothly
Receiver doesn't play sound until it's warmed up 5 - 10 minutes
Unfortunately, your question has too many variables. Try this. Unplug the unit. Plug it back in. When you first push the power button, you should immediately hear one mechanical click from the unit, followed by a second click with 5-10 seconds. If you don't hear the second click, the unit may have a condition known as DC Offset. It would be unusual to have DC Offset only within the first 5-10 minutes. It's possible that power supply has an issue where both the positive and negative voltages are not coming up at the same time.
If you are interested in having your RCA repaired, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
May 22, 2015 | RCA RT2500 System
Tip
How to test your AC/DC Adapter or Computer Power Supply Unit.
A PSU or Power Supply Unit aka AC/DC adpater is then means by which a low tension (voltage) appliance receives its power from the 240 AV mains supply, the this is usually accompanied by the nominal current that is drawn from the PSU on load in milliamps. (e.g. 500mAmps = 0.5 Amps) most modern DC adapters are unregulated, where the output voltage is only regulated by the load current, and a smoothing Capacitor is sometimes used to reduce AC ripple on the DC Level.
If the PSU is regulated the DC Voltage that you measure using an AVO even off load will be the same as the rated current.
Also most, not all, are double insulated (indicated by small square inside a larger one) this means that it doesn't need a earth on the plug, the give away is a plastic pin instead of a metal one found in most domestic plugs with a 13A fuse.
Using Ohms Law P= I x V means that we can find out either the Current in Amps Power in Watts or the Voltage of any unit this is also called the VA rating
The Simple test is if the adapter gets really hot as soon as the you apply AC power then this may indicate catastrophic failure OR a dead short and you must turn OFF immediately the plastic may even start to melt, you may also smell electrical burning. This will also happen if you ever use a non-specific adapter on your device that has a different output voltage this will almost certianly cause damage to your device.
The main test if to test the step-down transformer using an AVO (Amps Volts Ohms) this is what is used to reduce the 240V ~AC voltage to something more in line with the required DC supply say 14-16V ~AC, a diode bridge converts this to DC, if it is regualted there will be either and either a zener or resistor drops this to the rated 12V and a capacitor to smooth the level.
You need to make sure this is socket is working correctly by checking with either a lamp electricians screw driver or a AC test plug, dont use this socket you have an earth fault or someother problem, usually two lines at the outside of a AC socket tester means all is correct.
  1. First measure the resistance (Ohms) across the two AC pins that is the Live and Neutral this should have VERY low resistance in the range 300 to 2,000 (2K) Ohms. if this is the case then your primary winding is probably OK if you see 1 on all settings this means open circuit (O/C)
  2. Then connect the power supply to a 240V AC socket, and check the output voltage with multimeter set at volts DC you should see a stable voltage of the rated value for a regulated adapter or slightly higher by about 5% if its unregulated as this is a reading off load, if you were able to test the voltage with the adapter on load you would see the rated DC voltage.
  3. If you connect an unregulated AC/DC adapter to the device and open up the cover to test it under load and the voltage is low around 5V or less then the adapter will need replacing even if the off load value appears correct in above test ( ** ref the table below)
NOTE: If you have a AC only output then the test done in 1 can also be done, if there is a diode bridge, Zener Dicde OR Capacitor on the secondary this test wont work so you might have to remove the cover by unscrewing the tamper-proof screws and test it before the connection to the PCB, without the power on of course, check out my tip HERE for help on how to remove the screws.
If you have a faulty power supply its usually the thermal fuse that blows on the secondary winding, this means that you will get considerably less Voltage at the output jack of around 5 VDC or less and falling if this is the case the transformer is faulty and will need to be replaced with one of the same step-down ratio. OR you will need a new AC/DC Adapter, check out this table for examples of the results that you might find.
** The Amstrad Black PSU that reports 24V and 383 Ohms on the primary may still not deliver the rated voltage under load and therefore I have marked this as a false positive and therefore FAULTY.
NOTE: The AC/DC Chargers are constant current devices (the symbol is usually two interlocking circles and even though you can do similar tests on the transformer primary coil its the current that it delivers under load that is important the only way to test this is using a clamp meter on the cable to see the current under load this should match the rated current.
COMPUTER ATX PSU
Most ATX power supplies are known as switched mode can only be tested under load when connected to the PC motherboard this is a bit tricky using a plain old Fluke, AVO or Multimeter the best way is to buy dedicated PSU tester for the type of Power Unit you have, it will check the DC voltages in the range + 12V,-12V,+5V,+5VBs and +3.3V on both the SATA and IDE supply cables these cost about £20 ($35) you can test the unit in as little as 5 mins.
on May 11, 2010 | Computers & Internet
Tip
ERROR codes Canon 6230
Canon 6230 E000 Fuser did not heat up. Lamp, thermal switch, thermistors, connections, AC driver, DC controller, SSR, etc. E001 Fuser temperature too high. Same possibilities as E000, as well as shorted wire. E002 Fuser temperature not rising at correct pace. Same possibilities as E000 E003 Fuser temperature drops. Same as E003. E004 Fuser problem. AC driver, SSR bad, wire shorted. E010 Drive problem. Main motor, gears, etc. E030 Total counter. E064 Composite power board or DC controller. E065 Composite power board or DC controller. E202 Scan motor or scan sensor problem. Panel locked with no code. Scan motor problem. E203 Scan problem or scan sensor. E204 Scan problem or scan sensor. E210 Lens sensor or motor problem. E212 Lens sensor or motor problem. E220 Exposure lamp or exposure lamp regulator board. E224 Blanking shutter motor or sensor. E240 DC controller or composite power supply problem. E244 DC controller. E400 RDF to copier communication problem. E401 RDF Pickup motor or pick up sensor. E403 RDF feed motor or pulse sensor. E404 RDF delivery motion problem. E404 RDF delivery motor problem. E411 RDF tray sensor or registration sensor. E500 Sorter main board or communication with copier. E510 Sorter feed motor. E530 Sorter guide bar motor. E531 Sorter stapler motor. E540 Sorter bin shift motor. E541 Sorter bin motor. E550 Sorter power supply. E710 DC controllerE711 DC controller E712 Document feeder IC failure. E716 DC controller. Sorter. E800 Auto power off function (DC controller) E901 Pedistal motor. E902 Jogger side plate sensor or motor.
on Jan 19, 2010 | Office Equipment & Supplies
I hear no water draining from my heathy soluions lennox humidifier just put in a new filter
None leaking? Try removing the cover, and manually cycling on the controler switch? Does the solenoid click on, next to the humidifier (the unit with the water line running through it, with wires coming out of it)? If it does click on, is water running down the water pad? It doesn't necessarily drain water when it's working correctly. All of the water SHOULD be getting evaporated into the air return duct.
If it's clicking on, but no water is running out, you should check the water supply saddle valve and make sure it wasn't turned off during servicing.
If it's not clicking on, you should test that you are getting voltage (12v-18v DC) to the solenoid. If you're not, check all wiring connections and make sure they're tight. If you still don't get power, you have either a problem with your control unit/humidistat, your DC power supply, or the control board on your furnace.
Jan 06, 2013 | Humidifiers
My Sony pcg-9c1l won't turn on!! When I press the
Could be your adapter, adapter socket - most common issues.
AC ADAPTER CHARGER POWER FOR SONY VAIO PCG 9C1L PCG 9D1L VPCCW14FX... Test your power adapter with a multi-meter. Example below
Hope this works to help you and your situation.
Mar 11, 2012 | Sony Computers & Internet
Tip
ERROR codes Canon 6035
Canon 6035 E000 Fuser did not heat up. Lamp, thermal switch, thermistors, connections, AC driver, DC controller, SSR, etc. E001 Fuser temperature too high. Same possibilities as E000, as well as shorted wire. E002 Fuser temperature not rising at correct pace. Same possibilities as E000 E003 Fuser temperature drops. Same as E003. E004 Fuser problem. AC driver, SSR bad, wire shorted. E010 Drive problem. Main motor, gears, etc. E030 Total counter. E064 Composite power board or DC controller. E065 Composite power board or DC controller. E202 Scan motor or scan sensor problem. Panel locked with no code. Scan motor problem. E203 Scan problem or scan sensor. E204 Scan problem or scan sensor. E210 Lens sensor or motor problem. E212 Lens sensor or motor problem. E220 Exposure lamp or exposure lamp regulator board. E224 Blanking shutter motor or sensor. E240 DC controller or composite power supply problem. E244 DC controller. E400 RDF to copier communication problem. E401 RDF Pickup motor or pick up sensor. E403 RDF feed motor or pulse sensor. E404 RDF delivery motion problem. E404 RDF delivery motor problem. E411 RDF tray sensor or registration sensor. E500 Sorter main board or communication with copier. E510 Sorter feed motor. E530 Sorter guide bar motor. E531 Sorter stapler motor. E540 Sorter bin shift motor. E541 Sorter bin motor. E550 Sorter power supply. E710 DC controller
Turn on the organ and get a loud hum.......
Chances are you're hearing "60-Hertz" hum that comes from poor filtering in the organ power supply. Electronic circuits need direct current (DC) but our power lines supply alternating current (AC). The power supply converts the AC to the various DC voltages needed. Parts called filter capacitors smooth out the voltage, and if they go bad or lose contact because of bad connections the result can be the hum you're hearing.
There are other possible causes, but the filtering is so common it's a good place to start. You don't give the age of this organ, but if it's one that has been around a while, it's a good bet some of those capacitors are worn out.
If you can post a follow-up with a make and model, I'll check some of the technician groups and see if anybody has service information.
Good luck and thanks for using Fixya!
Feb 11, 2010 | Music
Power to Amp but no lights and does not switch on
(1)When the unit is switched on the relay clicks in,but no sign of life, and then five seconds later the second relay clicks on/off don't know which. This symptom is DC outputted to speaker terminals. Check any DC at power amp stage output.(2)Must have blown up.
Positive. If Caps blew, your amp shutted itself down within 5 seconds due to + & - power supply creating an unbalanced +B & - B voltage not allowing your amp to turn on.
Oct 05, 2017 | Optimus STA-3500 Receiver
Ac power Symphonic sc309D blows fuse- Dc power ok
The most likely problem is a shorted diode, I suggest replacing them even if they do not test shorted while not under load. If it is not the diode rectifiers, there is probably a resister in the power supply that is shorted, remember also that it can also be both. Lastly, it can be a capacitor within the power supply.
I Wish You Well
Dec 03, 2008 | Symphonic SC309D 9 in. TV/VCR Combo
My Pioneer Receiver Shuts Power OFF within 10 seconds I put it on.
Hi Sharad! Do this maybe of help. Turn the power off. Wait about 10 seconds, then power up again. Get close to the reciever and listen for a click-not from the speakers,from the recievers itself.If you hear a click, you can assume that the power supply is ok for that circuit.This does'nt eliminate the power supply problem but it will do for now.You would have to check both the positive and negative voltages from the power supply to see if both are present or if one or both are missing. This would be dc voltages and the positive voltage must be equal to the negative voltage ,if one is higher than the other, the regulator transistors in the power supply maybe defective. The transformer can be checked for AC voltage before the power supply.You know that the secondary is good because the dial lights. For this kind of problems you better change the regulator transistors with desame number.
Jun 14, 2008 | Pioneer Audio Players & Recorders
Televison & Video Logo
64 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
